Offline Luna
#1 Posted : 14 February 2025 15:50:27(UTC)
Luna
I am going to install some S88 decoders on my layout and would like to have them closer to the actual contact tracks instead of using a 25 foot long piece of contact track wire. What cable is used to attach the s88 to the L88? Is it a RJ5 cable?
Thanks in advance,
Luna
Offline rbw993
#2 Posted : 14 February 2025 19:37:49(UTC)
rbw993
Hi Luna,
I compared non Marklin 6 pin cable to the blue Marklin ones and they look the same. I do know from the manual that the Marklin cables are shielded to prevent interference. I don't know if all RJ45's are.
regards,
Roger
Offline rbw993
#3 Posted : 14 February 2025 19:43:00(UTC)
rbw993
I think you would need a cat 6 cable as that is required if power is being routed through the cable.
Offline Kiko
#4 Posted : 16 February 2025 03:15:34(UTC)
Kiko
Hello Luna,
I have all my s88 modules together as close as possible to my command station. I use long runs (some over 30 feet) from all my contact tracks to these s88 modules. These single wires from contact tracks are just "open" or "GND" levels with not much chance of RF interference. I use either single 22 AWG wires or CAT 6 cables. I have used this system for over 25 years with no problems. Using CAT 6 cable is very inexpensive -- you can connect up to 8 contact tracks to one cable, and buying a few 100 foot rolls or even a 1000 ft bulk pack is the way to go.
The actual problems of interference that can occur is in the length of ribbon cable between various s88 decoders and the ribbon cable from the last s88 to the command station. Those are the critical lengths which you want to minimize.
Or... go with the newer s88-N standard, which connects s88 modules via Ethernet cables and does away with flat ribbon cables altogether.
Just some suggestions based on experience.
Andry
thanks 1 user liked this useful post by Kiko
#5 Posted : 16 February 2025 15:19:15(UTC)
Glad I got a CS3+ because the network cable plugs into it. Each S-88 decoder comes with a cable to connect them together.
Offline rbw993
#6 Posted : 18 February 2025 19:14:30(UTC)
rbw993
That's not the issue. The issue is using longer cables than the stock 3' (1m) ones that come with the S88's so that they can be set up close to the feedback track locations.
Offline Kiko
#7 Posted : 18 February 2025 19:33:25(UTC)
Kiko
If you really want to run longer cables to the command station and use short wires from feedback tracks to your s88 modules, then you'll need to switch to the s88-N standard. However, you can avoid this expense if you follow suggestions in my previous post...
Andry
Andry
Offline rbw993
#8 Posted : 18 February 2025 22:55:15(UTC)
rbw993
My L88 and S88's all use the S88-N RJ-45 cables to interconnect. I have never seen a Marklin statement, pro or con, about using longer cables than they supply.
Offline Luna
#9 Posted : 19 February 2025 00:02:28(UTC)
Luna
I tried a 25ft RJ45 cable and it seems to be working fine. Seems like there is no limit to the length of cable that can be used.
thanks 2 users liked this useful post by Luna
This page was generated in 0.458 seconds.
