Offline Blazebroughton
#1 Posted : 10 January 2025 16:41:35(UTC)
Blazebroughton
I'm having trouble wiring my older switching track but my transformer (278 A model)but it
only has 3 ports and two are being used to power track what do I do?
Offline RudiC
#2 Posted : 10 January 2025 16:59:36(UTC)
RudiC
The brown ground connector is used as a return for both the red locomotive / rail power as well as the yellow light / solenoid current.
Rüdiger (Rudi)
thanks 1 user liked this useful post by RudiC
Offline FastEddie
#3 Posted : 10 January 2025 17:20:52(UTC)
FastEddie
You can use the ground terminal for multiple items you just need to gang the brown plugs or use a distribution strip and then connect the distribution trip to the brown terminal. Track power comes from your red wire from the power track to the transformer. The brown wire from the power track can be plugged into the ground (brown) distribution strip. The yellow terminal is used to power lights like those on switches.
thanks 1 user liked this useful post by FastEddie
Offline ccranium
#4 Posted : 10 January 2025 18:43:01(UTC)
ccranium
The red wire from the feeder track's center rail goes to the "B" connection on the trafo and the black or brown wire from the track's base goes to the "O" connection on the trafo. The yellow wire from the turnout goes to the yellow or "L" on the trafo along with any other accessory lights which you may have. The 2 blue wires from the turnout go to a 476/4 Control Plate with pairs of red and green buttons; then connect one of the side connectors on that Control Plate to the black or brown wires going to the "O" on the trafo.
The turnout works from power from the "L" and the circuit is completed when you press a red or green button to make one of the 2 solenoids in the turnout move the points.
The only things which connect to the "B" connection on the trafo are the feeder tracks for the center rail.
Brian
This page was generated in 0.610 seconds.
