Offline Normmeister
#1 Posted : 16 January 2025 02:04:19(UTC)
Normmeister
I have just received the Piko 96619 set of five Zugkraft Aargau coaches (limited edition, only available in Switzerland).
The coaches are beautifully decorated and have multiple lighting features, with a decoder in the control car.
However, the couplers do not lock. They are a two pole conductive type (Piko part number 56047). They mate nicely and conduct the electricity well, but pull apart. I have Marklin single pole conductive couplers (72025) that I could use (the coaches have the standard NEM pocket), but two poles are needed. The reason is that Piko chose to have a pickup shoe on the control car, plus a wiper on two axles to provide the ground return, but the other coaches do not have ground return axle wipers.
No doubt there are other two pole couplers around, but they are very expensive, especially when one has to fit five coaches.
Any thoughts on how to make the existing Piko couplers work ?
regards to all
Norm in Oz
thanks 2 users liked this useful post by Normmeister
#2 Posted : 16 January 2025 02:36:11(UTC)
Not a direct fix, bit Modellbau Schoenwitz does very small (and very affordable) 2 pole electrical connectors. You could run those and use any couplers you like.
But that is of course less than ideal- the piko ones should work?
Offline Normmeister
#3 Posted : 16 January 2025 06:44:01(UTC)
Normmeister
I have done further experiments. I found that if I briskly slam the coaches together, they will latch. But not very reliably, coaches tend to sometimes separate when trundling around the layout.
Also, Piko have supplied the coaches with the Piko conductive coupler fitted, but of course the loco end of the train, the coach that is supposed to couple to the loco has a standard non conductive loop coupler (what Marklin call the relex coupler) on one end, the other end has the Piko coupler. So that the loco coupler will not short out the electrics.
However ................... one would expect only one of these "different" coaches, but actually two of the five are like that, so one can only use four of the five coaches together.
Solution: I consulted my spare parts box and found I have plenty of the Marklin 219446/219447 two pole conductive couplers, so I will fit those to the Piko coaches.
Disappointed that I have had to modify a newly received model.
Norm
thanks 1 user liked this useful post by Normmeister
Offline PeFu
#4 Posted : 16 January 2025 07:59:38(UTC)
PeFu
Have you seen this review? It maybe can provide some hints on how to manage the coplings. You may add English subtitles to the clip.
thanks 2 users liked this useful post by PeFu
#5 Posted : 16 January 2025 13:10:18(UTC)
Too often we are finding that new items are being delivered and do not work as they should. Manufacturers are clearly not testing their product properly and maybe we should start complaing more.
However my view remains that these are cheaply made plastic toys and whu ile they may look good they should be useable without the buyer having to modify.
Offline mvd71
#6 Posted : 17 January 2025 03:39:42(UTC)
I can understand your disappointment.
I think you should email Piko and tell them quite clearly how they have failed you.
Perhaps if you are lucky they will do the right thing and at least send you some spare couplers!
Offline Normmeister
#7 Posted : 17 January 2025 04:09:04(UTC)
Normmeister
Thanks guys for the comments. I will answer each in turn:
PeFu: I did try that YouTube clip. The autotranslate was not terribly helpful, much of it gobbledegook, but it does not address the problem, in fact it gives the impression that the reviewer is in love with the couplers and can see no wrong.
David: They might be "plastic toys" but cheap they are not. The whole set was almost $1000 AUD
mvd71: spare couplers would not be any use. It is not that the ones I have are faulty, it is just a lousy design that is dodgy and unreliable. So more of them I do not want ! I am in the process of converting the coaches to Marklin two pole conductive couplers, it is a fiddly job but will hopefully solve the problem
regards to all
Norm.
Offline PeFu
#8 Posted : 17 January 2025 07:49:36(UTC)
PeFu
What still confound me is that I still can’t google a single additional negative review of the Piko 56047 couplings. (Note that I’m not a seller nor a user of these couplings.) Is your layout demanding when it comes to curves or vertical transitions? Bended M tracks etc.?
Smile
Offline Drongo
#9 Posted : 17 January 2025 12:25:06(UTC)
Drongo
David, I have been saying this for years, especially Marklin products. They simply don't thoroughly test the products. This was seen with their steam loco 37017. It has only 2 main wheels on each side and when it reaches an incline the back wheel lifts off the tracks and the loco stops. I returned the loco to Marklin with a video showing the problem, however they ignored me and simply return the loco. If you look at some of Marklin promotion videos they show you the test track area and ALL the track is on a flat, level surface with very few curves. Therefore the test process does not reflect our actual layouts. As we say hear down under, "You've got Buckley's of trying to tell the Germans".
Offline mario54i
#10 Posted : 17 January 2025 12:38:05(UTC)
mario54i
I have a Piko Golden Pass Express AC set that uses the same conductive couplers from factory and I put them also in a Liliput BLS Nina consist. I don't remember any mechanical disconnection, maybe some electrical disconnection.
#11 Posted : 17 January 2025 13:03:58(UTC)
By saying cheap I am talking about the cost to manufacture which you can be sure will be little. Items like model coaches do not sell in numbers to allow small mark up margins hence the price we pay is expensive for what we get.
However I hope you can reslove the probem with Marklin couplers but you should still complain to PIko if the ones you mhave are faulty.
David
#12 Posted : 17 January 2025 14:53:36(UTC)
Aftre all the hoopla since the early 1980's about inflation, interest rates, debt, inflating the currencies to provide income raises for the working middle class, since the reduction of it all, the only ones better off since are the wealthiest of the planet.
So I say pay people more, inflate the currency to match, and fuel our economies.
At the end of a fisdcal year, the rich are richer regardelss. What does it matter what the number amount is in pricing, wages, taxes, etc. if we do not earn enough to save and spend?
