Offline Jpearso1
#1 Posted : 20 December 2024 02:01:22(UTC)
Jpearso1
I just bought a Marklin oval track and I wanted to have two trains on the track. I purchased 8568 and 8569 curve turnouts having an inner and outer curve on one side of my oval. Issue I’m running into is when I have my turnouts switched to run the inner track I find the outside track is still live. Is there a way to use the 8568 and 8569 turnouts so when the inner track is switched the outer track doesn’t run the train on it?
Offline Jpearso1
#2 Posted : 20 December 2024 03:57:18(UTC)
Jpearso1
I wanted to add that I tried the switches manually without power. Would using a control box 72740 solve my issue? Or would it just electronically throw the switch?
Offline Carim
#3 Posted : 20 December 2024 11:09:54(UTC)
Carim
These points are "live" in both directions regardless of the direction the blades are switched to. So if you have a crossover to the inner circuit, you have to have electrical isolation on the crossover (either an air gap or isolating fishplates). The inner circuit will then require a separate power feed. If you are using analogue controllers and want to run two trains independently on each circuit at the same time, you will need two controllers. Alternatively, with one controller, you could set up a form of "cab control" that allows you to select which circuit is being controlled - but you won't be able to operate two trains, independently at the same time.
This web site explains all this better than I have: https://www.brian-lamber...k/Electrical_Page_1.html
I have not used the 72740 box, but the description seems to indicate that it just functions like a series of on/off switches.
Carim
Offline Jpearso1
#4 Posted : 20 December 2024 12:31:00(UTC)
Jpearso1
Hi Carim,
Thank you for the reply! I’m coming from N-scale Kato unitrak where when the blades of the turnout are on the inside, the inside is live, and the outside is not live. Allowing me to park another locomotive on the display. Sounds like this won’t be possible with my analogue controller. I wasn’t planning on going DCC on this setup , so I’m going to look into the options you suggested. Does Marklin sell air gap or isolating fish plates? I’m not familiar with these. Also it sounds like I’ll need a second analogue controller with a curved feeder track. Was hoping to have two trains on my display where I could switch which one I wanted to run around my basic oval. Doesn’t seem to be as easy as I thought.
Offline Carim
#5 Posted : 20 December 2024 14:56:15(UTC)
Carim
Air gaps are literally a gap between two rails (so electricity cannot flow between the rails) - so you just don't join two pieces of track together. Sometimes this leads to alignment problems so you can use insulating rail joiners; Märklin sell them in pack 8954, but I prefer the Peco product SL-311.
Carim
ZmeMman
Offline Jpearso1
#6 Posted : 21 December 2024 00:54:42(UTC)
Jpearso1
Thanks for the great information. I’m going to go with two isolating joiners on the outside track, and add a circuit track. I’m not sure how I’m going to power off the isolated circuit track if I’m using one transformer wiring both circuit tracks to the same controller.
Can I use a Marklin relay to power off the isolated track?
Thanks in advance
Offline RudiC
#7 Posted : 23 December 2024 15:24:37(UTC)
RudiC
Originally Posted by: Jpearso1 Go to Quoted Post
... Can I use a Marklin relay to power off the isolated track? ...
IF talking analog, Märklin semaphore or light signal in fact ARE relays to power / power off something, usually a piece of track, a block, a siding or what have you. You'll need two of them to alternatively run and stop either of the tracks.
Rüdiger (Rudi)
thanks 1 user liked this useful post by RudiC
Zme
This page was generated in 0.305 seconds.
