Offline Train train
#1 Posted : 02 September 2025 14:41:22(UTC)
Train train
While doing my Research on the Marklin system I see alot of people using Marklin M track, even with a Marklin digital setup, I'm curious to know if there is a reason for this?
thanks 4 users liked this useful post by Train train
#2 Posted : 02 September 2025 15:18:23(UTC)
Because it's classic vintage Marklin. Also robust.
thanks 11 users liked this useful post by marklinist5999
Offline ccranium
#3 Posted : 02 September 2025 17:55:43(UTC)
ccranium
...and I began collecting analog components, including M-track turnouts, signals and control boxes in the 1980's before (finally) starting on my layout in 2020. I didn't want to start over, and I love the challenge of creating an extensive analog layout!
thanks 10 users liked this useful post by ccranium
Offline hennabm
#4 Posted : 02 September 2025 20:37:13(UTC)
hennabm
I started with my collecting in the 70s and finally built my layout in 2010. As it is an exhibition layout it needs to be robust and M track is the best.
1957 - 1985 era
What's digital?
thanks 9 users liked this useful post by hennabm
#5 Posted : 02 September 2025 22:15:57(UTC)
Much cheaper than C-track or K-track. I won't have room on my new layout for any radius greater than R2 anyway.
thanks 8 users liked this useful post by xxup
Offline Michael4
#6 Posted : 02 September 2025 23:17:22(UTC)
Michael4
Very robust (you can tread on it), very cheap (often free) and, of course, the sound.
thanks 8 users liked this useful post by Michael4
Offline BenP
#7 Posted : 03 September 2025 00:55:24(UTC)
BenP
The M sound of yesteryear and fully compatible with digital operation. C track looks cheap (but isn't). K track is best looking and most flexible, imho, but needs track bed (I have used Merkur).
Just my opinion.
Ben
thanks 12 users liked this useful post by BenP
Offline Willem99
#8 Posted : 03 September 2025 02:00:40(UTC)
Willem99
M track lasts forever.
There are no brittle tabs that will break off.
If it is out of shape you can use a 5 lbs hammer if needed :)
It is cheap on Ebay, sometimes almost free.
I have lots of it, probably too much to ever use.
The list can go on and on.
Tim
thanks 11 users liked this useful post by Willem99
Offline hermanvk
#9 Posted : 03 September 2025 07:51:05(UTC)
hermanvk
I have lot's of M-rail and apart from nostalgia: it's currently too expensive to replace, plus there is no need to, because I still run old style analog...
thanks 8 users liked this useful post by hermanvk
Offline Michael4
#10 Posted : 03 September 2025 11:53:41(UTC)
Michael4
and the M track catenary system must be one of the easiest to assemble and strong enough to withstand "mistakes".
thanks 6 users liked this useful post by Michael4
Offline hermanvk
#11 Posted : 03 September 2025 12:32:56(UTC)
hermanvk
I wouldn't call it easy, but yes: it's strong enough to deal with "mistakes" as I experienced lot's of them! And also: M-rail is pretty tolerant when there are no exact fits.
Just my $0.02...
thanks 6 users liked this useful post by hermanvk
#12 Posted : 03 September 2025 13:02:03(UTC)
I think people use it because they already have it. The amount of M track in the world will not increase and will disappear. But there is probably enough for the next 2O years.
I like C track for good running and decoders etc under the ballast. K track looks the best for those wanting something realistic.
Just a matter of choice and evrybody will like what they have which is the main thing.
thanks 8 users liked this useful post by David Dewar
#13 Posted : 03 September 2025 14:28:40(UTC)
Hi Yall
Why use M track?
- because many have old Märklin trains from decades ago
- because it bring sweet memories from the childhood past
- because it is almost indestructible and very cheap
- because it works very well with digital trains Only restriction is long occupation straches are not avaible but rather easy to make
- because very small radius curves make possible to have an impressive layout
- because nothing beats the aspect of a train in the 50s with old Faller buildings
Temporary layout with my old M Track and old 6021 Central Unit
Yes I admit I use now C Track, works better but more fragile et more expensive
thanks 16 users liked this useful post by JohnjeanB
Offline hermanvk
#14 Posted : 03 September 2025 14:58:36(UTC)
hermanvk
- because fragile et more expensive
Hi Jean,
It seems your French sneaked in...
Flapper
No big deal. I just thought it was funny...BigGrin
Happens to me too, though not French...
thanks 4 users liked this useful post by hermanvk
Offline Martin T
#15 Posted : 04 September 2025 21:42:27(UTC)
Martin T
Who needs anything else than M-tracks? Wink M-track rocks!
Regards / Martin T
thanks 14 users liked this useful post by Martin T
Offline Aussie Susan
#16 Posted : 05 September 2025 00:01:12(UTC)
Aussie Susan
I think other have already covered much of this but my m-track comes from the 50's to the 70's when it was packed up and only brought out recently so I can get it working again for my grandchildren.
I have bought a 'starter kit' that is digital with a small amount of c-track plus m- to c-track converters so I can use all of the rails I have (once they have been cleaned up). I've also bought digital converter kits for the 2 engines I have (the 3rd was 'retired' as the new digital version was cheaper than the conversion kit!!!).
I have some bridge supports that I know can be used on m-track - not sure about c-track - but I also have a 3D printer to make more if I need them.
I guess it all depends where you are starting from...
