Offline nlevassur
#1 Posted : 23 December 2024 22:44:18(UTC)
nlevassur
Views messages in topic : 9
Ok, I’ve been an analog only LGB enthusiast for decades and even though some locos have some decoders, I never had the opportunity to try them digitally until last week. So I purchased a Mobile Station II, had the dealer upgrade the firmware to V 3.112. I hooked up the 66367 power pack and 60114 digital connector box to a small circle of track and placed my first dcc loco on the track. I left all the protocols in place. I have only one recent loco with a factory mfx decoder while the other locos have older decoders from either late LGB lineage or early Marklin.
The locos all registered via “find” and allowed me to change the icon, address, etc. Then for the heck of it after adding all 5, I placed the first one back on the track and changed the loco selected to the last one, which it should not have been controllable as I had change the address but its motor functions work just fine… any loco will run on any of the 5 locos defined into the Mobile Station II.
1. What am I missing? Are they using the same short address perhaps from the factory? If so should I change the short address via CV to match the address that I changed via the mobile station UI? Clearly during the “add” it recognizes that the unique decoder has various unique functions that it presents but why does they all respond with motor (throttle functions)?
2. The loco with the MFX decoder which is new, acts rather odd….. All of the functions seem to work, motor, exterior lights,interior lights, announcements, other sounds, etc ….. however, it makes a very loud whining noise which almost masks the other sounds. If I mute the sound completely its tolerable but them I lose all the other sounds. The loco is a lgb 20384 San Francisco Streetcar. It worked without the whining on analog but since running it on digital it’s now making the noise on analog. I have reset the decoder, removed the loco and re-added it like 10 times… to no difference. Does it sound like the decoder has gone bad?
Thanks in advance for weighing in.
Noël
LGB analog & digital CS3+
thanks 1 user liked this useful post by nlevassur
#2 Posted : 24 December 2024 00:43:40(UTC)
This sounds like all locos have the default DCC address of 3. You need to place each loco on the track one at a time and change the loco address. I would recommend you change them all off 3 so that next time you put a new loco on the track it doesn't operate with one of your existing locos.
Once you have changed the loco address then you can the corresponding loco configuration to use that address so you don't need to go through the whole configuration loop again.
Offline nlevassur
#3 Posted : 24 December 2024 03:28:32(UTC)
nlevassur
Alan,
I did change each address with the menu selection to Change Loco, scrolled down from Name to Address and made each unique. Is there another address that must be changed directly via the CVx like at CV1 that I need to change? I apologize in advance for my ignorance and appreciate your reply.
#4 Posted : 24 December 2024 08:52:04(UTC)
Did you read the manual of the MS2?
In page 14 with the english language it stand Only the locomotive to be edited may be standing on the track, which means to configuring a locomotive must stand alone on the track.
MS2 works like both track and programming track.
Yes it´s dumb system!
Even Märklins accessories changes too if they are connect to the same wires from the box 60116.
What you need is to seperate main track to alone track/connect if you shall change value in every CV adress of the locomotive/accessories.
I recommended you a two pole switch to the connect or an alone track stand.
Offline nlevassur
#5 Posted : 24 December 2024 13:47:35(UTC)
nlevassur
Thanks Goofy for your reply. I actually did read the manual as well as watch a few YouTube videos before I attempted anything. I did make sure to remove each loco before I placed the next one on the small circle of track and “find” the next one loco.
I even double checked that I had actually changed each loco’s address and sure enough the Mobile Station II thinks I did. Even after I reset the Mobile Station II and re - found each loco the addresses and loco names were all as I had left them with changed addresses and names.
Maybe I should reset the locos decoders to factory and try again?
Thanks again… any new ideas?
Noël
#6 Posted : 24 December 2024 14:59:14(UTC)
Alan,
I'm assuming you are running the ms2 in DCC mode only (although you mentioned you have one mfx loco). I haven't tried using an ms2 for DCC, so don't know if setting the address as you describe will change the CV in the loco or not, but it sounds like it didn't. It may well be worth checking what the loco CV says the address is. It may well be worth making sure that all other formats are turned off in the decoder as well, as having multiple formats enabled can sometimes confuse things.
