Offline rogerh2025
#1 Posted : 02 June 2025 08:28:29(UTC)
rogerh2025
The loco was purchased used, oiled and has run for twelve months.It has developed erratic ,or non running.Power is heard and felt from the motor.
Lights flash intermittantly,and motor will run if pressure is put on one side.Wheels are kept clean. Suggests power pick up problem.
I have removed bogies ,contact springs cleaned ,all running gears reoiled.Gear drivers oiled ,reassembled ,but will not run,either forward or reverse.
Wheels have been cleaned ,and cleaned again
The motor brushes seem ok .......any thoughts?????
#2 Posted : 02 June 2025 11:55:51(UTC)
Hi Roger
A warm welcome to this great forum.
Here a fellow Märklinist from Paris, France but in HO scale
Current pick-up issues are pleaguering all brotherhood of miniature trains lovers.
I suggest you verify that all wheels supposed to pick up current are doing so.
Install the loco upside down on a foam bed and with two wires connected to the power source alternately test each wheel pick-up.
Of course this is done after all wheels and rails are cleaned (avoid any abrasive: use rathefr wood for rails and cardboard on wheels while they are turning).
Oiling must be EXTRA sparingly applied: for Z scale the use of an hypodermic syringe s mandatory
PS You may want to watch this
The loco is oêrated while immersed for cleaning
The used liquid is RS24 from Noch NO WATER
Offline Carim
#3 Posted : 02 June 2025 12:58:33(UTC)
Carim
The fact that the motor runs if you put pressure on the loco from one side suggests that you have a contact problem. I would check that the contacts from the bogies are making good contact with the back of the wheels. If that doesn't sort it, the next culprit is likely to be the thin wires from the circuit board connecting to the capacitor which runs down to the brushes. Other than that, check that the brushes are making good contact with the split-ring commutator.
Carim
Offline Poor Skeleton
#4 Posted : 02 June 2025 22:19:37(UTC)
Poor Skeleton
Can you explain what you mean by this? Are you saying that you can hear the motor spinning even when the loco isn't moving?
Lights flash intermittantly,and motor will run if pressure is put on one side.?
Does the motor running coincide with the lights being on or are they independant of each other?
My thought is that the screw which makes electrical contact between the circuit board and metal chassis casting is making intermittent contact. If I'm right, tightening it up should get you back to normal service.
If it's a non electrical problem (from your description I'm not sure) it could be that the drive shafts aren't fully seated and their gears aren't engaging with the mating gears of the motor. This brings us back to the four screws which secure the circuit board and clamp everything in place. Beware, though, that over-tightening them can cause additional friction in the gears and cause lumpy running at low speed.
Hope this helps
Chris
#5 Posted : 02 June 2025 22:32:02(UTC)
Poor Skeleton
Actually, I think I might not have got my facts quite right.
8875 is one of the earlier products and I think it has two screws securing the circuit board in place (one of which is resposnsible for electrical contact) and underneath the circuit board there are two (or possibly four, I can't remember) more that hold the two halves of the chassis together.
Chris
Offline rogerh2025
#6 Posted : 02 June 2025 23:06:22(UTC)
rogerh2025
There are two screws holding the circuit board.One is pinning a connector for the motor brush.Tightening and adjusting has made no difference.
I suspect the problem is with the bogie connectors,behind the wheels.If the bogies are waggled side to side,intermittant connection is made,motor spins and bulbs flash on .
These terminals have been cleaned,but look worn away,and are no longer behind the wheel surface .Good second hand parts are rare to come by .......
Offline Zme
#7 Posted : 03 June 2025 04:52:19(UTC)
Zme
Hello, hope all is well.
There are many excellent comments concerning your 8875. I am always amazed with the results shown on the YouTube.
No amount of cleaning can make up for any parts which are worn out or maladjusted. It seems you received many years of trouble free use from this sturdy locomotive. I have this one also and it has started to act up also. I agree, parts have become harder and harder to find.
If you have an eBay account you might be able to search the user “marklinpro”. He is known to have these older parts. Looking at his listings for the US he has these parts for about $6.00. Even with mailing and customs you might be able to get a few more years of service from this locomotive. I believe this is the wheel contact you are referring to. You likely will not find new old stock parts if the condition shown troubles you. This seller has a good reputation on eBay and I have purchased from him myself.
Remember there is a part which works for the front and a different one works for the rear boggles.
This model was significantly redesigned and parts from these would not work on the older models
This might solve your performance issues. I hope it does.
Just a suggestion.
Take good care.
Zme
Offline rogerh2025
#8 Posted : 03 June 2025 15:50:18(UTC)
rogerh2025
Can't find the supplier you nentioned on EBay,unless he uses another ID.
The new cost of trucks from Marklin is equivalent to a full used replacement loco,so I think I'm going down that route........
#9 Posted : 03 June 2025 20:38:13(UTC)
Poor Skeleton
It will be a fidlly job, but with some patience you could repair the contacts with phosphor bronze strip. You'll need a fine soldering iron but you should be able to get things working again.
Good luck!
Chris
Offline Zme
#10 Posted : 04 June 2025 19:38:25(UTC)
Zme
Hello, just a quick note to let you know, it is possible parts listed on the Marklin site are for the newer versions of this locomotive. If the model you have is similar to the one released in 1972, the parts may not fit. I am not certain when it happened, but the original model was redesigned with the new motor and the brushes integrated together.
Also, if you decided to purchase a new locomotive, you will find the new model is a lightweight version which will lack the strong pulling power of the original. Of course you would get the benefit of a quiet, yet adequate motor.
Take good care.
Zme
Offline rogerh2025
#11 Posted : 04 June 2025 20:02:28(UTC)
rogerh2025
You are quite correct.I tried to change over bogies from another model,just to try,and they would not fit.
Probablly due to trade tarriffs fron USA,Ebay will no longer allow purchases from there to Uk,and sites are not visible here.This has only occurred recently........
thanks 1 user liked this useful post by rogerh2025
Zme
Offline Zme
#12 Posted : 05 June 2025 02:01:01(UTC)
Zme
I believe eBay selects the country for your purchases based on the information in your account settings regarding your location. In the past, it was possible to turn off this eBay setting and then select the country you want to purchase from. You could try this and select the US as the country you want to purchase from. After this is your selected country you could search for user marklinpro. Or search for the product numbers shown in my photo above.
To change Country
On app, select my EBay, then settings, and under general choose Country. At the top turn off the switch which removes auto detection of country or region. Once off go down country list to find US. When you return to the home page, is should change to US. Reverse this procedure when you are finished.
Be careful changing the country, because you don’t want to accidentally change to a country which you don’t read the language. Chinese for example would be difficult to reverse.
I recently made a purchase from Germany. It was costly because of the tariffs, but the transaction was completed without issues. You should have a similar experience. Before making a purchase, I always ask the seller if they will send an item to me in the US.
Hope this helps.
Take good care.
Zme
This page was generated in 0.404 seconds.
