Offline Drongo
#1 Posted : 17 May 2025 14:51:26(UTC)
Drongo
Hi Fellas, It's happened again with a short circuit on my large HO scale layout. I've been trying to find a short video on YouTube on how to detect where the short is happening, however, all the videos are on a 2 track system. Can someone either explain how to detect the short and give me the link to a video on YouTube as this is a lot easier to understand.
Greg
#2 Posted : 17 May 2025 18:07:17(UTC)
As allways, one has to be systematic, and proceed step by step.
Now, your layout being permanent and quite old, my bet is that some metal bit has been dropped on the rails, creating a short between pukos and rails. Maybe in a point (switch).
Second; Inspect all your rolling stock, maybe something has derailed, and is bridging pukos and rails. (did an item with a slider stop on top of a DKW¿?)
Thirdly; Did a cable come loose? -Maybe even on the underside of the layout. This can be almost impossibe to find, which lead to my fourth and final point;
Segmentate your layout. If the cuplrit hasnt been found yet, you need to separate your layout in parts. Ideally you power HALF your layout, and see in which of the two halfs the short exist. You then proceed to further segmentate the half where the short is, and so on.
Good luck.
#3 Posted : 17 May 2025 18:17:26(UTC)
First thing to do would be to remove ALL rolling stock from the layout.
If there is still a short, then you have eliminated all your locomotives and coaches/cars as the cause and the problem is with the track or wiring.
On a small layout, it is possible to detect the location of the track short by sound or smell. On larger setups and setups with complex wiring, this becomes more of an issue.
Listen for sounds (sizzling), look for signs of a short (heat damage, burn marks, etc)
With a digital layout, you normally have a few seconds before the system trips. Check areas where wiring is connected to the rails to ensure that a wire strand is not making contact with the ground/live.
I have seen this with K Track feeder sections. With C Track, it is more frequently bent tabs under the track which can cause shorts.
First question is what track are you using? M, K or C?
Can you describe your setup? How many transformers/boosters? What controller? Is the short affecting one section or the entire layout?
Are you powering accessories (lights, signals, etc). Is there a possibility of a short between that circuit and the track circuit at some point?
It can be frustrating to have to check every track section for contact issues.
Looking for Maerklin specific videos is often easier when searching in German (Maerklin Digital Kurzschluss finden or similar)
As Maerklin now uses DC power for digital operation, you can use the same instructions for short detection as for a DC/DCC layout.
One of the first things I would recommend is to swap out the power supply track section(s) and test to see whether the short occurs with the layout disconnected as well as with the replacement track section.
This will identify or eliminate the feeder track as the source of the short. If you have multiple power sources (transformers/boosters), repeat the same procedure for each one.
You can try submitting your question to digital(at)marklin.com to see if Curtis or Rick have any suggestions on how to narrow down your search for the cause.
#4 Posted : 17 May 2025 19:58:55(UTC)
Spit up the track into sections. Hopefully not screwed down otherwise c track comes apart easily.
#5 Posted : 17 May 2025 20:43:05(UTC)
Do you still use old time wagon lights?
For many years ago when i did had Märklin train i did had short circuits caused of the lighting kit 7335!
You should check if there are fault with the trains, locomotive or wagons with the old time lighting are also possible troublemaker.
Online DasBert33
#6 Posted : 17 May 2025 21:52:36(UTC)
DasBert33
How about using a multimeter to measure the resistance at various spots on your layout? Where the resistance is closest to zero your short will be more or less located.
Just be sure to measure without any power applied, and all rolling stock (with sliders at least) removed.
thanks 2 users liked this useful post by DasBert33
Offline Drongo
#7 Posted : 18 May 2025 08:46:54(UTC)
Drongo
Thanks fellas for the information.
I'm using a new ECoS 50220 as the old one was playing up. I have 2 ESU boosters (1 - 4amp & 1 - 8amp). The layout is divided into 2 power sectors and when I plugged the main section into the 6amp ECoS the short started. However, when I plugged the main section into the 8amp booster the short stopped. I noticed that the power consumption is quite high when nothing is running, so there must be something drawing this power, but not enough to overload the 8amp booster. While things are running I'll continue with this setup, but it could be leading to another later problem.
Greg
#8 Posted : 18 May 2025 10:31:49(UTC)
Greg
Why didn´t you reported like this at first?
Waste of others comments whis has nothing to do with your digital system!
Buy Märklin CS3 next time!
#9 Posted : 18 May 2025 14:20:28(UTC)
So you have a short using 6A*19Vac (Thats more than 100Watt). Thats´s enough to start a fire, yet you choose to just let it go, and continue with 8A which doesnt cut out. That doesnt sound like a good idea... RollEyes
Offline Drongo
#10 Posted : 18 May 2025 14:42:10(UTC)
Drongo
Yes, I agree with you, however how to I find the cause of the shorting ?
