Offline Adrian666
#1 Posted : 23 January 2025 07:00:17(UTC)
Adrian666
Romania
Hi, i have 3 questions , is it normal for the station to be called 21267 ? See picture
2
There are some flashes when I start the station before the logo marklin digital appears, s that normal ?
And 3 When i turn it off , it shows the black screen with 2 lines of codez îs that also ok ?
thanks 2 users liked this useful post by Adrian666
#2 Posted : 23 January 2025 09:20:41(UTC)
Hi Adrian,
That is all normal.
The flashes are part of a boot-up routine.
The series number 21267 is not material to the operation.
The close down screen is for command line entries, to enable a traned technician to access diagnostic functions.
Ordinary users would have no reason to use this command line.
Offline PerR
#3 Posted : 23 January 2025 09:24:03(UTC)
PerR
CS3-21267 is the default name of the CS3, and the number in the name of the CS3 is the serieal number of the device.
In that way, the name of the CS3 is different if you have more CS3's on the same network.
You can rename the name of the CS3 in the setup menu, if you want to.
But what you see is normal.
Per
thanks 2 users liked this useful post by PerR
Offline Adrian666
#4 Posted : 23 January 2025 09:32:51(UTC)
Adrian666
Romania
This page was generated in 0.222 seconds.
