Offline fabstar68
#1 Posted : 05 January 2025 18:44:09(UTC)
fabstar68
hi all, sorry to bother but i cannot understand if rocrail has a limit in virtual automatic mode ragarding direction swap. I only recently tried this method to test my layout, and i saw that locos didn't reverse direction, even if they met all the conditions. But just to avoid messing with my main plan, i created an empty one, just 2 blocks connected, the blocks allow for direct swap, the loco is defined as a commuter train... and here everything works. so what am i missing in my main plan ? i checked that everything is defined as it should be to allow reversing direction. Only thing that i don't understand, is that when the loco arrives at the last block, where it should change directin, the system says "no direction found". but if i manually go in the block where the loco is, and right click on "swap logical direction", then it starts, makes the loop, and then stops again. <UPDATE>. I found a loco for which the reverse worked. i checked the settings, and they were all equal to the one that didn't reverse, save for address and type. i copied the working loco, changed the parameters to match the non working locos, and then it worked. so i guess it is some weird bug in the definition of the non working locomotive>
This page was generated in 0.179 seconds.
