Offline Luna
#1 Posted : 27 April 2025 05:02:03(UTC)
Luna
Hello fellow modelers, I am trying to figure out a way to use M signals on my digital C track layout.Due to the facy that I need a large amount of signals in my yard I was wishing to be able to hook up M signals to be able to save a good amount of money. As you all know m signals are a fraction of the cost of the new MFX signals. I just want them to light up, not control traffic. Kind of like platform lights or street lamps. The M signal I purchased to experiment with has 5 wires, I just need something like a red and brown wire to get it to light up. Can any of you more experienced modelers give me an idea of how this could be done?
Thanks in advance
Luna
Offline mvd71
#2 Posted : 27 April 2025 09:51:39(UTC)
This can be done easily enough, but it would help if you post a picture of the signal so the we can identify the correct one and give the right advice.
Cheers…
#3 Posted : 27 April 2025 13:22:55(UTC)
Hi Luna
This is exactly what I did on my C-Track layout.
Electrical aspect
- signals can be driven directly using a M83 (60832)
- their contacts can be used to power ON / OFF the stop section in front of the signal
- the bulbs could be replaced with LED M4 Fassung. That way, they never burn anymore and urrent need is sharply reduced
Prototypical aspect
- they are quite good except the huge motor casing
- one solution is to cut a rectangular hole in the plywood base and make an adaptation so that the top of the casing comes flush with the upper plywood surface
Here is what it looks like on my layout
Offline Luna
#4 Posted : 27 April 2025 17:52:51(UTC)
Luna
Jean & Mike thanks for the quick reply. The M signal I have is #7039, It has a red and blue wire and separate a red, blue and yellow wire. If I just want to use the signal as an adornment, not to stop train traffic which of those 5 wires do I hook up to get the signal to light up? It would be easiest if the signal could just be connected to my light transformer instead of an M83 or M84.
Thanks again in advance,
Luna
#5 Posted : 27 April 2025 18:09:24(UTC)
Hi Luna
These are one-wing semaphores.
To light up the signal just connect the yellow wire with yellow plug to the yellow plug of the Märklin transformer and the ground wire (brown, that YOU ?must provide) between to female plug on the signal and the brown female plug on the transformer.
Often, with M track, the metal base of the signal would provide the signal with the ground by the M Track metal bed.
To change the signal to the position you like, use one of the blue cablle and connect it shortly with the ground
Offline Luna
#6 Posted : 27 April 2025 18:36:31(UTC)
Luna
Thanks Jean, now how do I provide the brown wire? The amount I could save as opposed to buying MFX signals is astronomical.
Luna
#7 Posted : 28 April 2025 09:56:10(UTC)
Hi Luna
Not sure I understand your concern.
You need TWO wires to light up the signal
- one is by connecting the YELLOW wire from the signal to the 16 VAC Transformer
- You need to ground the signal by connecting it to the other 16 VAC (return) plug. Märklinists usually use brown wire. Is this so exhorbitant?
Offline Luna
#8 Posted : 28 April 2025 10:52:00(UTC)
Luna
Jean again thanks for the reply. The problem I’m having is the signal has 5 wires. 1 is yellow, the others are either red or blue. In other words no brown wire for the ground. I don’t think any of the blue or red wires will work as a ground. I did touch the blue wire to the transformer and the semaphore moved a bit, however no light.
Luna
#9 Posted : 28 April 2025 12:05:26(UTC)
Yes the signal has also 2 red wires (traction current switch), 2 blue wires to drive the solenoids
One yellow wire to power all the signal
There is NO brown wire as in those days with Marklin M track the ground return was provided by the signal s base plate
Since you use C track you have to plug a brown plug into the signals front socket and wire it to the trafos brown socket
Edited by user 28 April 2025 23:29:53(UTC)  | Reason: Not specified
Offline Luna
#10 Posted : 29 April 2025 04:53:22(UTC)
Luna
Jean thank you so much! I got the signal to light up which is all I wanted to do. You just saved me a boatload of money. I can get M signals on Catawiki for about 4 or 5 M signals for the price of 1 MFX signal. I attached a ground wire into the front connection and light! Again thank you.
Luna
thanks 1 user liked this useful post by Luna
Offline HO Collector
#11 Posted : 29 April 2025 20:14:20(UTC)
HO Collector
Electrical aspect
Don't you lose the digital control/memory of the engines?
#12 Posted : 30 April 2025 12:10:56(UTC)
Hi (no first name)
Originally Posted by: HO Collector Go to Quoted Post
Electrical aspect
Yes you are right but, in digital and using Rocrail or equivalent, there is no need to have insulated (stop) section so less wiring and better control of locos (speed fonctions, etc)
of course headlights smoke, sound continue working
This is what I use and it works extremely well
Offline Martti Mäntylä
#13 Posted : 30 April 2025 19:09:49(UTC)
Martti Mäntylä
In my case, I run also analog locomotives, so I need the stop sections for my old-school signals. Nevertheless, with Rocrail controlling the deceleration of digital locos, they generally stop at the contact tracks placed in front of the stop sections, so they never experience the loss of track power.
Edited by user 01 May 2025 09:54:18(UTC)  | Reason: Not specified
- Martti M.
