Offline Raimund
#1 Posted : 08 February 2025 16:44:47(UTC)
Raimund
I just updated to the most recent version of the CS3 software, and now can no longer edit events using the browser interface. Any help is greatly appreciated…NVM… you can’t edit events or track layout in 2.5.2..sigh
Edited by user 08 February 2025 21:04:15(UTC)  | Reason: Not specified
Offline NewComix
#2 Posted : 09 February 2025 22:22:38(UTC)
NewComix
Hi Raimund,
current version of CS3 does not support editing via the browser interface, but using VNC supports editing events.
kind regards
Jörg
Offline rhfil
#3 Posted : 10 February 2025 02:31:13(UTC)
rhfil
As far as I remember the web browser did not give access to events. The latest upgrade though did provide access to a free RealVNC which does. Marklin Dudes did an instructional video on how to access the free app. However they failed to provide clear instructions on the first steps. You first need to connect your CS3 to the internet. Then enter the ip address of the CS3 into a pc which also is connected to the internet. That willbring up some options on the internet tab of your CS3. Then follow their instructions.
Offline bph
#4 Posted : 10 February 2025 12:03:38(UTC)
One tip, the newest VNC-Viewer versions require an account to use it, even if it's free.
However, a slightly older version (6.22.x) doesn't require an account, the sign-in is optional.
So if you only using VNC for the CS3 on a closed network, it might be an option.
This page was generated in 0.462 seconds.
