Offline johnhendry
#1 Posted : 09 January 2025 02:47:18(UTC)
johnhendry
Guys, I’m curious if you all think that this motor noise is normal for an old loco like our V200 or if you think it needs a service, etc?
[img=https://www.marklin-users.net/upload/community/Prototype/johnhendry/17743_IMG_2044.mov]V200 motor noise video [/img]
#2 Posted : 09 January 2025 06:23:26(UTC)
It is hard to tell whether it is the slider or the motor that is louder.
Check the slider to make sure it is straight and even.
You can test the motor by connecting wire leads directly to the wheels and slider while the model rests on some kind of cradle.
Offline RudiC
#3 Posted : 09 January 2025 12:10:10(UTC)
RudiC
Cleaning and slightly lubricating an old loco in not too long intervals is never a bad idea. And looking at the brushes as well. That said, I think your V200 sounds quite similar to mine (from the early sixties), which gives a nice dieselic sound when driving slowly.
Rüdiger (Rudi)
thanks 2 users liked this useful post by RudiC
#4 Posted : 09 January 2025 12:52:37(UTC)
I agree with Rudi and I find that my older locos which aren't run in some time need just a tiny drop of oil on the external armature shaft at the center of the covers or shields to quiet them up. The gearing warms up with running and the oil on them gets more viscous.
Offline FastEddie
#5 Posted : 09 January 2025 16:29:38(UTC)
FastEddie
It just sounds like an old 60's V200. They growl a bit because of the metal body acting as an echo chamber. My streamlined 3089 is worse.
thanks 1 user liked this useful post by FastEddie
Offline Paul59
#6 Posted : 09 January 2025 17:02:11(UTC)
Paul59
I'm with FastEddie here - it doesn't sound too bad to me. I don't use C track - (in fact I've never even seen any) does it tend to amplify the noise at all?
Weren't the older locos made with gears that were stamped out rather than machine cut? I'm sure I read that somewhere. If this is the case then it would have been a bit of a lottery whether you got a quiet one or not. This looks like an early V200 so maybe it's one of those.
Run it round with the body off. That is the only way that you can really tell how much noise the mechanism is making since the bodies do tend to resonate or amplify it. Some locos are worse than others in this repect.
thanks 1 user liked this useful post by Paul59
#7 Posted : 09 January 2025 19:33:22(UTC)
Yes, the Danish M-y series does that too.
This page was generated in 0.370 seconds.
