Offline cintrans
#1 Posted : 03 August 2025 14:31:09(UTC)
cintrans
Aruba
I want to get some period correct rolling stock to accompany my Big Boy and was looking at the 45800 UP Hopper wagon set and the 45702 UP caboose.
Are these OK, (in the sense of zinkpest as seen on some other US models produced by M* at the time) or should one shy away from them?
Any of the US manufactures have something similar that would be a good match worth looking at?
I have a whole rack of boxcars but guess hopper cars would be a better match as description of the lok talks about pulling heavy coal trains.... Open for suggestions!
Jean-Pierre
Offline Jimmy Thompson
#2 Posted : 03 August 2025 22:51:15(UTC)
Jimmy Thompson
Coal certainly; basically, if I recall correctly, just about any heavy freight trains, even mixed freight - tank, cattle, box, etc., of that era.
I also recall the Big Boy moving fast fruit/vegetable/produce trains (Pacific Fruit Express, et al.) of refrigerated cars. ("Reefers" if you will...Blink ) Although I suspect that these will be difficult to find...Blushing
So Go For it!
Jimmy T
Dr Dirt's Rule #1 and
Offline dickinsonj
#3 Posted : 04 August 2025 01:12:02(UTC)
Jimmy is right - Big Boys pulled all types of mixed freight. The reefers are something they were specifically designed to pull, hauling fresh fruit from California.
Here is my list of Marklin freight cars bought for my Big Boys over the years, any of which are appropriate. The sets 45657, 45658 and 45659 each have one reefer among other cars. I have never had any issues with any of these and can recommend them if you can find them.
45580
45644
45645
45646
45648
45654
45656-01
45656-03
45657
45658
45659
45660
45661
45662
45664-02
45664-03
45702
45709
45800
48640
Offline Bill L
#4 Posted : 04 August 2025 01:46:16(UTC)
Bill L
Jim: With long trains, have you had to put heavy lead weights into these plastic freight cars that are pretty light, to prevent them from derailing. Thanks.
thanks 1 user liked this useful post by Bill L
Offline dickinsonj
#5 Posted : 04 August 2025 03:05:57(UTC)
Bill, I have never had any derailments caused by the lighter cars, although I do like to put some of the heavy cars up front. The only cars that cause any problems are the tin-plate tank cars from the 48640 set, whose couplers don't mate well with the other cars.
I usually split those up into 2 and sometimes 3 trains, but I have run them all behind one of my Big Boys, with it pulling 60+ cars. It is quite a sight and the Big Boy runs like there is nothing at all behind it. They are such beautiful machines! ThumpUp
Offline cintrans
#6 Posted : 04 August 2025 03:19:12(UTC)
cintrans
Aruba
Thanks for that list Jim
I do have a couple of those on the list already.
So am I correct to see that it does not matter either from witch rail company the wagons are?
They do not need to be from UP specifically?
I am guessing they should be West Coast only or does that not matter either?
Thanks for the input
Jean-Pierre
Offline dickinsonj
#7 Posted : 04 August 2025 03:33:07(UTC)
Happy hunting Jean-Pierre! In the US consists often contain cars from many railroads and although I favor UP cars that is not at all required. They don't even have to be from western railroads, since many cars were forwarded across the country over other lines. The only requirement for me is that they all be from the correct era. I have a number of reference books on UP and the Big Boy and I don't think I have ever seen a unit train of mostly coal hoppers behind a UP steamer.
#8 Posted : 05 August 2025 12:55:03(UTC)
Jimmy Thompson
Jim,
I had found this, which is how I had drifted off into colliery land...Blushing
https://www.trains.com/trn/railr...boys-story-continues-on/
Unsure
Jimmy T
Offline dickinsonj
#9 Posted : 05 August 2025 13:05:52(UTC)
Jim,
Unsure
Hi Jimmy, that is a good point!
Big Boys were such strong locomotives that if there was a heavy load to haul they would do it, obviously including a massive train of hoppers. That is one of the fun things about putting together a consist for one of them, because they were used to haul just about anything that rolled on rails.
This page was generated in 0.308 seconds.
