#1 Posted : 10 April 2025 17:22:31(UTC)
I did watched a video in the Youtube about power consumption of the two rail.
It seems nickle silver are sensible when i can see some wear on the surface of the rail.
This happens too for the digital locomotive which also have wear on one side of the wheel where it has contact on the + rail side.
I was surpriced to see the result of the damage on the rail and the wheels.
Is there any one here of the forum who has friends that have rail problems by use two rail tracks?
Online marklinist5999
#2 Posted : 10 April 2025 19:02:56(UTC)
Nope. I used Atlas code 83 track. Been on the same layout module since 1990. I run Hamo SBB croc, RE/420, DB br 03, Fleischamnn ICE-1, 610 pendolino, Piko br 612 regioswinger,
Roco DB br E-08/10, E-91, Br E-103, and various American diesels.
#3 Posted : 10 April 2025 19:51:43(UTC)
Looks nice!
Does your track also have nickle silver on the rail?
#4 Posted : 11 April 2025 00:27:55(UTC)
Yes Goofy. The rails are solid nickel silver and non magnetic 🧲. Unlike Marklin C track.
Offline ocram63_uk
#5 Posted : 11 April 2025 08:18:16(UTC)
ocram63_uk
never heard of this problem on 'at home' layouts. It could possibly happen at huge open to the public layouts where trains travel at least 8 hours a day every day. This is a non problem IMO and YT is full of lies :-)
thanks 2 users liked this useful post by ocram63_uk
#6 Posted : 11 April 2025 11:56:44(UTC)
Not heard of this ever being a problem. Had C track for many years and not as yet seen any wear. As said maybe if you run 8 hours a day every day you will get wear but I doubt anybody on here will be doing that.
Offline dickinsonj
#7 Posted : 12 April 2025 00:46:11(UTC)
Same here - C track since it came out and never any detectable rail wear.
Sounds like some more YT clickbait silliness to me.
#8 Posted : 12 April 2025 11:34:26(UTC)
I did watched this video over again and it was a german Märklin railfan who did present close up pictures of the two rail with extrem macro lenz.
Thanks for the comments and have a nice saterday! Cool
Offline Copenhagen
#9 Posted : 12 April 2025 16:50:02(UTC)
Copenhagen
Why not put a link to the video?
thanks 2 users liked this useful post by Copenhagen
#10 Posted : 13 April 2025 09:37:29(UTC)
Okey!
www.youtube.com/watch?v=eaYBl2D3nJs
Offline Copenhagen
#11 Posted : 13 April 2025 17:48:31(UTC)
Copenhagen
Thanks for posting the link. The video is mostly about different wheel nem norms and the difference between AC and DC wheels. Wear and tear is just briefly mentioned towards the end in the Radreinigung (wheel cleaning) chapter. There is one picture of new and old wheel surfaces that doesn't really show how much material has been worn off. And then there is another picture where he has grinded or sanded (angeschliffen) the surfaces of a wheel and of a piece of track to show the underlying metal.
thanks 3 users liked this useful post by Copenhagen
#12 Posted : 17 April 2025 20:11:50(UTC)
The video shows damage on the rail that tells difference dc and ac.
Märklin use rail as a return line which does not wear out in the same way as a feed line.
It is power consumption that causes wear on the surface of the rails due to metal contacts from the locomotives and carriages with lighting.
The more locomotives and carriages that are on the rails, the more wear there is on the surface of the rails.
That is what wears down the rails and where is dust and other dirt, it gets worse.
I decides to stop use two rail system.
Offline Copenhagen
#13 Posted : 18 April 2025 00:28:47(UTC)
Copenhagen
With all respect: Goofy wrong.
#14 Posted : 18 April 2025 09:20:27(UTC)
Wear and tear are result when the metal have contact with the power consumption.
In fact does even this happens with Märklin tracks too but in this case stud contacts.
Two rail are more sensible cause of the nickle silver and depends how much power consumption you use on the tracks.
That´s way people recommended you to clean the tracks and the wheels.
I found on my two rail Tillig elite code 83 some wear and tear on top of the rail.
User is suspended until 01/09/2107 13:55:52(UTC) Vinedusk
#15 Posted : 18 April 2025 09:52:38(UTC)
Vinedusk
I've read many posts on 'track-cleaning' over the years. Whilst the topic here is different, I arrived at one conclusion.
Marklin (and other manufacturers) probably do more research on this issue than any of us possibly can do.
