#1 Posted : 19 February 2025 04:58:06(UTC)
Hi everyone,
I'm encountering a some troubles with LED passenger car lighting, and can use some expert help.
I am installing a few of the Schonwitz lighting strips: https://modellbau-schoen...beleuchtung-gelb-h0-n-tt
I am putting on a buffer capacitor to avoid flickering. (with 100ohm resistor to limit inrush) I used a 470uF capacitor (25v) and was surprised to find that the light strip almost immediately dims to zero upon a power cut. This is on the test bench. While it doesn't "flicker" - it also doesn't do a good job of keeping the lights on for a second, nevermind two. It just rapidly fades instead of flickers.
After much confusion, I tried out a 2200uF, 35v capacitor - just because I had it on hand as a comparison. Similar results! (maybe a touch slower, but still not what I would expect)
I thought I would turn to the experts: any ideas what might be wrong? I have tried 2x light strips and 2x capacitors of each size, and the same results across all cases.
Or am I overthinking this, and once installed they will be fine? Or maybe the strips draw some massive amount of power? (it says 100mA at the midpoint, which isn't crazy?) Attached are images of the strip with large capacitor for reference.
Thanks in advance!
Offline DasBert33
#2 Posted : 19 February 2025 07:42:26(UTC)
DasBert33
You say you use a resistor to limit inrush current. You are also using a diode in parallel to not limit the 'outrush' current? Have you calculated the RC timevalue? Maybe the cap needs a longer time to charge. It can be checked by measuring the voltage across the cap terminals.
thanks 4 users liked this useful post by DasBert33
Offline osoraku
#3 Posted : 19 February 2025 11:45:09(UTC)
osoraku
Dear All -
I am no wizard circuit designer (so this might be wrong), but if I remember my physics correctly, then the capacitance F required to run an average current I for s seconds at voltage V would be:
F = (I * s) / V ,
so for your values and a guess of about 10 V, I'd get
F = (0.1 A * 1 s) / 10 V = 0.01 Farad.
Your capacitor is 0.0022 Farads, so it is a bit small to carry the required charge. Using a lower current LED strip (10 mA perhaps, but dimmer lights) would make your solution work.
Osoraku
thanks 3 users liked this useful post by osoraku
#4 Posted : 19 February 2025 15:34:05(UTC)
It is confusing for me as well. Capacitance=storing current, resistance=choking current.
#5 Posted : 19 February 2025 17:13:05(UTC)
That sounds an awful lot of current for a strip of LEDs like that. It must be like the sun shining in the coach with that much current.
Offline BenP
#6 Posted : 19 February 2025 19:34:48(UTC)
BenP
Did you make sure the diode is in the right way. Parallel with resistor and current flow blocking when loading capacitor (so current flow open when using capacitor).
Offline cintrans
#7 Posted : 20 February 2025 00:27:32(UTC)
cintrans
Aruba
I am using similar Viesman strips (but with the rectifier and pot meter cut off) or the LED strips "on the roll" in my coaches.
I feed them via a separate rectifier, have a 10K resistor in line and a 470 uf , 25V in the DC section.
Light stays on and dims out after 2 ~ 3 seconds.... so 470 uf works!
Try with a higher value resistor and see what that does...
Jean-Pierre
#8 Posted : 20 February 2025 04:58:19(UTC)
Thank you all for your suggestions!
I did more experimentation tonight. Some actual readings from my multimeter:
Input voltage: 16v AC (digital)
Rectified voltage: 16v DC
Full strip has 8 LEDs
Each LED has its own 1201 (1.2k ohm) SMD resistor, so they can be broken off individually
Voltage at LEDs: 2.46v (Lets say 3v)
So if my formula is correct I have 3v/1200ohms = 0.0025ma times 8 LEDs = .02A = 20 milliamps?
#9 Posted : 20 February 2025 05:05:42(UTC)
This is indeed correct. (but a good guess) And to eliminate a variable I've tested without diode/resistor and got the same results.
#10 Posted : 20 February 2025 07:22:58(UTC)
Problem solved! Lack of instructions + operator error was the issue. In brief, the capacitor needed to connect to the first set of + &- pads before the dimmer pot, which had the full 16v, and does not work with any subsequent sets of these pads, which only have 2.5.
For others considering the schonwitz lighting strips: 470uF works, but is not quite enough in my opinion. I would go a little larger if ordering all over again. 2200uf was laughably too much! :) No surprise at all, but it was fun to try it now that I know the correct hookup.
thank you all for your kind responses!
Offline LeoArietis
#11 Posted : 20 February 2025 09:39:26(UTC)
LeoArietis
Connect two 470 µF in parallel if one is not enough.
Current layout:
The former project:
thanks 2 users liked this useful post by LeoArietis
#12 Posted : 21 February 2025 05:48:15(UTC)
Good thinking. I have an excess of 330uF caps, and a pair of those should be about perfect ThumpUp
This page was generated in 0.436 seconds.
