Offline Carlos
#1 Posted : 29 December 2024 13:35:52(UTC)
Carlos
Hello to everybody:
Does anybody had ever used the RailControl Pro? And if so. is really easy to use or do you have any recommendation to set automation/Events with the CS3+?
Thank you
My best regards,
Carlos
#2 Posted : 29 December 2024 15:41:05(UTC)
Hi Carlos
Why would you need such a thing when you have a CS3 when you need only a wifi router or Internet/TV box (that you probably already have)?
Here is the way to use the CS3 / CS3 with a smart phone:
- connect the CS3 / CS3+ to your Box / Router using a CAT5 or CAT6 cable (Ethernet cable)
- look on your CS3 the IP address given to it by the rouer / Box
- if no IP address is shown, type the IP address 192.168.1.15 and validate in the CS3
- on your smartphone, authorize WiFi and be sure you are onnected to your home WiFi
- on your smartphone open the browser and in the name filed type the same IP address ( 192.168.1.15 in this example) and confirm
I use an old iPhone 12 and the result is like this
So sorry it does not anwer your question but provides a way to use your smartphone free of charge
Offline Carlos
#3 Posted : 29 December 2024 18:21:45(UTC)
Carlos
Originally Posted by: Carlos Go to Quoted Post
Hello to everybody:
Thank you
My best regards,
Carlos
Hi Jean: Thank you for your prompt response, The problem I have is that I have my CS3 with my model in the basement, and the router on the first floor. Is there a way to make it work without having to bring the CS3 to the first floor every time you need it? Or I have to connect to the CS3 only once?
Carlos
Offline rhfil
#4 Posted : 29 December 2024 18:39:53(UTC)
rhfil
You can buy a router for around $30.00 and it works even better with a pad. I use it to control locos and our 17' X 34' club layout. The stop button is better than yelling at the CS3 operator who is off in dreamland or talking with someone.
RailControl Pro — CS2 and CS3 controller for iPhone, iPad and Mac (Model railroad software)
by northstar 24/02/2023 15:29:28(UTC)
This page was generated in 0.243 seconds.
