Offline Howard1975
#1 Posted : 12 July 2025 19:19:19(UTC)
Howard1975
Hello everyone, I have an interesting question to ask. I would like to use Marklin 3 rail trains for an On30 type narrow gauge layout. On30 (O-16.5 in Europe) is using HO gauge track, locomotive mechanisms, freight car wheels and couplers, to model narrow gauge trains in O scale. I know that most people generally use regular 2 rail HO scale trains, modifying the bodies, to look nice as O scale narrow gauge. Or buying trains already designed as On30 trains, such as the Bachmann On30 lineup, which is quite popular here in the United States. And I'm certainly aware that Marklin produced the Minex On30 equipment from 1970 to 1972. But I want to build my own custom locomotive bodies, and freight cars. I would start with the regular Marklin model (such as the Marklin 3000 steam 0-6-0 locomotive) and modify the bodies, or scratch build some custom bodies for the narrow gauge trains. I'm on a tight budget, living in an apartment. Same with freight cars, using inexpensive freight car wagons, modified or with my own custom bodies. To look correct as On30 models.
Minex is rather limited in the amount of locomotives, freight cars and passenger cars available. I don't currently own any of the Marklin Minex trains, perhaps I will find some of them at a reasonable price to purchase. Generally the Minex are very expensive when I see them anywhere, and can be hard to find. I see a few available on eBay, but they are a lot of money. I'm on a tight budget.
Basically speaking, I want to use regular HO scale 3 rail Marklin trains, modify the bodies, for use as narrow gauge trains. Yes I know using Marklin to model narrow gauge trains is not very normal, other then using the Minex Marklin produced in the early 1970's. I prefer to use Marklin because of the extra reliability of the 3 rail system, easier layout wiring, and the very durable Marklin locomotives produced in the 1950s to 1980s. I like that vintage Marklin locomotives have metal gears.
And to prevent anyone having a potential heart attack, I would be using the inexpensive small steam and diesel locomotives, such as the Marklin 3000, 3029, 3087, 3090, 3078 and 3080. Nothing valuable or rare. And using small inexpensive freight cars, such as the 4503 low sided gondola car. And other inexpensive small freight cars, which can be modified for narrow gauge railroads. And I will be using the stud rail Marklin M track, from the middle 1950s to the end of production in 2000.
My questions are these. Do you think it would be better to use them as AC powered locomotives, with my 30 VA 6153 blue plastic Marklin transformer for the American market? I have two Marklin blue plastic transformers produced from 1973 to 1991. The bigger transformer Marklin 6153 is 30 VA, while the smaller one is 10 VA, which was from a set.
Or convert it to DC control, with a permanent magnet and 3 or 5 pole rotor? And use my MRC (Model Rectifier Corporation) Tech 2 DC power packs?
Personally I don't think I need digital, because I will only be operating one or two locomotives at a time. On a small layout.
My other question is should I keep the normal Marklin Relex couplers or convert to body mounted Kadee couplers? I want to do switching shunting maneuvers.
Anyway I already own a few Marklin locomotives, about 11 of the 4503 low sided gondola, some other Marklin freight cars wagons. Overall I currently have about 20 Marklin freight car wagons. Over half of them have the metal Relex couplers, and the rest have the common plastic couplers Marklin produced in the 1980's and 1990's.
I don't mind body mounting Kadee couplers on the bottom of the chassis, especially the older freight car wagons with the metal chassis and Relex couplers. Or the newer wagons with the plastic chassis and plastic couplers. The buffers and Relex (metal or plastic) couplers can be removed, and Kadee couplers body mounted to the chassis floor with screws. The problem would be those old vintage locomotives, with those metal hooks. I would need to remove the metal hooks (like for example on a vintage Marklin 3000) with a Dremel type rotary tool.
I own enough Marklin M track to build a simple layout, with four manual switches (turnouts, points), and a couple crossings, and three uncouplers. I will be purchasing some more Marklin M track in the near future, including some more switches.
And I have two of the Marklin blue plastic transformers produced from 1973 to 1991. The bigger transformer Marklin 6153 is 30 VA, while the smaller one is 10 VA, which was from a set.
I also have a couple MRC Tech 2 power packs, because I also run regular 2 rail American DC powered HO and N scale trains.
Personally I don't like the typical small (2 rail) 0-4-0 and 0-6-0 type (or 2-6-0, etc) On30 locomotives, because they sometimes stall on switches (turnouts, points). And I'm not a fan of the plastic gears in Bachmann On30 locomotives, they have a tendency to get cracks and cause problems.
