Offline tgj
#1 Posted : 04 May 2025 19:44:59(UTC)
tgj
Subject: Help! CS3+ seems to be changing my turnout addresses when I add mfx devices
Hi everyone,
I’m getting confused about how mfx and Motorola/MM addresses interact on the CS3+.
Here’s what happened:
I programmed all my turnouts manually on the CS3+ and noted their MM addresses.
Yesterday I added a batch of new signals and let the CS3+ search for mfx devices.
The search completed—but the CS3+ also “found” a bunch of my existing turnouts even though none of them were set up for mfx.
After that, several of those turnouts stopped responding to their original manual (MM) addresses. It looks like the CS3+ overwrote them with new mfx IDs.
Has anyone else run into this?
Clearly I’m misunderstanding something about how to configure mixed mfx/MM systems. Any tips on:
Preventing the CS3+ from re-identifying MM accessories as mfx
Restoring the original addresses without deleting and re-adding everything
Thanks in advance!
— Thorben
Thorben Jensen - Denmark
CS3+, Märklin HO
TC Gold Version 10.0 B3, 64 bit
Windows 11 Home
thanks 1 user liked this useful post by tgj
#2 Posted : 04 May 2025 20:07:50(UTC)
Hi Thorben
Here is the little I know on Märklin devices.
When chosing the MFX operation of decoders (m83, m84, in-situ decoders) you accept that:
- the CS3 assigns the MFX adresses in lieu of all previously selected addresses
- therefore, you must ERASE all previously stored addresses for the SAME device in MM2 or DCC
- you switch to MFX as soon as you push the key find MFX accessory decoders
- the decoder will IGNORE the MM2 or DCC commands as soon as the MFX protocol is identified and registered on the accessory decoder
- you cannot block the MFX protocol on the decoders. Just refrain from pushing that MFX search key.
Some (like me) HATE that someone else is selcting addresses for me and therefore:
- NEVER push this button Find MFX Accessory decoders
- code the address on the switches on the decoder
- note the address on an EXCEL spreadsheet to keep track of them and avoid duplications
- in this way you go under the table only once
In case of erroneous MFX registration, just erase the created records and you are in business
Offline tgj
#3 Posted : 04 May 2025 20:47:34(UTC)
tgj
Hi Thorben
Hi Jean,
I appreciate your detailed explanation regarding the MFX protocol and its interaction with the CS3. Unfortunately, I learned the hard way about the implications of using the "Find MFX Accessory Decoders" function.
After setting up over 70 turnouts manually with specific addresses for integration with TrainController, I decided to experiment with a few signals using MFX. Activating the MFX discovery function resulted in the CS3 reassigning addresses to all my accessory decoders, including the turnouts. Consequently, TrainController no longer recognizes the turnouts, as their addresses have changed.
Now, I'm faced with the daunting task of manually identifying and reprogramming each turnout's address. This process requires two people: one to operate the CS3 and another to observe the physical turnout responses. It's a time-consuming endeavor that will take several days to complete.
While I understand the advantages of MFX's automatic address assignment, this experience has highlighted the importance of cautious use, especially when integrating with external control software like TrainController. In the future, I'll adhere strictly to manual address assignments and avoid using the MFX discovery function to prevent such disruptions.
Thorben
CS3+, Märklin HO
Windows 11 Home
Offline tgj
#4 Posted : 04 May 2025 21:22:52(UTC)
tgj
Originally Posted by: tgj Go to Quoted Post
Hi Thorben
Hi Jean,
Thorben
Hi Jean,
Do you think there is any way to go back after all my turouts have been reprogrammed?
I tried to delete a turnout in cs3, but the turnout still reponded to the mfx assigned address.
Any ideas? Maybe reboot the cs3?
Regards Thorben
CS3+, Märklin HO
Windows 11 Home
#5 Posted : 04 May 2025 21:29:10(UTC)
You make a good point that using other software can cause problems. I just use the CS3 and the decoders register themselves for turnouts etc with no problems.
