#1 Posted : 14 May 2025 12:04:04(UTC)
Copied from the FB group because I thought it may be of interest to some here.
The layout appears to be based on 0463 from 1968. Interesting that the wiring is fully displayed on the perspex, and no scenery at all.
It was obtained from a model shop in the US and was still in its original shipping crate as per the photos.
Apparently it does have legs to make it free-standing but some work is required in that area so it's shown temporarily supported on two fold-out tables.
It 'appears' to be original, and that it possibly came direct from Märklin, but without any supporting documentation all there is to go on is the style and design of the layout, and the details on the crate which clearly state "Made in Western Germany" but do not carry any specific Märklin details.
Reeves International were a large Märklin importer & distributor at that time. It's also entirely possible this layout was commissioned and built in Germany but not by Märklin themselves.
Has anyone seen anything like it before?
One obvious question is Why? It seems more of a demonstration layout than the usual Shop Window layout with scenery etc. But demonstrating what exactly? It is missing the turntable in the open area but I understand that is with it, just not mounted at present.
Other perspex layouts can be found, and there were perspex layouts available at the release of Digital to show the lack of wiring whereas this one seems to show the complexity of it and nothing that would be particularly innovative.
It's also quite large and somewhat fragile.
dafd1716-382a-4426-bb7e-53122dcab318.jpg 8c55372f-738a-4077-aafe-914e391802b9.jpg
bbb96a6d-832c-4e3d-95fd-9ab4c1216a9f.jpg d2f9d3b0-61b4-47b8-b5fd-a554eaa4ece9.jpg
8c72f508-55db-4519-b69c-a3cb61c709da.jpg ec0bd160-4933-4f49-a77b-6cc0aea14f05.jpg
ea95518b-eadf-4a49-a91b-4d151eec2adb.jpg f6b663e3-fd0b-4613-bfdc-eb20862a7b34.jpg
deffb5fd-8378-46ae-b1ec-73e9a5278fcd.jpg cfcc0cf5-0365-401e-90f7-00ecdf2940e2.jpg b77c2964-7538-48f1-ac73-fb8856754a4c.jpg
thanks 17 users liked this useful post by cookee_nz
#2 Posted : 14 May 2025 12:53:59(UTC)
Thank you for sharing this - it is very interesting. Any idea on the thickness of the Perspex?
It looks unfinished - did they not get around to adding the turntable? Confused
Whenever I see neat wiring like that, I suspect a disturbed mind. Cool
thanks 6 users liked this useful post by xxup
#3 Posted : 14 May 2025 13:39:33(UTC)
I have a Marklin built perspex layout that uses K track, built in the early days of digital, to show the minimal wiring a digital layout requires. It is smaller than this layout, with a single loop of track with R1 curves at the end, and passing loop on one side and a bunch of sidings on the other side. The perspex is about 12mm thick, which makes the layout quite heavy. It also has perspex blocks under it at suitable points so it is lifted up off whatever table or cabinet it is fitted to, so the wiring and and k84 and s88 don't get damaged.
In addition it came with an enclosure made out of square steel tube (30mm square?) and a plate glass top so it can be used as a shop counter with a layout under it. The cabinet and plate glass top are even heavier than the layout itself.
Offline Willem99
#4 Posted : 14 May 2025 15:12:47(UTC)
Willem99
Comparing that wiring to mine, I do not have a disturbed mind :)
But it looks absolutely wonderful, wish I could do it like that, but I do not have the patience.
The shortest way between two points is a straight line, at least that is what my teacher told me in school.
Tim
thanks 4 users liked this useful post by Willem99
Offline Jimmy Thompson
#5 Posted : 14 May 2025 16:44:43(UTC)
Jimmy Thompson
Well...my "Minimalist" bits of my mind are entranced by this. Love Also tickles my Tischbahn Tendencies BigGrin
As a Silly Wild Jimmy Guess...perhaps it was commissioned for a Train Show (there has been a big show in Maryland (near the final destination per the label) for many decades, although I am not sure how far back and whether this layout pre-dates the shows...)
Just a thought, and it would be pretty cool at a show. And one would not have to worry over buildings and scenery getting damaged during travel. A kind of "Behind The Scenes" / "How The Magic Happens" ThumpUp
Edited by user 14 May 2025 20:11:12(UTC)  | Reason: Not specified
Jimmy T
Dr Dirt's Rule #1 and
Offline osoraku
#6 Posted : 14 May 2025 16:52:27(UTC)
osoraku
Dear All -
My totally ignorant guess is that it is a display for a trade fair, which would account for the bespoke - and battered - shipping crate.
Osoraku
thanks 3 users liked this useful post by osoraku
Offline nzr1
#7 Posted : 14 May 2025 17:09:58(UTC)
nzr1
The adressee - Hobby Works, 360 Domer Ave, Laurel Center, Laurel, is still in business but moved a couple of shops down to 354 Domer.
They have several branches but their headquarters is in Laurel.
They maybe able to help with some history.
It's a fantastic find. Thanks for sharing it with us.
Pete
thanks 3 users liked this useful post by nzr1
#8 Posted : 14 May 2025 21:34:25(UTC)
Jimmy Thompson
kiwiAlan wrote: "I have a Marklin built perspex layout that uses K track, built in the early days of digital, to show the minimal wiring a digital layout requires."