I'm happy to accept that Marklin's C-track will provide the 'optimum' solution with respect to wear; and to cleaning. It might need to be 'wiped-down' occasionally. If it wears out, then replace it.
If we're looking at 'wear and tear' here, nothing lasts for ever, if it's used.
It's always amusing to see ebay sellers (and others) showing the slider in their photos as an example of 'use'.
It's easy enough to put in a new slider...
I don't think Goofy is 'wrong' - but it really is a moot point. We're talking consumables here and track ends up being 'consumable'.
Are our modern-day trains still running on track laid 100 years ago? Think about it...
Fine, young, Tweed salseman that y'are
Offline Copenhagen
#16 Posted : 18 April 2025 13:01:11(UTC)
Copenhagen
As I see it the video isn't about wear and tear. The picture of the top layer of metal gone and exposing the underlying metal is because the maker of the video has manually ground the surface of a wheel and of a piece of track.
I don't recall seeing posts or videos from "DC" users complaining about wear on wheels and tracks. I have found, by searching, that Miniatur Wunderland is replacing (or has replaced) lots of K track in favor of two wire. Link: https://www.miniatur-wun...jetzt-fliegt-alles-raus/
And that they also use (or have used) several track systems: https://www.miniatur-wun...l-railway/track-systems/
Edited by user 18 April 2025 17:26:39(UTC)  | Reason: Spell correction
#17 Posted : 21 April 2025 21:42:03(UTC)
Maybe Goofy knows more about wear on tracks than Miniatur Wunderland - after all, he has seen a video on Youtube LOL
P.S: Serious wear on two rail track:
wear
thanks 5 users liked this useful post by Purellum
#18 Posted : 22 April 2025 13:33:24(UTC)
Ooowwhh correct 💯 Per. If one thinks for a moment, the total trackage of a small layout gets ran on more in less time. So even running several trains at once, given the size of an exhibit like M.W.L., which has several different routes, it's still less.
Remembering when my layout was smaller, I had to clean the tracks more often from the traction tire residue and black dirt.
#19 Posted : 26 April 2025 15:53:43(UTC)
I did photo a track name Tillig elite.
When i did bought the track the top of the rail was brownish like side of the rail.
After few hours used you can see that the top of the rail has become more glossier.
This is what it happens when you supply voltage and power consumption.
Have a nice day!
Offline Bent
#20 Posted : 26 April 2025 16:42:03(UTC)
Bent
Besides the angle the two photos is taken, I can’t see any difference!
Could You mark the areas to compare please?
Bent
thanks 1 user liked this useful post by Bent
#21 Posted : 26 April 2025 20:24:16(UTC)
Exactly the same thing happens in our live steam club, where no electricity is involved: https://www.facebook.com/groups/205373204638300
Just as it has always been since the first real train ran on steel track in 1825 - without any power coming from the tracks.
Offline dickinsonj
#22 Posted : 26 April 2025 21:13:43(UTC)
I agree on the rail wear Per, no electrical charge is required.
Thanks for posting that picture btw, which inspired me to check out the Western Maryland 1309, which I was not aware of. I think I really need to visit them, since it is only 285 km from my front door! Even better I can take a dinner cruise in a heritage dining car through the beautiful mountain scenery. ThumpUp
Offline Copenhagen
#23 Posted : 26 April 2025 23:27:38(UTC)
Copenhagen
I saw a youtube video originally from a television broadcast about maintenance on a Danish railway track with heavy traffic. There was a German crew with specialised equipment not only grinding the track but actually milling it where needed because af cracks and irregularities (like small chunks of surface metal missing). Without maintenance the track would deteriorate faster. This had nothing to do with electricity (and two rail...) but just a result of the ordinary traffic.
Offline mvd71
#24 Posted : 27 April 2025 00:36:07(UTC)
I can’t believe this thread is still going!
1. track wears when trains run.
2. damage to rail can occur when electricity is fed through it, pitting from electricity occurs when excess current is going through the track. This can happen when idiots build high power boosters capable of delivering high current. Then they get arcing, followed by pitting. Really simple.
Offline Copenhagen
#25 Posted : 27 April 2025 09:10:42(UTC)
Copenhagen
To stay in the jargon: is it fair to say that the discussion was off track from the beginning?
#26 Posted : 27 April 2025 12:36:14(UTC)
I cant think why but I just looked at my C track to see if it had any wear. Funny how some threads on here make you do odd things.
thanks 4 users liked this useful post by David Dewar
OceanSpiders 2.0
This page was generated in 0.822 seconds.
