Offline Twinrover1965
#1 Posted : 09 January 2025 13:50:02(UTC)
Twinrover1965
Forgive my ignorance but which Marklin digital wiring (with bare wires at one end and spades at the other) do I need to run from a distribution strip to C track?
I understand 74040 is used for analogue only.
I am currently using Uhlenbrock 2neo control.
Hope one of you oracles can assist.
Many thanks.
Offline rhfil
#2 Posted : 09 January 2025 14:45:16(UTC)
rhfil
My theory has always been the bigger the pipe the less loss due to friction but in this instance whatever you are comfortable using from 14 down. The female spade lugs need pretty small wire or they don't fit the male ctrack spade lugs.
Offline PMPeter
#3 Posted : 09 January 2025 15:46:25(UTC)
PMPeter
Many thanks.
I'm not really sure what you are asking. The 74040 wiring set is what you use to connect to C track. The red wire goes to B and the brown wire goes to O. It doesn't matter whether you are running analog or digital.
thanks 2 users liked this useful post by PMPeter
This page was generated in 0.195 seconds.
