Offline Diecastcraze
#1 Posted : 31 August 2025 06:12:56(UTC)
Diecastcraze
Hello all
Moving ho dc to ho dcc so got this trix 66950 set with marklin digital box. So i had these two dc locos from piko one is br218 and one is br101 dc and i had put dcc decoders one from digitrax and esu 8 pins . I am not sure how to programme is what and where i am doing wrong i manage to do it , maybe , the problem is ligjts flickring loco moves and stoped and running jerky ..
assumption is those two wires from box not giving enough power
Or dcc decoder
Or i dont know how to programme it
Anyone help me to programme these or what is issue ?
#2 Posted : 31 August 2025 13:35:21(UTC)
A warm welcome to this great forum. Here a Märklin digital fan from Paris France
Assumption not enough power: unless the loco is defective the unit you have (MS2 + Trackbox + 36 W PSU) delivers 36 VA enough to power 4 locos running simultaneously
DCC decoder: they are often similar with a factory-set address of 3. The unit can program most of DCC locos
How to program?
- set the loco ALONE on the track
- power on and select a free space on the MS2 (66950)
- select the fonction discover (shift+Loco) scroll down. The MS2 will search for all possible adresses in DCC, MFX, MM2 and report back
- once discovered select modify loco (Shift+ Loco, scroll down & select), select address and key in the new address (either using the side keys or using the rotary knob, validate, finished
Note: depending on the deocer, often, during programming the lights blink to signal the edit mode
Note: if you accidently have more than one loco during the process then you probably changed addresses on all of them. No Problem: simply repeat the process with ONE loco
This page was generated in 0.204 seconds.