Susan
thanks 4 users liked this useful post by Aussie Susan
Offline DB Fan
#17 Posted : 05 September 2025 03:29:46(UTC)
DB Fan
I’m in the corner of not using M track anymore. I started a new layout and used M track and found it to be unreliable as in not aligning correctly (side to side or up and down) and had to constantly work on it. Also some engines derailed on the double slip turnouts and so on. I have now mostly c track and traded my m track for K track. Much happier with it on the layout I’m building at the moment. This is just my personal experience and opinion. Just don’t like spending a lot of time fiddling with the track to make it work so my engines don’t derail.
Robert
thanks 6 users liked this useful post by DB Fan
Offline Martin T
#18 Posted : 05 September 2025 07:36:57(UTC)
Martin T
Robert
I agree fully with you. My previous M-track layout was built only using one type of turnout; 5202. No crossings, no curved turnout. Then it worked quite well. All the visible lines were K-track flex (2205) though. My new layout is built exclusivly using K-tracks. I’m not super-happy about the K-track either, since geometry and precision is somewhat 80s still, compared to the 2-rail systems in the market.
Regards / Martin T
thanks 4 users liked this useful post by Martin T
Offline analogmike
#19 Posted : 05 September 2025 12:49:45(UTC)
analogmike
If I had to explain,You wouldn't understand.
thanks 11 users liked this useful post by analogmike
#20 Posted : 05 September 2025 13:49:01(UTC)
I began with the 1926 start set in 1993, then added the 5191 and 5192 extension sets with curved turnouts. and a 7039 home signal. In '98 I got a 6021 control with the transformer. I still have it all but changed to C track and a CS 3 plus for my new layout. The 6021 stays on my workbench. The big blue trafo. from the 2916 set is currently used for some lighting, a crane magnet, and the speed control for a wind turbine generator motor.
thanks 3 users liked this useful post by marklinist5999
#21 Posted : 05 September 2025 18:59:12(UTC)
So long there is still to get metal tracks in the second hand they use it.
Be attention about M-tracks...newer digital locomotive are more advanced but also more comfort to drive with modern tracks like C and K-tracks, not with the metal tracks.
#22 Posted : 06 September 2025 15:38:11(UTC)
I use the straight lenghts and oval of M tracks for testing after repair Marklin old analog trains.
If you build M tracks layout, I recommend cork sheet or sundeala board for M tracks to keep quite running.
Edited by user 06 September 2025 19:36:33(UTC)  | Reason: Not specified
#23 Posted : 08 September 2025 18:14:17(UTC)
It works. For those who want to play trains like they did decades ago, it is the obvious choice, and they still have it.
For those aiming for realism, while it does not look as good as K-track, it can be landscaped in:
but it is never really as nice as K-Track with Merkur track ballast
I use it for tracks in display cases.
thanks 11 users liked this useful post by DaleSchultz
Offline Train train
#24 Posted : 11 September 2025 11:54:03(UTC)
Train train
Wow so many answers to my question, thank you.
thanks 1 user liked this useful post by Train train
Offline 1borna
#25 Posted : 12 September 2025 20:52:59(UTC)
1borna
Croatia
In the mid-50s, as a child, I saw railways from various manufacturers such as Fleischmann, Trix, but compared to their tracks, the Marklin M track looked much better and sturdier! Later, the tracks from Lima, Rivarrosi, Liliput and others only convinced me that I had chosen the right manufacturer.
When K track appeared, it quickly became clear to me that it was too delicate for a lot of assembly and disassembly, I only used it for fixed layouts.
I now also have some C but I don't like the plastic look. Many complain that M track is noisy, but real railways make a lot of noise too!
thanks 9 users liked this useful post by 1borna
Offline sudibarba
#26 Posted : 28 September 2025 04:11:47(UTC)
sudibarba
I have a very large dog bone type layout that I switched to C track. The track is very reliable but the turnout manual levers and lights are very tender.
Now I do switch digitally but some times need to flip the lever.
I am thinking of doing a second level and will definitely use some of the many hundreds of M track and 70 or more turnouts I have. May run with a 6021 with
fewer locos than on my CS3 or use a CS2 That has one functional problem I can work around.
Like others have said, M track is noisy but I have a lot of very clean track that I would like to hear again. Funny, while most of my loks have sound I don't enjoy
the racket they make.
thanks 5 users liked this useful post by sudibarba
Online mike c
#27 Posted : 30 September 2025 18:22:25(UTC)
When the tracks from my new set (1971) proved not fully compatible with the older solid rail track that we had at home, we switched from the older track to the newer ones. In the 80s, I experimented with K-Track as the larger radii were not available for M-Track.
Around 2000, I swapped out the old track for new C-Track (Start Set) and digital. I was discouraged by the problems with the plastic and almost stopped with the conversion. Since then, much of my C-Track has been replaced with the newer and better quality ones.
I still have my issues with the new tracks. The electrical connections for me are not suited for teppichbahn (floor layouts) and for repeated plugging/unplugging. It would be much better if Maerklin went back to some kind of socket rather than those thin pins which can be easily damaged.
A two pin mini socket on certain rail sections would be a better solution, better than the wires from the track (M) or the contact clips (K).
For me, it was all about the larger radii. If there was no option, I would still be using the old M Track. For others, that was what they started with and they had no interest in larger radii, so they did not change.
Offline Br502362
#28 Posted : 30 September 2025 19:32:36(UTC)
Br502362
Hi Mike,
Larger radius M track... how about the older 3800 and 3900 curves?
I am still dreaming of them if I would build a new layout.
Best regars
Åke
Offline 1borna
#29 Posted : 06 October 2025 19:52:17(UTC)
1borna
Croatia
Unfortunately, this model track was produced for a short time and since there aren't many of them, it is very rare and
expensive as a used one.
thanks 2 users liked this useful post by 1borna
This page was generated in 0.777 seconds.
