Offline Tiki734
#1 Posted : 23 January 2025 06:44:33(UTC)
Tiki734
Can anyone shed some light on a rare piece of pre-war track 3600AR. I think it appeared in the 1935 catalogue for one year only. A boxed one has come up in Munich Toy auction.
thanks 2 users liked this useful post by Tiki734
Offline ccranium
#2 Posted : 23 January 2025 19:04:59(UTC)
ccranium
Hi Roger, I don't see any 3600's in the 1935 catalog, but I do in the 1936 "OO" catalog (I think OO was introduced for the first time in 1936); however, there are no "AR" pieces.
Is it possible the "R" is a smudged "A"? That would correlate to the "Anschluss-Schiene" (Connection-Rail) 3600 AA in the 1936 catalog
It wouldn't have had a red plastic connector as in 1952+, and it would be male.
I hope this helps.
Brian
thanks 3 users liked this useful post by ccranium
Offline Tiki734
#3 Posted : 24 January 2025 05:36:18(UTC)
Tiki734
Brian
I don't have a copy of the 36 OO catalogue. This particular track section has a lever and you can see the pivot point bolt/nut. It also has the power cables so could it be a direction reverser or isolation of some sort.
Roger
Offline Paul59
#4 Posted : 24 January 2025 09:51:33(UTC)
Paul59
Roger - it is 3600 AR.
In the early days of 00 around 1936 the controllers used only had four output voltages so there was no fine control of the locomotive speed.
This power feed track has a small wire wound resistance underneath it and the red knob moves a wiper over the windings. It allowed a limited amount of speed adjustment so the speed could be fine tuned between the coarse speed steps of the main controller.
Google Marklin 3600AR and look at images and you should see a picture of the underside of it.
It's very rare apparently as it was not required once better main controllers became available so was only in the system for a year or so.
Paul
thanks 4 users liked this useful post by Paul59
Offline ccranium
#5 Posted : 24 January 2025 17:33:05(UTC)
ccranium
Paul, Thank you! Amazing bit of M trivia. Which answers my thought on what appears to be a red connector and is instead the red knob. Shame on me for not searching before replying previously!
Brian
Offline Paul59
#6 Posted : 24 January 2025 19:42:19(UTC)
Paul59
Your welcome Brian.
This has got me thinking now....
On traditional analogue layouts they would be quite useful for feeding power into short adjustable slowing sections before signal stops as they could be quickly adjusted for faster or slower locos.
Also they could be useful for feeding into downhill sections to prevent the trains racing down the hill. Again the knob could easily be adjusted for different locomotives.
It would be a nice little project to make a few.
Paul
thanks 1 user liked this useful post by Paul59
Offline Tiki734
#7 Posted : 25 January 2025 09:30:33(UTC)
Tiki734
Brian and Paul
I did Google it but never found much. I redid the search and found the full details straight away.
For anyone interested https://tischbahn.de/ger...s-anschlussgleis-3600ar/
Photo of the back Roger
thanks 4 users liked this useful post by Tiki734
Offline ccranium
#8 Posted : 25 January 2025 19:12:53(UTC)
ccranium
Thank you, Roger. This is why I love this Forum.
While low voltage compared to the mains, regulating the return is somewhat scary since an accidental short from the center rail to the return plug on the trafo could be a surprise, as unlikely as that would be. Certainly not as bad as a wall switch being used on the neutral wire (my first home, wired in 1917, had that but not for long after 1987 upon my purchase...)
I need to read tischbahn more often!
Brian
#9 Posted : 22 September 2025 12:37:31(UTC)
The 3600AR production in 1935/6 for export market.
This page was generated in 0.343 seconds.
