Online cintrans
#1 Posted : 21 July 2025 00:25:56(UTC)
cintrans
Aruba
Just received my 37990 Big Boy, a display model that only once was removed from its pedestal to test drive it by the owner.
Unfortunately, doing so, the three screws / bolts that hold the lok to its wooden base were misplaced and lost...
Anyone knows what thread size and length these should be?
Jean-Pierre
Offline rhfil
#2 Posted : 21 July 2025 15:27:06(UTC)
rhfil
Does the parts list show the screws? If it does the downloadable parts list gives the thread type, size and length. I don't see them but have no idea where they might be.
Online cintrans
#3 Posted : 21 July 2025 18:41:49(UTC)
cintrans
Aruba
No...
They are not mentioned in the parts list, nor the manual of the lok
Was hoping someone that has a Big Boy would be willing to remove one of them and measure it....
Jean-Pierre
Offline Baureihe 96, DK
#4 Posted : 21 July 2025 18:57:33(UTC)
Baureihe 96, DK
Call Marklin repair service. They can send you new screws for the Big Boy plate. I dont know the amount fot this. I have done this with other things for Big Boy ho. Things i didn`t find in the spare part list.
Bedst regards
Michael
thanks 1 user liked this useful post by Baureihe 96, DK
Offline DasBert33
#5 Posted : 21 July 2025 18:59:47(UTC)
DasBert33
You need 3x M3x20 screws.
But thats not all. Mine (37993) also came with 2 washers (one brass and one zinc, total thickness 1.5mm) for each screw and more importanty also a brass piece each time to put between the wooden base and the loco.
Edit: Note that the mentioned brass bushings are not identical. There are 2 which are the same and then another. Is the odd one for the tender?
thanks 2 users liked this useful post by DasBert33
Offline rhfil
#6 Posted : 21 July 2025 20:20:35(UTC)
rhfil
I have 30 years experience in hardware in the U.S. Not sure about where you are nor even sure where you are but a really good hardware store in the U.S. would have an assortment of metric screws. You could even bring the base in to try them. The length should not be critical but the thread is. Also washers are just nice to have. That would be by far the least expensive way to replace them as they sell the screws individually. Pennies. But if not you might consider buying an assortment of small metric screws which are available from Amazon.
#7 Posted : 21 July 2025 20:40:26(UTC)
The thread is in the loco. If screws are too long, you cannot tighten them. They might even damage the loco if you turn too long screws too tight.
If they are too short, they may not hold the loco safely.
Without the distance rings, there will be pressure on the wheels and that can also cause damages.
Offline rhfil
#8 Posted : 21 July 2025 21:00:42(UTC)
rhfil
The length is not critical so slightly longer or shorter should not matter. And depending on where the flat washers are their purpose is to spread pressure. Generally they go between the head of the screw and whatever the head is in contact with. That way tightening the head does not drive it into the base. Do they go between the wheels and the base?
#9 Posted : 21 July 2025 21:32:56(UTC)
The thick distance pieces go between board and loco.
You want to fix the loco to the board without putting pressure on wheels and axles.
Offline rhfil
#10 Posted : 21 July 2025 23:07:29(UTC)
rhfil
Plus if the screws are too long you can cut them down if you know how to do it properly or add spacer washers.
#11 Posted : 21 July 2025 23:12:07(UTC)
Jean-Pierre
Hi Jean Pierre
Honestly, I was expecting others to be quicker to spare me the extration and opening of my 37990 Big Boy. Sorry about that
So the spacers TOTAL length (not diameter) are:
- front spacer is 9.5 mm
- moddle spacer is 6.5 mm
- tender spacer is 5.5 mm
I spent quite some time to screw the loco on its wooden pedestal so here is my advice:
On a clean and horizontal surface install a cloth to prepare a bed for the UPSIDE-DOWN loco, straight
Install the washers at their proper locations
Install the screws in each 3 holes in the upside-down pedestal
Guide the screws into the spacers
Screw them, Finbished
Hint: colour-code the spacers and their location with a tiny paint markling both on each spacer and nearby where it is screwed
Note: on my loco and many others, the foam bed has lost its elasticity so the less you touch it, the better
Online cintrans
#12 Posted : 22 July 2025 02:07:05(UTC)
cintrans
Aruba
Thank you, that is what i needed!
I think I can find these in our local hardware store.
Jean-Pierre
Online cintrans
#13 Posted : 22 July 2025 02:21:52(UTC)
cintrans
Aruba
Jean-Pierre
Hi Jean Pierre
Hi Jean, thanks for that!
I forgot about those spacers!
And that is most probably the reason why the bolts went never back in after the lok was tested on some track! Its a pain to get them back in with those spacers.
Being in the tropics, that foam has changed in what is best described as pulp.... luckily the cloth protected the lok, so the stuff did not stick or otherwise got into the lok. Planning to let an upholstery shop carve in new piece of foam to replace it....
One more question, both lichted number boards on the front should have X4013 on it? The left side on mine has the number, the right side is blank (white)
Jean-Pierre
Offline DasBert33
#14 Posted : 22 July 2025 13:55:32(UTC)
DasBert33
yes both should have the number. maybe the missing number is sticking to the foam or cloth?
thanks 1 user liked this useful post by DasBert33
Online cintrans
#15 Posted : 25 July 2025 01:46:01(UTC)
cintrans
Aruba
Thank you, unfortunately I found nothing back in the mess that used to be the foam, so it looks like I will need to create some kind of waterside decal to replicate the number....
Jean-Pierre
Offline 1borna
#16 Posted : 07 August 2025 20:52:05(UTC)
1borna
Croatia
I wrote elsewhere about the repair of that model which arrived damaged because it was not attached to the base. It seems someone lost the shortest washer?
Judging by the damage to the grooves in the wood, it appears that someone overtightened the screws and the wheels damaged them.
thanks 2 users liked this useful post by 1borna
Offline Hannes Porsche
#17 Posted : 09 August 2025 22:03:57(UTC)
Hannes Porsche
Hi, are you guys saying I must immediately check the condition of the foam on my Big Boy, as I am having it stored for more than a two Years. ???Blink And yes my situation warranted such "inactivity"Confused So give indications of what foam will be suitable.?? THANKS.BigGrin
thanks 1 user liked this useful post by Hannes Porsche
This page was generated in 0.389 seconds.