Offline rhfil
#7 Posted : 24 December 2024 19:40:01(UTC)
rhfil
The only additional information I can add is in reference to a CS3 and mfx. My understanding is that at some recent update the mfx system changed so that each locomotive performs a unique "handshake" with the CS3. That is why every mfx locomotive needed to re-register after the update. And if you reset the CS3 it will all have to be redone. If you investigate the cv you will find that there are two controlling addresses. One for the unique handshake and a second if your controller does not have mfx. But don't hold me to any of this.
#8 Posted : 25 December 2024 08:28:55(UTC)
If you use DCC and the train are set at adress 3 you must add the locomotive manually in MS2.
It also depend if you did set MS2 in DCC protocol for the locomotives.
I use DCC protocol in my layout and did tested with MS2.
It works nice!
If you did success by reset your loco at CV 8 and write 8 in the value you can start over again by use in another way by control your loco on the layout.
Offline Copenhagen
#9 Posted : 25 December 2024 09:56:39(UTC)
Copenhagen
Don't know if it's been mentioned but don't use the "find" method when adding a locomotive that only uses dcc addresses.
Offline rhfil
#10 Posted : 25 December 2024 15:01:00(UTC)
rhfil
And I believe "find" only works with a CS3 if the dcc loco is on the programming track. The CS3 has another feature "find missing mfx locomotives".
Offline nlevassur
#11 Posted : 28 December 2024 01:02:28(UTC)
nlevassur
First of all let me thank everyone that has comment one or more times. It has been very helpful.
Based on all of your advice, I :
1. Placed each loco on the track and reset each loco. Then removed the loco and went to the next.
2. After all locos were reset, I reset the MS2, then turned off all protocols except DCC.
3. Then I placed each loco on the track and did a manual add with address of 3 and this is where it got a little interesting. The motor function would not work. When taking stop off, I would get sound but the throttle wouldn’t do anything. So I changed the address in the MS2 back to what I had changed the loco to before step 1 above. Then everything worked.
My conclusion:
The reset loco on the MS2 menu, doesn’t work. Perhaps I will try changing the appropriate CV to force a loco reset.
The new mfx loco with the annoying whining noise is still at the lower volume I had set which is further proof that the reset loco on the MS2 menu didnt work. The volume didnt reset to factory default and neither did the address.
So each loco now has a unique address, and they are all running under DCC only.
I have read about plenty of frustrations on this forum, and now I am sharing in the nest! Thank you all for your help. I will update this thread as I learn more. Hopefully, my experience will improve someone else’s experience.
Noël
thanks 2 users liked this useful post by nlevassur
Offline nlevassur
#12 Posted : 27 December 2025 03:56:23(UTC)
nlevassur
While this topic is very old, I wanted to share the solution to this post:
1. My oddly acting loco was still under warranty so I reached out to Marklin service, sent it in, they fixed it and upon return it was working. Apparently a “hall sensor” had failed and needed to be replaced. While working with the other locos and the MS2; Marklin’s approach to managing CVs;MFX locos; etc - I was “drawn to the dark side” - Marklin CS3.
2. Thanks to everyone that weighed in on my problem that was probably thinking it was MS2, or the operator (me). It certainly underscored that the MS2 is very limited and cannot exist forever without needing a CS for updates, certain types of resets, etc.
3. Early this month, I acquired a CS3+ and I’m really enthused about moving forward… so as this closes, don’t worry I have been also reading a lot of old posted questions and answers so hopefully I can avoid dumb questions.
Thanks for the help, but more importantly, kudos and thanks to this amazing resource of past and present active subject matter experts on this forum. It is absolutely incredible.
Noël
Offline rhfil
#13 Posted : 27 December 2025 12:20:57(UTC)
rhfil
modeltrainfun on YouTube has the best videos on Marklin including very detailed introduction into the CS3. You will find that the CS3 offers access into a wide range of opportunities and each one can tie up all your time and effort. You have to decide which one you are most interested in pursuing and allow the others to just what you need to meet your minimal operational needs. You can always return to them later. Have fun.
Offline nlevassur
#14 Posted : 29 December 2025 04:20:44(UTC)
nlevassur
Thanks I will check it out… I think I have seen a few already. Great suggestion
This page was generated in 0.406 seconds.