Running our railways are as simple or as difficult as you want to make it and I just let Marklin work as it should and rarely have a problem. You can expand the hobby using other brands of software which in itself is a hobby and can be an added interest.
Offline tgj
#6 Posted : 04 May 2025 22:14:15(UTC)
tgj
I am sure it works fine for you. The problem is not using other software, but only the'at Märklin have implemented MFX so bad, that it will just overwrite anything that I have set manually. That is BS if you ask me and a serious Märklin software problem.
Regards Thorben
CS3+, Märklin HO
Windows 11 Home
Offline Copenhagen
#7 Posted : 04 May 2025 22:29:43(UTC)
Copenhagen
What if the dip switches on all the devices (where possible) are set to DCC? Would that preclude that the search for mfx articles could change anything on them?
#8 Posted : 04 May 2025 22:50:01(UTC)
Hi Thorben
All the hard work you have done is not lost
Simply when you pushed the "Find MFX Accessory Decoders" the CS3 has registered all you MFX-capable m83 and the result is all MM2 commands are now ignored (not erased)
What you have to do is
EITHER to erase all MFX records made related to these m83 decoders you wish to address in MM2 AND NEVER PUSH AGAIN this "Find MFX Accessory Decoders" key
OR YOU LET ALL WORK USING MFX (erase all MM2 records, reset decoder switches to their factory) and take note of all CS3-assigned MFX addresses
Offline tgj
#9 Posted : 04 May 2025 22:51:40(UTC)
tgj
It's too late. MFX have already reprogammed all turnouts. I got a solution from ChatGPT and it is to delete all the entries that MFX found, then it should go back to the old address. I will try that and let you know the result.
Regards Thorben
CS3+, Märklin HO
Windows 11 Home
Offline tgj
#10 Posted : 05 May 2025 10:37:56(UTC)
tgj
Hi everyone,
Thanks in advance!
— Thorben
Hi everyone,
I've recently encountered an issue that I believe others might find helpful to be aware of.
After initiating a search for MFX items on my Märklin system, I discovered that all my turnouts—previously programmed manually using the Motorola (MM) protocol—had their addresses reassigned automatically. This was quite surprising, as I had meticulously configured over 70 turnouts with specific addresses to integrate seamlessly with TrainController.
It appears that the MFX discovery process overrides existing manual configurations, even those set via DIP switches or CV programming. Consequently, I'm now faced with the task of reprogramming each turnout to restore my layout's functionality.
This experience has been rather frustrating, and I question the system's design in this regard. I hope sharing this will help others avoid similar setbacks.
Thorben
CS3+, Märklin HO
Windows 11 Home
#11 Posted : 05 May 2025 14:24:28(UTC)
As I wrote before I pushed by accident this key BUT by erasing all MFX-created records I could use again the MM2 manual configuration
There is no other to do it as you cannot block the MFX protocol on the m83
Offline tgj
#12 Posted : 05 May 2025 14:34:18(UTC)
tgj
I thought I could do that, but I found out that MFX actually programs the turnouts and you have to reset them to program them again. I deleted all my MFX turnout, but could not accces them from TC as they all had new addresses.
For sure it´s a BAD system.
Regards Thorben
CS3+, Märklin HO
Windows 11 Home
Offline PerR
#13 Posted : 05 May 2025 16:04:25(UTC)
PerR
Hi Thorben.
It is not a bad system.
The only thing wrong is the default behavior when you are searching for mfx articles.
The option selected by default I to let CS3 decide the adresses of the mfx articles.
I recommend always that users are using "Keep the adresses".
With that option CS3 will use the adresses set by the dip switches.
Thorben, have you read my CS3 guide in Danish which is located on digitaltog.dk
Per
thanks 2 users liked this useful post by PerR
Offline tgj
#14 Posted : 05 May 2025 16:07:35(UTC)
tgj
Originally Posted by: PerR Go to Quoted Post
Hi Thorben.
