Offline Donb
#1 Posted : 19 March 2025 04:03:34(UTC)
Donb
I just bought this nice Controll cab coach, and it registered in mfx no problem and the three light functions( F0, coupling, interior and cab) work fine.
However, the headlights do not switch when direction is reversed. They remain red all the time regardless of direction of travel.
Looking at the bogies, I don't see the typical flip switch I am used to seeing on these control cab coaches from the past.
There appears to be only two ground plates and of course a slider.
I'll post a photo soon.
How does the headlight direction switching function work now?
Best Regards,
Don
TFT ECOS, C track and Z scale, mostly DB/DR and SBB, SJ
thanks 1 user liked this useful post by Donb
#2 Posted : 19 March 2025 05:24:24(UTC)
From what I could tell from the manual, the coach has a built in decoder with the following functions:
F0: 3 White lights or 2 red taillights controlled by decoder direction change
F1: Activates power supply via current conducting coupler (for other coaches) (on/off)
F2: Interior lights (on/off)
F3: Cab lighting (on/off)
MFX Address: BDylf 457 DB
DCC Address: 03
MM Address: 68
Preset to MFX>DCC>MM
Offline Donb
#3 Posted : 19 March 2025 05:49:41(UTC)
Donb
DCC Address: 03
MM Address: 68
Thanks, Mike! That solved the problem for me. It doesn't say 'decoder ' direction change in my manual, I missed the obvious!
Don
Best Regards,
Don
This page was generated in 0.376 seconds.
