Offline Michael4
#1 Posted : 26 January 2025 11:28:20(UTC)
Michael4
These are the M track curved points/turnouts.
Why is it that the small 'guard rail' becomes loose over time? I don't know its correct name but the bit near the white arrow in my picture. When it becomes loose derailment can result.
Are my old locos too heavy? Are they running too fast? Or is it simply a case of age?
It is easy to rectify but I seem to have to do it quite often. However it means removing the piece from the layout which inevitable causes problems elsewhere.
Any advice much appreciated.
UserPostedImagepoint by dralowid, on Flickr
#2 Posted : 26 January 2025 12:24:42(UTC)
Hi Micheal
This issue is very easy to correct.
Those guard rails are attached to the sheet-metal ballast by two tongues going through the ballast and twisted for anchoring.
Before twisting the tongues , make sure - using a Märklin wheelset that the guard rail position is correct (so that the wheel is not bumping on the ftog) ONLY THEN attach the tongues by gently twisting them a little
Edited by user 26 January 2025 21:25:28(UTC)  | Reason: Not specified
Offline Michael4
#3 Posted : 26 January 2025 12:41:14(UTC)
Michael4
Hi Jean,
Many thanks. I am familiar with correcting the issue, as you say, it is easy once removed from the layout.
My real question is about the cause. Why does it happen?
#4 Posted : 26 January 2025 14:08:22(UTC)
Hi Jean,
It could be for a couple of reasons.
1. The wheel flange is too thick for the gap between the check rail and the running rail.
2. The wheels on (some) wagons are too close together, so that when a wheel is in the frog of the point the other wheel is rubbing on the check rail with enough force to eventually work the check rail loose. I suspect this is the more likely scenario. The solution is to measure the back to back distance on the wheels of all your rolling stock (including locos) with either calipers or a wheel gauge and correct any that are out of tolerance.
Offline analogmike
#5 Posted : 26 January 2025 15:13:12(UTC)
analogmike
Vibration.
I wonder if they can be soldered permanently from underneath? One can only tighten the little twisty bits so many times before the metal tears. I guess they never figured we would be playing with this stuff 70- 100 years later.
BigGrin
Offline Michael4
#6 Posted : 26 January 2025 15:43:38(UTC)
Michael4
Am I right in remembering that wheel spacing is 13.9mm for M track?
Are the little rails called 'counter rails'?
Not sure about soldering, they share an insulating type pad with the frog, don't want to pull more apart than needed.
From a quick check it looks as if all M track counter rails are the same size. I have a box of junk turnouts, might be worth stripping the counter rails off them for use when I break bits off the ones currently in use.
Offline Paul59
#7 Posted : 26 January 2025 17:47:28(UTC)
Paul59
In the UK they are called 'Check Rails', I don't know if that name is used in other countries.
I've had a couple come loose and I just fixed them by dribbling a drop of superglue down the edge of the check rail at the position where the tongue goes down through the base of the point. I used a good axle to ensure the check rail was in the right position before it dried. Those fixes have held firmly ever since.
Using superglue means that it can be done from above so you don't have to disturb the track. Just don't run any trains until the glue has dried.
A couple of little dabs of epoxy on the edge where the rail contacts the base would probably work just as well.
It must have been a problem that was recognised by Marklin as later points have these check rails moulded in plastic in one with the sleepers which are a bit thicker where the check rail is.
It's a nuisance but easily fixable.
thanks 1 user liked this useful post by Paul59
#8 Posted : 26 January 2025 19:02:22(UTC)
Only cause: someone tried to adjust the counter-rail without doing it right
Offline BenP
#9 Posted : 26 January 2025 20:03:33(UTC)
BenP
14 +/- 0.1 mm
Offline 60904
#10 Posted : 03 February 2025 11:57:35(UTC)
60904
You may also fix them with hot glue.
Edited by user 07 March 2025 21:44:10(UTC)  | Reason: Not specified
Martin
thanks 1 user liked this useful post by 60904
This page was generated in 0.464 seconds.