Instead I would rather use the small 6 wheel Marklin locomotives, or the small 4 and 6 wheel locomotives Marklin made in their Primex lineup. Marklin locomotives such as the 3000, 3029, 3087, 3090, 3078 and 3080, and similar. They far more rugged and reliable, compared to any small 2 rail DC locomotives. And it's a lot easier to wire a Marklin 3 rail layout, compared to any 2 rail layout. Especially when using reversing loops , wyes, or a turntable is used, to reverse the direction.
I would prefer to run my vintage Marklin locomotives with my MRC Tech 2 power packs, because they have better slow speed control, and a bigger range of control (270 degrees) on the speed dial, compared to my Marklin transformers, which have a much smaller range of control of the speed dial, and not the greatest slow speed control. I'm considering removing the reversing unit, and running them strictly on DC power. I could keep the field coil and 3 pole rotor, and wire in a couple of diodes, as I have found a diagram online. It would allow to converting the Marklin locomotives to be converted and run on 3 rail, DC power. Keeping the field winding and coil, and the original 3 pole rotor. And adding in a couple dollars worth of diodes, to reverse direction on DC power. It's basically the same method, how the original Marklin electronic reversing computer chip operated, when it was introduced in the early 1980's. Instead of an electro-mechanical reverse unit like before, it was replaced by a simple electronic circuit.
I believe some of the early Marklin locomotives (1950's and older) can be manually reversed with the lever sticking out of the body shell. How would those work on plain DC power? Could I reverse the direction (with the lever sticking out), without making any changes to the motor, reversing unit, or field coil?
Additionally I have the option to completely remove the reversing unit and field coil, and just install a Hamo type permanent magnet and keep the original 3 pole rotor, for control on DC power. It would be a little more expensive using a permanent magnet compared to wiring a couple of diodes in, but not a huge amount of money. I only plan on converting a handful (perhaps around 5) inexpensive locomotives to On30 anyway. Obviously if I decide to continue using the regular Marklin AC transformers, and I keep the field coil and reversing unit, then the only changes would be to the body shell.
Either way, I would be giving it a bigger cab for the O scale engineer and fireman, and a taller smoke stack, bigger headlight in the front, and a few other detail parts. And making freight car wagons a little wider (and taller as needed), and passenger cars taller and wider, for O scale passengers. Unless I find enough of the Minex Marklin sold between 1970 and 1972.
Currently all of my Marklin locomotives have the traditional reversing unit, common from the late 1950s to the 1980s. All of my Marklin locomotives will reverse from the 24 volt pulse from the Marklin transformer. With all of my bigger and nicer locomotives, I will be keeping them intact, as regular HO scale models. I'm only talking about using the small and inexpensive 6 wheel steam and diesel locomotives, such as the 3000, 3029, 3087, 3090, 3078 and 3080, for my On30 conversions.
Like I have said, I would be using Marklin M track, with the studs in the middle, produced from the middle 1950's to the end of production around the year 2000. I'm on a tight budget, I want to keep my expenses low. I already have enough M track to make a small layout, but I will be purchasing a few more switches (turnouts). And purchasing a few more inexpensive freight cars, and a few inexpensive Marklin locomotives produced in the 1950's to 1980's. Thankfully used Marklin from the 1950's to 1980s are very reasonable in price on the used market. I'm talking about M track and small locomotives such as the 3000, 3029, 3078, etc.
Does this sound feasible? What would you recommend? I would really like to build a small On30 layout, but using Marklin components. I would like to do some switching (shunting), not just run trains continuously around an oval of track. I want to operate the model railroad, like it's a real railroad with a purpose. To move around and deliver cargo, and passengers. I might even build a point to point switching layout, with no ability to run around an oval. On30 would give me something unique, something a little different, compared to the typical HO scale, 3 rail Marklin layout.
I will be using a 30 inch by 72 inch table in my apartment. I don't really have the space to put an oval on it, unless I use the very sharp 5120 industrial curves. I currently own four of the manual switches (turnouts), and will be purchasing a few more of the manual switches. I don't really need electric powered switches with the solenoid switch machines.
I can still run my larger Marklin trains on the floor (on the carpet), using the larger 5200 radius curves I own.
