Offline fabstar68
#1 Posted : 11 February 2025 20:48:24(UTC)
fabstar68
hi all, i have a wired distant signal (4 wires for the 2 green and 2 red lights, plus the common wire, viessmann 4030), and i am getting mad in order for it to function properly with rocrail. i tried everything i could, but something is always off. it seems to only change one light at a time, so there is no way to switch from 2 yellow lights to 2 green lights. i have wired it to a basic signal decoder (ldt 8x2), basically i have 2 addresses and each of them is like a 2 aspect signals, in fact i control all my basic 2 aspect signals with those decoders. so i thought that by just defining a distant signal in rocrail (which seems to have been properly created, it reports 3 aspects), and putting the 2 addresses in the interface section (red:address1-red, green: address 1-green, yellow:address 2-red, and also white:address 2-green, even if white is clearly not used as an aspect). I did this type of configuration for marklin 24624, and it's ok with it. but no. Please help, i tried to look at the documentation and in the forum, but i cannot find any help. thanks
#2 Posted : 11 February 2025 23:30:09(UTC)
Hi Fab
With Rocrail one possibility is:
- to use a 60842 (a set of four relays) operated by digital orders. You need one of the four relays to control the distant signal
- you declare this "signal by giving it a name, an address, a protocol and if multiple central stations, indicating which one controls it
- in a Block in the SIGNAL TAB, you may give the name of the main signal and also the name of the forsignal
- when Rocrail sets the block to green it will set both the main signal and the advance signal to green-green
About the Viessmann 4030
- it is a distant lDB Light signal using LEDs, with a common wire ( a diode to the +16 VDC power supply)
- you have 2 wires with resistors for the green LEDs and two wires with resistors for the redLEDs
- you must wire both RED LED resistors tpogether and apply a O VDC controlled by you M84 (60842) RED output
- you must wire both GREEN LED resistors tpogether and apply a O VDC controlled by you M84 (60842) GREEN output
- you must connect the middle output (switch over) to the ground of your DC supply.
Offline PeFu
#3 Posted : 11 February 2025 23:37:12(UTC)
PeFu
I also use the LDT 8x2, but let the distant and main signals share decoder outputs, in order to limit the number of outputs required, and simplify PC software programming.
Offline fabstar68
#4 Posted : 12 February 2025 08:33:15(UTC)
fabstar68
thx, i also found another solution : i do not compile the interface tab of the distant, i created 2 dummy block signals interfaced to the ldt where the distant is connected, and then i created 4 actions to set those 2 block signals green and red, and lastly in the distant actions tab i set, for each state green red yellow, the call to the proper set of 2 actions that set the distant leds accordingly. i just was hoping that there was a faster way.
This page was generated in 0.228 seconds.
