Offline mvd71
#1 Posted : 19 April 2025 07:37:54(UTC)
Hi Guys,
Trying to finish an old project, and I have a BR111 that I have fitted the 60973 pick up shoe change over board.
I also wanted to fit the Märklin buffer capacitor, but it uses the SUSI port normally and the 60973 doesn’t have a SUSI port.
Can anyone supply a diagram showing where I can connect the individual wires to bypass the SUSI connection?
Cheers…..
Offline bph
#2 Posted : 19 April 2025 11:00:12(UTC)
Here is a picture of the 60974 wired up to the 60973 (my own work, so no guarantees given ;)
https://hovland.net/bilder/mj/60973.jpg
And if needed, a layout of the SUSI plug in relation to the MTC21 on the mSD3/mLD3
Maerklin_21_pin_MTC_mSD3_mLD3_layout_and_wire_colors.pdf (also my own work, so again no guarantees given ;)
Offline mvd71
#3 Posted : 19 April 2025 11:16:37(UTC)
Fantastic! Thank you, you’ve made my day.
Cheers…..
Offline mvd71
#4 Posted : 19 April 2025 11:59:35(UTC)
All wired up as per your photo. Checked decoder settings and then gave it a test run. Worked great in terms of stopping the loco from stalling ThumpUp
However, in my particular train, I have three Roco S Bahn coaches that are connected to the loco, and in the cab opposite the loco, I have a Lokpilot fx which is set to the same address as the loco decoder. This decoder controls the cab lighting and the passenger car lighting. And the passenger car lighting is activated by f3. When I activate it, the loco speed also drops. Any ideas as to why??
Cheers…..
Offline mvd71
#5 Posted : 19 April 2025 12:23:58(UTC)
Moved the interior lights to F2 on the function decoder and appears all good.
Offline bph
#6 Posted : 19 April 2025 15:33:57(UTC)
Normally Aux3 and 4 need to be always on, in forward/ rewerse mode ref manual, so it's sensible not to combine those with other functions. (On my mSD3, I used logic on the aux 3 and 4. So I can "lock" the relay in one position and only use one pickup shoe).
A little tip is that if you don't need the chassis/ground to be switched, you can bypass the relay and use the 0/GL pad next to the 3 GND solder pads.
Offline mvd71
#7 Posted : 19 April 2025 21:28:27(UTC)
When you say bypass the relay, do you mean that normally it switches both the slider and chassis?
Could you please clarify?
Offline bph
#8 Posted : 19 April 2025 23:54:10(UTC)
It's just a minor thing, but yes, there is a relay on the chassis connections as well. ref the relay diagram on the board and the manual. And using the alternative chassis solder pad bypasses the relay.
Offline mvd71
#9 Posted : 20 April 2025 10:21:22(UTC)
Ok, I’ll give it a try. Thanks for all your help. Hopefully I’ll get to a point I can post a picture of the finished item!
Offline mario54i
#10 Posted : 20 April 2025 12:00:02(UTC)
mario54i
Maybe F3 sets shunting speed
This page was generated in 0.300 seconds.
