Offline johnhendry
#1 Posted : 26 August 2025 16:34:56(UTC)
johnhendry
We have recently restored a beautiful little BR89 that we think is around 70 years old. It's running perfectly except slows down and sounds like the motor is working harder around right-hand corners. We have completely dismantled and cleaned everything, quartering is good, rods seem fine. Any ideas what it might be?
Offline RudiC
#2 Posted : 26 August 2025 23:18:21(UTC)
RudiC
Do all three axles have enough axial play so they can leave the straight line and follow the curvature?
Rüdiger (Rudi)
thanks 3 users liked this useful post by RudiC
Offline Copenhagen
#3 Posted : 27 August 2025 14:39:22(UTC)
Copenhagen
Also: what about the traction tyres? Are they in good shape? And what happens when you go backwards through the curve (try all the different combinations).
Offline rhfil
#4 Posted : 28 August 2025 16:59:30(UTC)
rhfil
You need to lower yourself so that you can observe exactly what happens on the curve. Do the drive wheels come off? Do they slip? I have had both issues with locos on curves. Lubricating the drive wheels or softening the traction tires solved the issues.
Offline ocram63_uk
#5 Posted : 28 August 2025 20:27:56(UTC)
ocram63_uk
have you got similar radius left curves? If not then that may be the problem, the right ones are too tight. Something like this could be more prone on switches than plain curves, IMO
This page was generated in 0.236 seconds.