My preference for a Marklin type On30 switching layout, would be running the small inexpensive Marklin trains with my DC power packs, remove the Relex couplers and buffers, and add body mounted Kadee couplers (such as the Kadee #5 couplers). For slower speed and smoother speed control. Reversing direction by changing polarity on the DC power pack. Instead of using the traditional Marklin reversing mechanism, and without the added expense of Marklin Digital or DCC command control systems.
By the way, just in case someone reads my earlier messages at this Marklin forum, I no longer own any Marklin digital or Delta locomotives, they have been sold years ago. I'm only interested in going analog and using vintage 1950's to 1980's locomotives with metal gearing, the classic Marklin reliability. I'm completely analog control with locomotives made mostly from the 1950's - 1980's, without any of the DCC, MM, Delta, MFX, mLD, ESU, or Uhlenbrock decoders, etc. I just want simple and reliable trains, I can cheaply and easily repair and do routine maintenance on myself, as needed. I don't want to damage or destroy an expensive and delicate digital decoder, or weld the wheels to the track, because of an overload or short circuit. I also prefer M track to C track, because it's rugged and made from metal. And a lot cheaper compared to the C track.
Perhaps if I had lot's of space for a permanent and large layout, I would be using Marklin K track, and it's flextrack. Along with good condition M track in certain areas, like inside tunnels, and staging tracks, in a helix, etc to save money. But I'm on a tight budget, and I live in an apartment.
Offline Howard1975
#2 Posted : 12 July 2025 23:21:28(UTC)
Howard1975
Just a little update since I wrote that earlier (about using Marklin Trains for On30) scale. I found an another forum (in Germany, a very popular and well known forum), some modelers that have created almost exactly what I'm thinking about. One particular person in Germany has created a very nice looking layout using Marklin M track, and the Minex trains that Marklin produced between 1970 and 1972. I think it's a wonderful looking layout. Over in Germany On30 is often called Oe scale. Over there it's narrow gauge trains in Continental Europe it's at 1/45th scale, while here in the USA it's modeled as On30 and at 1/48th scale. But otherwise it's the same track gauge, 16.5mm which is used by all regular HO gauge trains. This particular person designed his layout to be a point to point layout in the German Black Forest region, using Marklin M track. He has converted his locomotives to digital with ESU decoders. He said his two Marklin Minex steam locomotives (3400) have been converted using motors from Maxon, with the appropriate gearbox. The digital components are ESU 5.0 locomotive sound decoder, With speakers for sound.
Personally I want to keep things purely analog, because of my budget.
And I can't afford the original Marklin Minex that is available here in the USA, it's way too much money for me. I'm on a tight budget. But I can achieve similar results with regular HO scale 3 rail Marklin steam and diesel locomotives, Marklin passenger and freight cars, and modify and convert them to look appropriate as On30. I'm still debating if I want to do more of an American theme, or European theme, or British theme, or a more freelanced theme, using inspiration from narrow gauge trains worldwide. Most likely I will copy narrow gauge trains from around the world, and run them together on my On30 (Oe) freelanced layout. I don't have to follow any particular prototype railroad, instead I can do my own thing, with inspiration from narrow gauge trains around the world.
It looks like that person built most (or all) of his trees and buildings from scratch. I will probably do the same thing myself, to save money compared to using regular O scale trees and buildings I can purchase at hobby shops or online. A lot of his buildings were actually from card-stock or cardboard, and look very realistic. Some of them are cardboard kits the person bought for European O scale.
I saw another person (at another website) that is using Marklin Minex trains (and some other brands) on Marklin M track. That person has modified some inexpensive O-27 trains from Lionel and Marx, (and you could also use S scale American Flyer), and put Marklin HO scale freight trucks, wheels and couplers on the Lionel and Marx bodies. Or any other HO freight trucks with Marklin compatible wheels, from other brands. The freight cars this person made look decent for budget American style narrow gauge trains. Especially when repainted and a few other details added. Those O-27 scale Lionel and Marx freight cars are very close to size with Marklin Minex trains.
The nice thing with doing freelanced narrow gauge trains, is I can be a lot more creative and model whatever I like, wherever I find inspiration from. I'm not restricted to any particular prototype. Although I will try to keep the buildings and scenery to be realistic, perhaps with an American or European themed location.
Offline Howard1975
#3 Posted : 13 July 2025 21:16:32(UTC)
Howard1975
Hello it's me again, I have a few more thoughts about my plans to use 3 rail analogue Marklin equipment for a On30 layout. As I have said in my previous two posts, I will be using vintage Marklin locomotives from the 1950's to 1980s, Marklin M track with the studs, Marklin freight cars, and modifying everything to use on a 3 rail On30 layout. My inspiration is the Marklin Minex that Marklin produced between 1970 and 1972. That was narrow gauge On30 (Oe) scale trains (1/45th) running on regular Marklin M track.
