Offline Mailme
#1 Posted : 29 January 2025 08:47:42(UTC)
Mailme
Hi, I am trying to pick the best colour match for ballast to use with c track. I have been told there are some really good ones. The only one I have identified is Noch #91254. If you can recommend a better colour match I will be very grateful. I usually have to order blind on the web, usually Germany, as my local model shops mainly cater for Horby/Peco tracks.
Thanks …..Tony
Offline Drongo
#2 Posted : 29 January 2025 10:26:43(UTC)
Drongo
Thanks …..Tony
Hi Tony, I bought some acrylic colour paints and blended them so that matched the track ballast. Unfortunately I didn't record the formula, so when it runs out, it's back to the drawing board.
Greg
Offline revmox
#3 Posted : 29 January 2025 10:42:24(UTC)
revmox
Hi Tony,
I've been down this path and even contacted Marklin to try to find out the correct C-track ballast colour. Marklin support told me "The plastic bedding of our C-track is mixed from different shades of granulate. The result does not correspond exactly to any RAL color". That makes it difficult to get a really good match.
I've got quite close with a mixture of Mr Color 518 Olive Drab, 52 Field Gray (2) and 513 Dark Gray just mixing by eye - but that is a really, really lousy hit-and-miss method.
Please let everyone know if you do find a good solution.
As a side issue - pieces of C-track ballast can be dissolved in the right PVC plumbing solvent (somewhere in my other posts) to make a glue of exactly the right colour to repair or join C-track pieces when needed.
Good luck,
Mark
thanks 1 user liked this useful post by revmox
Offline Mailme
#4 Posted : 29 January 2025 10:50:28(UTC)
Mailme
Thanks for the feedback, looks like hit and miss, just like everything else.
If I come up with a good match I will share it!
#5 Posted : 29 January 2025 12:08:01(UTC)
Thanks …..Tony
IIRC Busch has a ballast that is colour matched to Marklin C Track. Can't recall the catalogue number off hand.
#6 Posted : 29 January 2025 13:00:19(UTC)
For me,it wasn't just color, but the size. I mixed two different bags of tallow stone and got close enough to the c track color and scale.
Online Pasquiles
#7 Posted : 29 January 2025 13:24:36(UTC)
Pasquiles
Luxembourg
Noch 09376. Is almost perfect match.
thanks 3 users liked this useful post by Pasquiles
Offline Mailme
#8 Posted : 29 January 2025 13:29:49(UTC)
Mailme
Thanks …..Tony
Thanks for the info, I will try and look it up……..
Offline Mailme
#9 Posted : 29 January 2025 13:32:21(UTC)
Mailme
Yes I had been told this but some else said to me it didn’t look right. I think it may be the salution however, even if I mix something else in it.
Offline Mailme
#10 Posted : 29 January 2025 13:34:27(UTC)
Mailme
That sounds interesting, it is getting the stuff over here that’s a problem. Thanks!
thanks 1 user liked this useful post by Mailme
Offline TrainIride
#11 Posted : 29 January 2025 13:36:10(UTC)
TrainIride
Thanks …..Tony
Best Regards
Joël
thanks 5 users liked this useful post by TrainIride
#12 Posted : 29 January 2025 14:33:37(UTC)
I just realised I meant tallus, not tallow. I saw a chef fry a chicken in beef tallow last night.
Offline samarlondon
#13 Posted : 02 February 2025 01:32:52(UTC)
samarlondon
Thanks …..Tony
https://www.modellbahnsh...9376/gb/modell_1615.html
#14 Posted : 02 February 2025 08:03:41(UTC)
Hello Tony!
I use Woodland Scenics ballast and you must use size "fine" to match the size of the ballast for the scale H0.
Best match color are B75 gray fine for the C-tracks.
I did tested by use this color and with water glue mixed with few drops of dishwashing liquid.
It makes ballast color little more darker when it dries.
Of course you can also use glue by brush direct on the tracks and spread the ballast.
Check in the Youtube by write in german language Märklin C gleis und ballast.
thanks 4 users liked this useful post by Goofy
#15 Posted : 02 February 2025 15:19:10(UTC)
I used B-75 from Woodland Scenics. I mixed in some larger talus of a mixed color brown/grey from BZD or JTT. C track to me anyway looks to have a couple different size ballast.
Offline Copenhagen
#16 Posted : 02 February 2025 17:57:23(UTC)
Copenhagen
I have used the dark gray from Busch or Noch a good deal but also the light gray and even some brown from Woodland Scenics in between tracks. Both in order to get some visual diversity and to model how ballast could look in real life where there can be a mix of old, darkened ballast and new, fresh looking stuff. I've also abstained from using ballast in several parts because of the hassle when changing or fixing something on the layout :-)
thanks 4 users liked this useful post by Copenhagen
Passing Cables under and out from C track ballast (H0-scale)
by Jabez 03/11/2016 01:22:23(UTC)
C track ballast colour (H0-scale)
by laalves 20/02/2004 13:19:26(UTC)
This page was generated in 1.016 seconds.