If that trend becomes steady, then demand falls and that will eventually hurt even the wealthy.
After all, it was those wealthiest who outsorced production, lowered their costs. and increased their profits to begin with.
In addition, isn't it ironic
that when corporate debt climbs to ridiculous levels, it miraculously eventually goes away. Either by restructuring, bankruptcy, aquisitions, or mergers. The rest of ultimately pay for that as well.
#13 Posted : 17 January 2025 18:41:10(UTC)
I don't have the ZKA Set. I have the Goldenpass Set, which is 5 coaches (no pilot coach). I have the Piko current conducting couplers between coaches. Each coach has its own axle contacts, so a single wire is all that is needed to power the coaches. The set comes with normal couplings for the first and last coach to connect to a locomotive.
Based on what I found here: https://www.moba-forum.c...bb-ew-i-zugkraft-aargau/
The pilot coach has a slider and decoder that controls functions for the pilot coach only. The rest of the consist has OEM lighting, but is supplied by a slider on one of the coaches. Power is transmitted between coaches by 2 pole current conducting couplers. The set comes with normal couplers to connect with the locomotive and pilot coach. Connecting the pilot coach with current conducting couplers could lead to a short of the decoder. The way to remedy this would be to remove the AC slider from the coach that is so equipped and to power the train from the pilot coach instead. I do not know enough about the Piko decoder, but you may be able to connect the coupler to the lighting output of the decoder to control the interior lights of the entire consist. Before doing so, I would follow the instructions below to get more info from the Swiss distributor.
I would recommend that you contact Arwico (service(at)arwico.ch), the Swiss distributor who commissioned the ZKA Sets. They might be able to assist you with your problem.
The only issue that I have had with the Piko couplings is that I had two NPZ coaches outfitted with lighting by a well known Swiss dealer but cannot use one of the coaches with my RBe 540/BDt set because the wires to the lighting interfere with the couplers and cause a derailment. At some point, I will open the coach and try to reduce the stress on the wire so that the coupling mechanism can once again freely move.
Piko Germany might be able to help regarding the couplers, but the models were commissioned for Arwico, so they should be the go-to for questions.
https://arwico.ch/de/cms...s/service/servicestellen
Offline mvd71
#14 Posted : 17 January 2025 21:58:31(UTC)
regards to all
Norm.
Good luck Norm, I hope you are successful and get some joy from the set!
Cheers…..
Offline Normmeister
#15 Posted : 17 January 2025 23:59:48(UTC)
Normmeister
One interesting detail about the set. The control car has a function decoder. I tried it on my ESU Lokprogrammer, it said it is not an ESU decoder, and gave the manufacturers code as " 85 " which is Uhlenbrock. But the surprising thing was that it auto registered on my Ecos, so it must have Railcom plus. Very convenient.
Norm
#16 Posted : 18 January 2025 14:29:37(UTC)
I think Railcom plus is becoming more common. That's good as Piko needed to make the decoders they use more widely compatible.
Offline Normmeister
#17 Posted : 22 January 2025 06:03:13(UTC)
Normmeister
The saga continues .........
I should say that my problems with the Piko coupler are probably due to the many gradient changes on my layout. The Piko couplers have no protection against even very small variations in height, similar to the way that the KD type knuckle couplers are . I can successfully run items with the KD type but the Piko couplers are much more touchy.
Anyway I tried the Marklin 219446/219447 two pole conductive couplers. These are like a two pole plug and socket, and require a bit of effort to couple up. I found that they are too rigid, causing a following coach to twist on curves and derail. Also they hit the buffers on curves.
So next try was the new 72025 conductive close coupler, released by Marklin to conform with NEM buffer heights. Of course only single pole so I had to fit an axle wiper strip to each coach to provide the return path.
This works well, except that if the couplers are pushed fully home in the NEM coupler pocket, the coaches are too close and the pretend concertina passageways between the coaches foul each other on curves. So I extended the couplers out from the pockets by about 1 mm.
The other advantage of the 72025 coupler is that it couples and uncouples easily, unlike the original Marklin conductive close couplers.
Norm
#18 Posted : 22 January 2025 18:18:52(UTC)
Some models have coupling shafts that are a little shorter and make it hard to properly couple them to other coaches. I have found that Roco's Universal Coupler has a shaft which is approximately 1mm longer than most others. This has allowed me to safely use coaches and cars from brands like LSM, ACME, Liliput, Heris, etc with my Roco and Maerklin coaches, cars and locomotives. Some brands, like LSM, have a coupling socket with two positions, so you can insert the couplings either fully or partially, which can solve this issue in some cases. I don't know why they chose this option rather than ensuring that the shaft with coupler extends properly to the point where it can safely be coupled. One other alternative that I used for a few consists was alternating close coupler (7203) with the regular hook coupler so that there was a little more space between coaches. The Roco Universal design allowed me to have the same coupler on all cars.
As far as using current conducting couplers, I have not done too much exploring their operation. There are many companies that make single or multi-wire couplers and even a few that do it magnetically. I have not measured the spacing between coaches using varying brands.
I remember the Hag SBB/BT BDe 4/4 from the 70s and how the lights were connected via a cable that was connected in each coach and then wired through the gangway door windows with a Maerklin style plug and socket that you would push into either one or the other coach's body.
Today, you can get much smaller plug and sockets, so running a wire (or two) can be less obvious.
I have not yet had much experience with my Piko Goldenpass consist on gradient changes (my floor is flat). Perhaps maybe transitioning from bare floor to carpet.
Have you tried the Viessmann 5048. I think that is the number for their current conducting coupler (2 pole) based on the Fleischmann Profi couplers.
I have not tried the Krois couplers https://krois-modell.at/...g-2-polig-MKS-2::26.html
This page was generated in 0.649 seconds.