But instead of buying that expensive equipment, I will be adapting the inexpensive and common Marklin locomotives and freight cars. For the time being I will be building a small layout on a 30 inch by 72 inch (76.2 x 182.88 cm) table. I'm living in an apartment, and I have a small budget and a small amount of space for a layout. Hopefully in the future I will have more space available, and a larger budget.
I'm planning on building a point to point switching (shunting) layout on the 30 inch by 72 inch table. It will not be an oval, it's strictly point to point switching type layout. It will be for small On30 narrow gauge trains, because it's a small layout. It will be analogue power, I don't need digital on such a small layout. All of my turnouts (switches, points) will be manually controlled. I will only be operating one locomotive at a time. Because it's a small switching layout, it will be more leisurely and slow paced. I will be using steam and diesel locomotives, the time frame will be around the 1950's to 1960's.
I can build larger temporary layouts on the floor of my apartment with my 5100 and 5200 Marklin track, to run longer trains on the floor.
Even when I build a larger layout someday, I will keep it a backwoods short line narrow gauge layout, 1950's to 1960's time frame, slow paced and relaxed leisurely operations. Operating one or two trains at a time, on a single track point to point main line, with a few passing tracks, one or two small yards, and some dead end sidings for industries. I will not be operating multiple trains on multiple loops of track. Only steam and diesel locomotives, in small towns and the countryside. No need for overhead catenary or Marklin signals.
Too keep my expenses down to a minimum (because of my limited budget), I will be keeping to inexpensive vintage Marklin trains, using good condition Marklin M track, analogue power packs and controls. Modifying or custom making my own On30 bodies for the trains. Building many of my trees and buildings from scratch, or simple kits. Painting mostly undecorated figures (people, animals) with budget craft paints to save money.
Currently I have five powered Marklin locomotives, they operate very well on my Marklin 30 VA transformer. I will be keeping them as is, because I like them a lot. One is a vintage Marklin 0-6-0 TM 800.1 steam locomotive. The other is the Primex version of the Marklin 0-8-0 steam locomotive 3031. I also have one Marklin blue 3034 electric locomotive, and one Marklin green 3037 electric locomotive. All four locomotives are very heavy, with metal body shells and chassis. My last powered Marklin locomotive is the chassis of a Marklin 3146 locomotive, it has it's motor and reversing unit, and it runs very nicely on the track. But it's missing it's body shell. I will need to purchase a body shell for that someday. I intend to keep four of those five Marklin locomotives as normal HO scale trains. The four Marklin locomotives with the metal bodies will not be converted to On30 locomotives. They will remain as regular HO scale locomotives, because of their strong pulling power. I don't need my On30 locomotives to be super powerful, because my On30 layout will feature short trains, from 3 to 6 freight cars. Or with a couple passenger cars. It will be a small time, backwoods short line narrow gauge railroad.
But I will use my Marklin 3146 chassis, purchase the proper body shell (assuming I find it at a reasonable price), and modify the body to become a On30 locomotive.
Like I have said in my two previous posts, I will be purchasing a few of the cheap inexpensive Marklin locomotives, such as the 3000, 3003, 3029, 3044, 3065, 3087, 3090, 3078, 3080, 3095, 3104, 3141, or similar cheap locomotives. Whatever I can find at an inexpensive price with a plastic body shell, because I will adapting and modifying it to become a budget On30 locomotive.
When I someday build my layout, I will power it with a MRC DC power pack, or with my Marklin 30 VA transformer. Depending on what I do with the motors, either using them as designed with the reversing unit and Marklin transformer. Or removing the reversing unit, adding a permanent magnet (or a couple diodes), and reversing the motor with the direction switch on a DC power pack. Anyway with only steam and diesel locomotives on a backwoods narrow gauge layout, I will have no need for overhead catenary, no need for Marklin signals, no need for automated control, no need for digital. I want to keep everything analogue, using vintage Marklin locomotives and Marklin M track.
