Offline fje
#1 Posted : 10 May 2025 12:50:34(UTC)
fje
Hi, I just got a second hand CS2 60213 (I know it is an old one with some issues, but for the use I will do of it, just testing layouts from time to time, it is fair enough, because it is an improvement over my old Intellibox I, at least it supports Mfx), but it is missing the front underside support/backing "legs", whatever it can be calledBlushing, that elevate the front side of it, helping to use the two underside connectors.
I looked at the spare parts of the CS2, but there is no mention about those support "legs", and I'd like to find them, because I will be using the underside connector for S88 and the 6017 booster.
Does anyone know where and how I could find and get them?
Thanks for any help and kind regards.
Javier
Offline FrankF
#2 Posted : 12 May 2025 09:22:12(UTC)
FrankF
Maybe this Product could help you - it will lift the CS2 unit a little bit up so that you can use the S88 and the 6017 Booster Connection.
https://mandau3d.de/produkt/bedienhilfe-fuer-maerklin-central-station-2-halterung/
CURRENT MARKLIN SOFTWARE/GFP/FIMWARE - UPDATES:
• CS3+ 60216 SW 2.5.2(6) • CS2 60215 SW:4.3.2(4) • MS2 (SW 5.6) • 6011x GLEIS-BOX (GFP1.70) • MS2-WLAN (FW 5.4.0.21) • 60117 WLAN-BOX (FW 0.3.0.2) • MS1 (SW:1.8 AP) • S88 LINK (SW1.1)
• MDT V3.6.0 (HW: 60970/60971/60801) • MLD3/MSD3 (FW 3.3.6.2) • MSD3.5 (FW 3.5.1.1) • 1098 MLD3/MSD3 DECODER-PROJECTS ON M-SERVER • MARKLIN SOUND-BIBLIOTHEK ( 33.744 SOUND-FILES )
• LOK-PROGRAMMER (SW5.2.15) • ESU HW (53451/53900/53901)
Offline fje
#3 Posted : 12 May 2025 09:52:20(UTC)
fje
Frank, thanks. This could be a good solution, but I don't have a permanent layout installation, >I only build something once or twice a year to experiment and test new features and things, so, this would imply another thing to find place to store... :) I would keep it in mind for the case, but the retractable legs or a similar (less nice, of course) as a pencil (cut) or similar, could be better.
Thanks anyway and best regards
Javier
OceanSpiders 2.0
This page was generated in 0.322 seconds.
