#1 Posted : 22 February 2025 11:05:51(UTC)
Views messages in topic : 14,907
Hi, over the years Roco had always a functional pantograph but lately their new locos have abandoned any electrical contact., its a shame and contradictive as the models become more and more detailed including the pantograph but to have an authentic operation isn't available., the other thing I've noticed spare parts aren't as available as they used to be, ordered a electronic circuit board and its not available and this is for a new item loco., I think off hand its only Märklin that has kept up the use of a pantograph for operational purposes., by the way had an answer from Märklin regarding my request for an axle with rubber tyres and they'll look into it if they can supply me with one, (not available on their website)
#2 Posted : 22 February 2025 15:11:59(UTC)
Well John, Roco has followed the others with aesthetic only panto's. Marklin's reasoning was better digital MFX conductivity with rails, but I'm sure it was also a cost saving mneasure.
thanks 3 users liked this useful post by marklinist5999
Offline dickinsonj
#3 Posted : 22 February 2025 19:21:20(UTC)
All true. Fidelity to the prototype has been getting more important also, and non-functional pantographs can be made to look more realistic.
#4 Posted : 22 February 2025 20:37:47(UTC)
Since the introduction of the ESU type decoder, there has been concern expressed that intermittent contact which is more likely with catenary operation can result in a few negative outcomes.
Firstly, due to the constant voltage of digital operations, it can result in the following:
1) On AC layouts, it can prompt a sudden reversal of direction
2) On AC and DC digital layouts, it can push the locomotive into programming mode, leading to an unexpected and sudden stop
3) On some models, the digital voltage has led to overheating and fire on the cable/lead between the pantographs and circuit board
Secondly, a number of models have appeared with digital functions (operating pantograph, etc) and this would not be possible if the catenary was functional.
For example, if you had the loco powered from the catenary and you commanded the pantograph to drop, how would you get it to rise again?
That said, have a good weekend
Never mind the fact that the sparks from the catenary was one of the coolest things I ever saw on model trains
thanks 6 users liked this useful post by mike c
Offline mvd71
#5 Posted : 23 February 2025 05:39:42(UTC)
I still plan to run my electric locos from the catenary. Hopefully I get away with it.
thanks 4 users liked this useful post by mvd71
Offline Paul59
#6 Posted : 23 February 2025 09:29:03(UTC)
Paul59
When I used to run digital all my electric locos picked up from the catenary. Most had ESU decoders as I had converted them from analogue. There were no problems at all and it seemed just as reliable as the steam/diesel locos that picked up from the track. Those decoders were all Lokpilot 4. Maybe the more modern decoders are more fussy. Obviously there was no real reason with digital to have a live catenary but, to my mind, it just seemed wrong not to use it.
Now that I have converted completely back to analogue a working catenary makes things much more flexible as electric locos can be controlled separately.
I must add that I never used any locos with the modern delicate "break just by looking at them" pantographs.
Paul
thanks 5 users liked this useful post by Paul59
Offline Michael4
#7 Posted : 23 February 2025 11:54:20(UTC)
Michael4
Using 'old' catenary on M track I find that a catenary circuit requires fewer power point than the same length of track. In my simple analogue mind this suggests that its conductivity is better and that unlike pukos it doesn't get dirty.
However rusty catenary can be preferable, it helps create sparks!
thanks 6 users liked this useful post by Michael4
Offline Paul59
#8 Posted : 23 February 2025 17:34:35(UTC)
Paul59
I would agree with you Michael regarding the conductivity of catenary circuits being very good and possibly better than the track.
A few sparks from the pantographs look great too!
Paul
thanks 7 users liked this useful post by Paul59
Offline analogmike
#9 Posted : 23 February 2025 22:24:19(UTC)
analogmike
Yeah, And our sparks are real!Flapper
thanks 3 users liked this useful post by analogmike
#10 Posted : 25 February 2025 06:27:19(UTC)
Yes and this are also worse for two rail when you have reverse loop. In fact you destroy decoder. To use power feed via pantograph works better with analog power. Even Märklin recommended analog power feed and decoder stand in ac analog protocol.
#11 Posted : 25 February 2025 14:46:38(UTC)
At my age, sparks are dangerous haha! Also not the greatest for decoders.
#12 Posted : 10 March 2025 09:30:54(UTC)
I would like to know who instigated this myth, in my time over 40 years whereas I have used the pantograph as a power supply I never experienced this, the only thing I remember that the loco reversed itself (6021) was a software problem, the only other thing I've experienced is the loss of a digital signal when the pantograph lost its contact with the overhead wire (rarely)
#13 Posted : 10 March 2025 09:32:36(UTC)
you shouldn't have any problems at all
#14 Posted : 10 March 2025 09:36:17(UTC)
Never had any sparks on my overhead system unless you're voltage is so high or there is a major short somewhere without you noticing it
#15 Posted : 10 March 2025 20:09:16(UTC)
I have never burnt a decoder by using the catenary, but I have had at least two occasions where the catenary did trip a locomotive into programming mode (Maerklin ESU OEM) after a momentary loss of contact. The end result was a sudden stop of the train, followed by no movement and flashing lights. There was no accident as it was the only train on the track at the time. Imagine if there would have been a second train following that would have crashed into the rear of the now stationary one. The train was operating on a floor layout made up of then 30 year old M track and the classic Maerklin catenary.
This page was generated in 0.554 seconds.