The reason I want to use Marklin components, is because vintage Marklin locomotives from the 1940's to 1980's are known to be very rugged, reliable, durable, easy to service and repair, and have metal gears, replaceable armatures and brushes, etc. No tiny fragile detail parts to get lost, bent or knocked off. No plastic gears, no sealed can motors, no digital decoders to burn out, or malfunction. Nothing that needs to be sent back to the dealer because it suddenly stopped working, like I read about with those new Marklin locomotives with the latest digital electronics. I can easily service and repair those vintage Marklin analogue locomotives from the 1940's to 1980's myself, with basic tools. I can purchase those smaller vintage analogue Marklin locomotives (such as 3000, 3029, 3078, 3080, 3087, etc) all day long on eBay, often between 20 and 50 dollars each. And naturally more money for the bigger and more collectible analogue locomotives.
And the Marklin M track is all metal, sturdy and rugged. It can easily last many years, as long as it doesn't rust. Most of my Marklin track is over 50 years old, and it works perfectly fine for me. And because 3 rail track is easier to wire compared to 2 rail track, especially when the layout has return loops and wyes, to turn around trains. The 3 rail wiring is just a lot easier. If I have a turntable, I might adopt the inexpensive manual Atlas turntable, they can be found cheap on the used market here in the USA where I live. It's already code 100, the same as Marklin M track. At 9 inches long, it's plenty long enough for my needs. I just need to modify it, by adding a thin piece of metal down the middle of the regular rails, to operate Marklin 3 rail trains with the sliders pickup shoes. Or perhaps I will find a Marklin turntable at a reasonable price.
And on a larger layout (for the future), I would be designing it as a single track point to point type layout. With a few passing tracks, a couple of small yards, and some dead end sidings for industries. I don't need as many of the special short track pieces, which you often need to make complex layouts, with the typical 2 or 3 ovals all connected together. All I will need are regular turnouts (probably a mixture of manual and remote control turnouts, vast majority will be manual), mostly the regular full length straights and curves, and a few of the shorter straights and curves as necessary. A few bumpers for the dead end sidings, and Marklin uncoupling tracks when using Marklin couplers. Marklin uncoupling tracks are not needed, if I decide to use Kadee couplers for the On30 trains. I don't need any contact tracks or other special tracks, because there will be no Marklin signals, no automation, no braking sections. No overhead catenary because all On30 locomotives will be steam or diesel type.
Honestly I believe anyone can build a On30 layout on a small budget. Using inexpensive Marklin locomotives, freight cars, and modifying the plastic body shells to more closely resemble narrow gauge trains. And use Marklin M track (especially when using mostly manual turnouts). Remote control electric turnouts will cost a little more money. I only need like 3 to 6 locomotives, that is perfectly acceptable for a small backwoods narrow gauge railroad, that only operated a short distance between a few towns. Perhaps 20 to 40 freight cars overall, and 3 to 6 passenger cars overall. A small On30 layout can get by with one or two locomotives, 5 to 15 freight cars, and a few passenger cars. The most expensive part will probably be the transformer, unless you get one of the small 10VA or 16VA transformers, Marklin produced for trains sets, and small layouts.
I would build most of my trees and buildings from scratch or inexpensive kits, paint undecorated figures (people and animals) myself with inexpensive craft paints, and have a handful of O scale automobiles on the roads.
It can actually be cheaper compared to the average typical Marklin layout, because I won't be tempted to purchase all of the nice expensive steam, diesel and electric locomotives, or purchase lot's of highly detailed freight car wagons, and long passenger car coaches. I will be busy spending lot's of time modifying the bodies on the cheap Marklin locomotives and freight cars, to more resemble narrow gauge trains. Unless you want the modern digital sounds in your locomotives, which is perfectly fine. I just don't need my locomotives to have any digital computer chips or sounds. I'm perfectly happy with the vintage analogue trains. It can save a lot of money. I can purchase the $ 20 to 40 US dollar Marklin locomotives, $ 10 to 15 US dollar Marklin freight and passenger cars, and the inexpensive Marklin M track. And I won't be tempted to have 50-100 locomotives, 200 passenger cars, and 1,000 freight cars. I'm not doing big Class One railroad main lines, with mile long freights like you see here in America. Or the equivalent in modern day Europe. Modeling American railroads in HO scale just look weird, if you have one or two diesel locomotives and 10 freight cars, as a train on the Union Pacific mainline. Unless you're doing a little short line, or similar. Doing one locomotive and 5 freight cars looks perfectly fine, in a backwoods short line narrow gauge railroad.
#4 Posted : 14 July 2025 11:51:40(UTC)
Interesting plan.
Märklin 3104 is a better fit than 3029 IMHO, because it has larger wheels.
This page was generated in 0.397 seconds.