Per
Hej Per
You have to understand, I just wanted to try to add two signals with MFX and then all my turnouts were reprogrammed. That is BAD.
Regards Thorben
CS3+, Märklin HO
Windows 11 Home
#15 Posted : 05 May 2025 17:53:49(UTC)
Hi Thorben.
Per
As you say the system is fine if you use Marklin for which it is intended. I have never tried to change a turnout decoder address but I would have though it should be possible but why would Marklin want to have that faciility. Could be wrong but the old type of decoder was not mfx and perhaps there are still some available.
Maybe the ESU controller would be better for this but I dont know how that works with Marklin mfx.
Offline PerR
#16 Posted : 05 May 2025 20:09:32(UTC)
PerR
Hi Thorben,
the problem is that you did not know how to add a mfx article decoder type m83.
If you have added them one by one with the search for mfx devices, and you have chosen the option "Keep the adresses", then everything have worked perfect, and you had not needed to add all the decoders manually.
But when you have selected the wrong option when searching for mfx articles, you could have changed the adresses in the edit unction for the mfx decoder.
Per
thanks 1 user liked this useful post by PerR
Offline tgj
#17 Posted : 05 May 2025 20:16:47(UTC)
tgj
Hi Thorben,
Per
I do not have any m83 decoders, the problem was that i just wanted to add a couple of signals and i choose to have it give them a new address. I never expected that it would readdress all my turnouts. It did not even give any kind of warning. That is BAD programming. Cursing
Regards Thorben Mad
CS3+, Märklin HO
Windows 11 Home
Offline PerR
#18 Posted : 05 May 2025 22:21:48(UTC)
PerR
Hi Thorben,
it is not BAD programming. The problem is that you did not know the difference of "”Tildeles en ny adresse” and ”Behold sin eksisterende adresse” when searching for new mfx articles.
If you have been reading section 22.3 "Indlæggelse af m83 og m84 (60832 og 60842)" in the following document, you would have known.
Please see this document, which is in danish language: https://www.digitaltog.d...CS3_Information_v252.pdf
Best regards Per
Offline tgj
#19 Posted : 06 May 2025 06:27:04(UTC)
tgj
Hi Thorben,
Best regards Per
Hej Per
Thank you for your input, Per, but I have to disagree with your assessment.
I’m fully aware of the difference between “Behold sin eksisterende adresse” (Keep existing address) and “Tildeles en ny adresse” (Assign new address), and I deliberately selected “Assign new address” because I was adding a new signal configured for mfx with all DIP switches set to OFF, exactly as the manual specifies.
What puzzles me is this: I have already assigned addresses to all my turnouts using Motorola (MM), and as instructed, I ensured that the DIP switches were not set to OFF unless I wanted the decoder to register as mfx. Still, despite the turnouts already having a valid MM address and not being set to OFF, the mfx registration process overrides this and assigns a completely new address.
To me, this behavior seems like a serious flaw in the Märklin software and not a user error. I believe this should be addressed and corrected in a future update.
Thorben
CS3+, Märklin HO
Windows 11 Home
Offline PerR
#20 Posted : 06 May 2025 07:46:53(UTC)
PerR
Hi Thorben,
your response shows me that you are not aware of the difference of “Behold sin eksisterende adresse” (Keep existing address) and “Tildeles en ny adresse” (Assign new address).
When you search for new mfx articles, and you did not do it during the installation of your previous m83s, then both the m83 and the new signals will be new to the CS3, and all of them will get assigned a new address, because you have choosed “Tildeles en ny adresse” (Assign new address).
Therefore my recommendation is to use “Behold sin eksisterende adresse” (Keep existing address) if you are an advanced user, and only use “Tildeles en ny adresse” (Assign new address) if you are a beginner and don't have an idea of the the addresses.
I don't think you should expect any changes in this area, because it works as designed.
Per
Offline tgj
#21 Posted : 06 May 2025 08:16:40(UTC)
tgj
Hi Per,
Thanks again for your response.
