Offline WC Model Railroad
#1 Posted : 10 February 2025 22:44:36(UTC)
WC Model Railroad
Does the Marklin Mobile Station WLAN (60667) have a physical factory reset. Like a button sequence on boot-up. I can't seem to connect to my WiFi anymore it just freezes after clicking the checkmark button after putting in my password. Did some soft resets using the menu and that has not resolved the issue.
FYI - the unit has been working fine since I bought it a few months back and I haven't changed anything so not sure why it started acting funny.
#2 Posted : 11 February 2025 00:12:31(UTC)
Don't forget it could be the other end of the link is the problem.
#3 Posted : 11 February 2025 01:28:01(UTC)
WC Model Railroad
I currently use a CS/3 Plus and it's connected to my network and I can access it through the web URL on my PC so that side is working. My WiFi is up and running as I have multiple types of hardware connected to it.
I tried the AP Setup on the MS and I was able to talk to it from my PC, but when I setup the wireless it just locks up.
#4 Posted : 11 February 2025 06:22:26(UTC)
Could be problem with the box too. Try to shut the power off both the box and the WLAN at the same time and wait about two minutes to switch on the power again.
Offline franciscohg
#5 Posted : 11 February 2025 11:58:25(UTC)
franciscohg
Chile
No box needed when you use a CS3 and a router.
Had a similar trouble a while ago, one night without batteries and then it runs fine again.
#6 Posted : 11 February 2025 12:42:28(UTC)
WLAN report if the battery are weak.
#7 Posted : 11 February 2025 15:52:21(UTC)
WC Model Railroad
Quick Update: I did leave the batteries out overnight and replaced the batteries with new ones (the originals were still good). The issue still exists.
I know that the wireless radio works as I can connect to the MS WLAN while it's in AP mode.
Seems like an OS issue which is why I'm trying to do a factory reset on it.
#8 Posted : 12 February 2025 06:37:46(UTC)
Have you check at CS3 system settings and see if there are communication between CS3 and MS WLAN?
If you have the box too at home try with it and not with the CS3.
Your MS WLAN seems have problem.
Märklin digital system MS2 and MS WLAN are sometimes troublemaker.
#9 Posted : 17 February 2025 04:28:21(UTC)
WC Model Railroad
I finally resolved the issue with my MS WLAN. I remember a few weeks back I did an update on my Asus AP and I ended up enabling Tri-band smart connect. Today I decided to revert this back to the original dual-band connect and bingo I was able to connect with no issues.
Strange issue - perhaps the MS WLAN did not like the additional channels on the 5 gHz band created by enabling tri-band.
I appreciate all the help here!
-Matt
thanks 3 users liked this useful post by WC Model Railroad
This page was generated in 0.365 seconds.