Greg
#11 Posted : 18 May 2025 15:06:36(UTC)
I think at least both Mike.C and I have given you suggestions on how to proceed. It should be quite straight-forward, I think.
#12 Posted : 18 May 2025 20:05:06(UTC)
Greg
If you have a voltmeter then measure at various places along the track looking for the lowest voltage. The more digits the voltmeter has the better as it will have better sensitivity at low voltage. I have used this technique to find a shorted component on a printed circuit board - but I used a power supply with current limited at a safe value.
Online DasBert33
#13 Posted : 18 May 2025 23:06:52(UTC)
DasBert33
I think there should be a information page in your ecos somewhere that reports actual and peak consumption for your boosters. What does that say? Does it really say 6A somewhere? Maybe it is just the startup current that is too high but not DC? Do you have a lot of capacitors too charge? If yes, is it an option use more boosters at once, ie split the layout in more sections? I think for ho scale it is not recommended to use more than 5A per boosted section.
thanks 1 user liked this useful post by DasBert33
Offline Drongo
#14 Posted : 24 May 2025 07:35:55(UTC)
Drongo
An update on my problem.
I've come to the conclusion that there is something that is consuming around 2.5 amps and by using the 8 amp booster, I don't get the short circuit. Now all I need to do is identify the culprit.
I use servo motors to operate my turnouts, approximately 70, and I was using track power to operate them, so I connected a Marklin 16v AC power unit via an ESU SwitchPilot 3 Servo and this reduced some of the power consumption, but not much. However, when I connect the power to the Marklin power unit I hear some "switching sounds". I need to identify where these sounds are coming from.
More updates later,
Greg
Offline ocram63_uk
#15 Posted : 24 May 2025 09:48:44(UTC)
ocram63_uk
with the Ecos you can enable to set all switches in 'normal' position at startup as well as powering off tracks. Have you checked this setting?
maybe this is the switching 'noise' you hear?
Offline Drongo
#16 Posted : 12 June 2025 14:56:09(UTC)
Drongo
Hi everyone, after hours of investigations, trials and many errors, I have finally found the source of the problem. Of course it's a simple problem which is easily overlooked. My layout has quite a number of drop downs to the main buss and I have 2 levels to the whole layout, with the upper level (powered from an 8amp booster) and the lower level powered from the internal power of the ECoS (6amps). One of the active drop down wires somehow wasn't connected to the top buss and it was touching a track rail on the lower level. Not enough to cause an overload but enough to cause a small spark which heated up the PVC insulation and being a former plastics worker I recognised the odour and I followed my nose to the culprit. No wonder I'm going bald. But as they say, "all's well that ends well".
Greg
thanks 2 users liked this useful post by Drongo
#17 Posted : 12 June 2025 15:00:01(UTC)
Sounds like plenty to stump me as well. Glad you found it!
#18 Posted : 12 June 2025 19:05:29(UTC)
Greg
Why do you use so much power consumption when you use H0 scale?
Digital expert recommended 3 Amp per each track area.
In my life i have never ever used more than 3 Amp on my layout.
#19 Posted : 12 June 2025 19:25:57(UTC)
Hi Guys
Sorry to jump in the conversation and add my grain of salt.
Indeed old locos when digitalized need a lot of current BUT recent locos (I use Märklin ones) need very little current:
- less than ONE mA (Milli Ampère) with light and sound ON
- 100 to 150 mA for a running loco
- 100mA additional for a smoke unit when turned on
- 150 to 200 mA for a pulsed digital smoke unit.
Of course in thses recent locos there are only LEDs and no bulbs
My layout is L-shaped 3.5 m x 3.5 m on 3 levels and includes 27 locos powered simultaneously, a large number of lighted coaches and the total current need in 3.0 to 3.5 Amps
Here is a flavour of it
Sorry for the long speech but when using recent locox and coaches 3 Amps allow you to power quite a layout without having to use boosters, etc (I use only on CS3 with a 100 VA PSU
Offline rhfil
#20 Posted : 13 June 2025 19:03:15(UTC)
rhfil
Not an electronics expert but if your layout is in blocks couldn't you determine which block by testing for conductivity across the track in each block with the power off and no locos on the layout?
Offline BenP
#21 Posted : 13 June 2025 22:13:18(UTC)
BenP
My 0.02 about power. I have a digital M layout with all locs digitalized (5 pole motor, esu5/marklin decoder). Most have LED lights, but several retain 19V bulbs. Wagons all have LED interior lights.
The big power draw is bulbs in old switches and signals. I had to remove all switches lights (40~) to stay below 4A when running trains (about 6 consists at the same time; more on staging tracks w lighted wagons). Signals and semaphores (~30) have original bulbs, which I may replace in the future to lower amperage demand (though not all led replacements I tried worked for this; something about +/- wiring).
Interestingly, I tried running an old Roco TEE with 1.5A motor (why so big?) that, predictably, overloaded my CS3.
Ben
Ben van der Pluijm--
This page was generated in 0.697 seconds.
