Offline Mjn2ts
#1 Posted : 17 March 2025 20:11:49(UTC)
Mjn2ts
I’m currently upgrading an analog loco to digital and upgrade the lights to leds. If I’m using a a Marklin e276770 socket and a e600080 led, do I still need a resistor and if so, how big and on which wire does it go on?
Thanks Jeff
#2 Posted : 17 March 2025 20:26:52(UTC)
e600080 is a light bulb and no resistor is needed for this light bulb.
You should dim the light in the decoder settings to reduce heat.
Better get e610080 light bulbs when going digital.
Offline Mjn2ts
#3 Posted : 17 March 2025 20:32:55(UTC)
Mjn2ts
Thanks, now it makes sense that they didn’t flicker when I tested them…
thanks 1 user liked this useful post by Mjn2ts
This page was generated in 0.269 seconds.
