Online GlennM
#1 Posted : 03 June 2025 04:20:36(UTC)
GlennM
Dear All,
I have been looking at Roundhouse kits and Faller currently offer a 7.5 degree Roundhouse (perfect for Marklin turntable) complete with a drive system for opening and closing the doors of the roundhouse kit number Faller 120277 which can be found here.
Having reviewed the instructions (instructions) the drive consists of a rack and pinion system (small plastic cog wheel on the servo moves a toothed plastic piece which operates the doors) which is all plastic and requires the purchase of one per door Servo Unit 180726 and also some form of servo control unit in this case Faller 180725. This solution is not cheap, but is it reliable?
My first question is has anyone built this model (or similar faller system with similar door opening mechanism) and is it reliable and did you use all the Faller parts or did you replace with your own servo motors or control system?
My second question is if you have opening and closing roundhouse doors and you did not use the above system, how did you achieve your results? Are you pleased with your results?
I have read articles on the Forum recommending the use of magnets to secure the roof rather than securing it with glue, and any system with require maintenance from time to time but for the price I am looking for something that has reliability. An estimate of cost for a 12 track roundhouse is around Euros 250 just for the servo and control (plus kits) and so having automatic doors is not cheap, but is it a necessary luxury for a modern day layout?
I welcome anyone's comments on the above.
#2 Posted : 03 June 2025 05:05:48(UTC)
… (or similar faller system with similar door opening mechanism) ….
Hello Glenn,
I built the Faller electric locomotive shed 120217 recently (to supplement my old Kilbri unit).Three double doors. I bought 3 of the the recommended electrical units to open and close the doors remotely (180624) and they work satisfactorily but I do not think they would necessarily adapt well to other kits.
Off topic somewhat, my roundhouse is Vollmer. Great building. Doors are “automatic” - the loco pushes the doors open on exit and on return pushes on a plate connected back via a wire to both doors which pulls them closed !!! OhMyGod Laugh LOL hardly prototypical!
PJ
Online GlennM
#3 Posted : 03 June 2025 05:11:53(UTC)
GlennM
Hello Glenn,
PJ
Thanks for your comments, I like the sound of your analog automatic solution for the doors, and it makes more sense than purchasing lots of servos.
I have seen automation videos where the door opens the train emerges and later comes back and doors close. I have also seen a lot of photos where the doors are generally open if there is a loco present and closed if not. This can be done by hand and may be enough. I guess what I am trying to avoid is spending 250 Euros for a solution that is not reliable.
#4 Posted : 03 June 2025 05:51:18(UTC)
. …I like the sound of your analog automatic solution for the doors…
The opening mechanism parts came in the Vollmer kit. The roundhouse must be about 30 years old now. They did not have electrical door opening mechanisms back then. BigGrin
I was intrigued to see that it is still sold by Lippe - Vollmer 45758
Offline Nigel Packer
#5 Posted : 03 June 2025 11:39:36(UTC)
Nigel Packer
I have a 12-stall roundhouse of the original Pola version of this Faller model. It is the same, but I think the door operation may be different.
With some expert help, I built servo operators for the doors, and they work very well. See my YouTube video below.
Dance of the roundhouse doors
The operation is using ESU SwitchPilot Servo decoders (three sets of them), and is run by TrainController software as is my whole layout.
Nigel
thanks 4 users liked this useful post by Nigel Packer
Offline BenP
#6 Posted : 03 June 2025 15:20:35(UTC)
BenP
My marklin kit uses physical door control. Loc pushing a stop closes doors after entering. Works fine though I prefer doors open with locs.
Ben
Ben van der Pluijm--
thanks 3 users liked this useful post by BenP
Online GlennM
#7 Posted : 05 June 2025 04:11:58(UTC)
GlennM
Thank you I will have a look at this kit as an alternative
Online GlennM
#8 Posted : 05 June 2025 04:41:44(UTC)
GlennM
Nigel
Nigel,
For sure the doors you have are impressive, and the ESU SwitchPilot Servo decoders look similar tot he Faller 180725. Do you remember what servos you used, and what is the door opening mechanism, I assume it is steel rod/wire but doe they connect direct to the servo or is there a connection between servo and wire?
This is my particular concern is the reliability/durability of this plastic cog to plastic rack
By the way I thought your roundhouse was Faller 120081 (here)
Edited by user 05 June 2025 12:21:41(UTC)  | Reason: Not specified
#9 Posted : 05 June 2025 11:33:51(UTC)
Hi Glenn
I am using the Fleischmann roundhouses (3 of them) and instead of using servo motors I use Rocrail to manage a slow coasting that make the door shut slowly
I is more simple and the result is equivalent.
Note: I use servos on the Faller Car System for stops and turnouts, for ash removal system and bus stops
All are operated using ESU SwitchPilotServo
#10 Posted : 05 June 2025 17:23:56(UTC)
Over the years had various rouindhouses mainly with a wire opening and closing the doors which was not always reliable. Now I just leave doors open which I think looks better seeing the loco inside with some people standing by. Save nyour cash and just either leave the doors open or let the loco push them going in or out. Faller kits are good.
Online GlennM
#11 Posted : 06 June 2025 06:05:21(UTC)
GlennM
David
That is what I am thinking right now, I bought the roundhouse kits and will decide later if they will be automated but manual operation is looking very likely ThumpUp ThumpUp
#12 Posted : 08 June 2025 12:01:14(UTC)
Nigel Packer
That's a recent Faller re-make of the Pola roundhouse I have (Pola 670). I have all of the Freilassing series in Original Pola (manufactured from around 1997), but some of them, like the wonderful water tower, are unassembled as I have not enough room on my layout for all of them!
Here are some views of the inside of my roundhouse, giving an idea of how the servos are installed. Note the laser-cut structure that supports each servo (not made by me!). Yes, they use wires to connect the servo to the original doors, using the door fitting (small loop) where the plastic spring arrangement originally attached. I was never happy with the mechanism in the kit, as the door operation was too violent, and yet the springiness of the plastic parts was not sufficient to give the doors a positive closing and opening movement.
With computer control, my roundhouse doors open and close appropriately, depending on loco movements, and there are always suitable delays between the doors opening and the loco emerging, for example.
Best wishes!
Nigel
thanks 3 users liked this useful post by Nigel Packer
Online GlennM
#13 Posted : 08 June 2025 12:29:33(UTC)
GlennM
Best wishes!
Nigel
Thanks Nigel, food for thought ThumpUp ThumpUp
#14 Posted : 08 June 2025 12:57:59(UTC)
There are plenty of suitable servos on ebay for a fraction of the price of the Faller/ESU/Noch ones. I believe the they are the same servo, just without the 'name' sticker on the outside, certainly cheap enough that having some spares on hand in case of failure is a minimal cost. Look for SG90 servos, or similar 9 gram actuating force.
This page was generated in 0.545 seconds.
