Offline marklin81
#1 Posted : 30 August 2025 22:12:44(UTC)
marklin81
I am rebuilding a 7186 turntable. The electrical problems have been sorted out. I need help locating the screws and nuts that secure the slip ring to the turntable base. The turntable is missing one screw and two nuts. See photos.
Part numbers or a source would be appreciated.
Pat
Edited by user 31 August 2025 16:54:53(UTC)  | Reason: Not specified
#2 Posted : 30 August 2025 22:49:28(UTC)
Hi Pat
The 7186 turntable was produced from 1951 til 1982 or so. Chances to find spares are minuscule unless you find another one where to extract spares.
Germany (Märklin) has been using metric screws since before WW2 so you are dealing with standard screws (M2.5) or M2 probably . Not sure here but you can get metric scews at very small prices.
Offline marklin81
#3 Posted : 31 August 2025 01:23:01(UTC)
marklin81
Jean, thank you for the response. I already measured: M2x4.5 slotted cheese head screw.
Some internet research revealed M part E755010 for the screw and E757010 for the appropriate nut. A few sources available, including at least one in the USA.
The good news: this project is actually my "spare parts turntable." It has seen some rough handling in it's time, but I'm close to getting it completely functional.
Pat
Offline rhfil
#4 Posted : 31 August 2025 14:42:40(UTC)
rhfil
Having worked in lumberyards most of my adult life I know that good ones have something like a Hillman display which usually include most metric screws and nuts. You can probably get both screws and nuts for very little money at one. Finding a good one will be your biggest challenge. You probably only need to match the length and thread and not the head type.
Offline marklin81
#5 Posted : 31 August 2025 16:54:01(UTC)
marklin81
I'm fortunate to have a lumber yard and two small hardware stores close by, and all have hundreds of fasteners in small drawers, not plastic bags. Certainly a less expensive option. I just hope I don't drop the existing screw and nut while I'm fumbling around looking for a match.
Head size and type on the screw isn't critical underneath, but the nut and screw end need to sit flush in the slip ring to avoid interference with the turntable.
Having confirmed size and availability of original fasteners, I'm calling this question answered.
Pat
thanks 1 user liked this useful post by marklin81
Offline rhfil
#6 Posted : 31 August 2025 20:01:27(UTC)
rhfil
You have the size and the bins are labeled so you should not have to take yours out at all. I usually place small parts in plastic bags and try to handle them only over well lit surfaces which would make finding them easy.
Offline Rocca
#7 Posted : 01 September 2025 21:34:05(UTC)
Rocca
Dear Pat,
Have a look in this internet shop, please:
TTN Internetshop
Stefano
Pat
thanks 2 users liked this useful post by Rocca
Offline Crazy Harry
#8 Posted : 08 September 2025 17:45:24(UTC)
Crazy Harry
Check local hobby shops that specialize in Remote Control cars. They usually have a huge assortment of these small screws and nuts (metric too) for reasonable prices. Du-Bro is the product name I've come across.
Hope this helps,
Harold.
Offline marklin81
#9 Posted : 08 September 2025 18:46:43(UTC)
marklin81
Hope this helps,
Harold.
Harold, thank you for the suggestion. However, the phrase "local hobby shop" takes a different meaning in Mathews County, Virginia. We have no traffic lights or roads wider than two lanes. The local economy is sustained by oysters, crabs, corn, soybeans and tourism.
The good news: AJCkids in Wichita Falls, Texas has most Marklin small parts and had the required 2mm nuts. In addition to the nuts, I renewed my stock of locomotive tires and sliders.
Pat
Offline dickinsonj
#10 Posted : 09 September 2025 00:38:37(UTC)
Pat
That is where I get my small parts too. If they don't have them they will get them for you, although it can take some time.
This page was generated in 0.336 seconds.