That would be fascinating to see and compare with the above layout Drool
Jimmy T
#9 Posted : 14 May 2025 22:35:14(UTC)
It looks like Perspex is about twice the weight of the same sheet in plywood (depending on the base wood used in the plywood - I used pine for the comparison. ) 2.4m x 1.2m x 12mm is around 40Kg. Too heavy for me to move on my own.
#10 Posted : 15 May 2025 01:29:52(UTC)
Alan, you kept that pretty quiet.
Where's the photos ??
BigGrin
#11 Posted : 16 May 2025 17:51:01(UTC)
BigGrin
I have had it for a good few years now, maybe 20 years. Bought off eBay, and I had to go down Kent way to collect it. Driving back around the M25 with the back end of it handing out of the Ford Focus wagon on a wet evening (I had to tie the tailgate down with some "stretchies") was an interesting experience.
I will organise some photos one day .....
Offline Paul59
#12 Posted : 17 May 2025 10:23:02(UTC)
Paul59
Alan - that sounds very familiar.
I went to Germany in 1987 and remember a layout similar to your description in a couple of model shops.
The layouts were an oval circuit with loops and sidings. The layout was symetrical and divided into two halves both the same.
One half had all the points etc controlled as analogue with the wiring to the control boxes all visible through the perspex. The other half had the points etc wired digitally.
It was a good demonstration of the difference between the two - the digital side having a lot less wires.
The layouts were on a perspex base with perspex sides and top (the top might have been glass). It must have been a standard Marklin display as I seem to remember the same display in a couple of shops.
As I say it was an excellent way of showing how much easier the wiring was on the 'new' digital system.
That said I still prefer analogue!
Thanks for the memory jog. Be nice if you could post some pictures of yours as I suspect it is the same display - or at least very similar.
Cheers, Paul
thanks 3 users liked this useful post by Paul59
#13 Posted : 17 May 2025 13:27:43(UTC)
Cheers, Paul
There may have been options in what could be purchased. Mine is set up as all digital, and I don't recall any signs of analogue type wiring. My layout uses 2100 series K track, so that makes it really old, and I believe was set up for demonstrating digital control, which would have been really new at the time.
#14 Posted : 19 May 2025 07:54:17(UTC)
Cheers, Paul
Most likely one like this...
The dealer leaflet
And a variation with some M-track substituted, possibly by the dealer rather than from the factory to show how digital & M-track work well together
Offline Paul59
#15 Posted : 19 May 2025 09:54:47(UTC)
Paul59
That looks like the one Cookee.
I seem to remember there was a little bit of M track with most of it being K track.
I wish I'd taken some photos but I was mainly interested in 'Z' gauge at the time.
As I say - the identical display was in two different shops so it must have been a standard Marklin dealer item.
That was 1987 so digital (as opposed to Delta) must have been fairly new.
Thanks for the little trip down memory lane.
Paul
thanks 1 user liked this useful post by Paul59
#16 Posted : 19 May 2025 11:28:18(UTC)
Jimmy Thompson
To my poor old eyes it appears that the top picture with the glass shell also has M-track sections (at the "back" or top of the pic) with one of the M points converted to digital control (the wee black box attached to the side of the point (left, "digital" side in picture) and it (the controller) appears smaller, more distant (tacked on), and on the opposite side (curve vs. straight) than the K-track point controls - the other "M" point (right side in picture) does not have the black box). Cool M and K playing well together! And showing that M points can be converted to digital?Woot
(less easy to discern is whether the 2291 K-to-M adapter track section is in use, although I suspect it would be)
And referring back to the origin of the thread, we might even surmise that the large M-track on Perspex was...The Prototype For Everything...Woot Thank you Reeves and Hobby Works! ThumpUp
Edited by user 20 May 2025 12:11:39(UTC)  | Reason: added parentheticals
Jimmy T
#17 Posted : 20 May 2025 07:28:07(UTC)
Pete
That's who the owner got it from but they've already said they have no info on the layout, those that did know are long-gone.
Seems the layout was held onto until they bascially had no choice about letting it go. Thankfully an enthusiast was available to rescue it.
#18 Posted : 20 May 2025 23:51:42(UTC)
Originally Posted by: osoraku Go to Quoted Post
Dear All -
Osoraku
All of Märklin's sales models, layouts etc come in a similar solid style shipping crate.
Here's how the Sonnenuhr (Sundial) was shipped
And other layouts in similar style, mostly with lift-straps attached to get them out easily
Finding them with their original crate is always a bonus :-)
thanks 9 users liked this useful post by cookee_nz
#19 Posted : 21 May 2025 07:07:36(UTC)
Tim
That's how Märklin do all their factory layouts, nice straight clean lines, and connectors.
For one thing, it's very easy to follow and understand. Also the tidy routing of the cabling, and adherance to the Märklin colour-code system makes troubleshooting considerably easier.
The downside, if you call it that, is that yes, noticably more wire is used than the straight line principle, but we've all seen the underside of layouts where it's a jumbled birds-nest of wiring. They can be a nightmare.
Digital defintely makes some of that much easier but unless you have decoders at each accessory, you're still going to have some longer runs, especially for feeders and contact/feedback sections so might as well have it tidy.
This is the wiring of my own factory layout, and topside.
Topside
And the original schematic has all the connections noted as to which contact track operates which signal or turnout in automatic operation. What's not to love BigGrin
#20 Posted : 21 May 2025 11:35:51(UTC)
Jimmy Thompson
Drool ThumpUp
Jimmy T
This page was generated in 0.618 seconds.