However, I think there's been a misunderstanding. I’ve never used any m83 modules in my setup, so I’m not sure why they are being referenced here. My concern is specifically related to signals and turnouts configured via Motorola (MM) and how they interact with mfx registration.
I do understand the difference between “Tildeles en ny adresse” (Assign new address) and “Behold sin eksisterende adresse” (Keep existing address). I chose Assign new address intentionally, because I wanted to register a new mfx signal decoder with DIP switches set to OFF, as the Märklin manual describes.
What I find illogical is that even existing MM devices, which already have defined addresses and are not set to register as mfx (i.e., DIP switches not set to OFF), are still being re-registered by the CS3 and given new mfx addresses — simply because I searched for new mfx devices.
This means that the CS3 seems to treat everything as new mfx hardware, regardless of whether they were clearly already configured and working. That seems like flawed logic to me, especially since it contradicts the idea that MM devices should remain untouched unless explicitly reset.
So, to be very clear:
I never used m83s.
I deliberately assigned MM addresses to all my turnouts.
Only one new mfx signal with DIP OFF was added.
Yet the CS3 reassigned existing devices as if they were mfx too.
To me, this looks like a real issue — not a misunderstanding of the interface, but a design flaw in the mfx discovery logic.
Thorben Jensen
CS3+, Märklin HO
Windows 11 Home
Offline Copenhagen
#22 Posted : 06 May 2025 09:26:21(UTC)
Copenhagen
Isn't the problem that mfx usually overrides mm? (Unless mfx is disabled some way). I asked earlier if DIP switches set to DCC would prevent the cs3 from changing addresses when searching for mfx devices.
Offline PerR
#23 Posted : 06 May 2025 09:26:39(UTC)
PerR
Hi Thorben,
if the addresses of your turnout decoders have changed, then they are for sure mfx capable, no matter if they are controlled by a m83 or a build in decoder. As far as I know, there is no way of turning mfx off for this kind of decoders.
And because you have not used the mfx registration of articles for your turnouts, but defined the turnouts manually, then all your mfx capable article decoders will be threated as new when you are doing the "search for new mfx article decoders".
The "Assign new address" functionality of the search function is meant to be used by beginners, and I don't see you as a beginner, because you have 70 turnouts.
So remember to use "Keep existing address" when doing the search.
Did you read my Guide in danish, which can be found on digitaltog.dk ?
Per
Offline tgj
#24 Posted : 06 May 2025 10:10:01(UTC)
tgj
Hi Thorben,
Per
Hi Per,
Thanks for your reply.
Yes, I now fully understand what happens during the mfx search — and I also understand why it happens. But my point is this: just because something is working “as designed” doesn’t mean it’s logical or user-friendly. In this case, I still believe it’s a design flaw.
I deliberately configured all my turnout decoders manually with MM addresses, and I didn’t expect a later mfx search — meant to register a single new decoder — to override existing setups that were already working and not in mfx registration mode. There should be a smarter way to handle that, especially when existing decoders clearly aren’t “new” and have been manually configured before.
So yes, I know what to do now — use “Keep existing address.” But honestly, it’s not intuitive that one wrong choice could override dozens of existing settings without any clear warning or option to skip previously registered devices.
I appreciate your guide and your willingness to help others, but please also try to see it from the perspective of someone who’s experienced and still finds this behavior illogical.
Thorben Jensen
CS3+, Märklin HO
Windows 11 Home
#25 Posted : 06 May 2025 18:13:27(UTC)
I was certainly under the impression that Thorben has about mfx detection, with an mfx inquiry reporting the address set on the DIP switches, but not changing the address if a non-zero address is set. But a careful peruse of the 74462 manual provides no information at all on how the mfx mode works. It is not clear to me if DCC mode is kept if the switch is set to that mode.
Unfortunately this is the sort of information fog that Marklin provides.
Guest (5)
This page was generated in 0.804 seconds.
