Offline genusCastor
#1 Posted : 17 December 2024 17:45:37(UTC)
genusCastor
I have an older Marklin 89028 (CM 800) engine, when I checked the brushes I found a carbon brush on one side and copper mesh on the other. Did an innerwebs search for replacement brushes and see they are sold in packs of two dissimilar (carbon & copper) brushes. Is this a requirement to use both? Or can both carbon or copper alone (both sides) be used OK?
brushes on eBay
Thanks in advance.
- djb
The best things in life aren't things.
Offline TrainIride
#2 Posted : 17 December 2024 18:11:32(UTC)
TrainIride
You have to use both, and at the good place !:
The two brush springs are different:
- one flat spring for the carbon brush
- one curved spring that goes inside the small hole of the copper brush.
Best Regards
Joël
thanks 2 users liked this useful post by TrainIride
Offline FastEddie
#3 Posted : 18 December 2024 16:41:31(UTC)
FastEddie
brushes on eBay
Thanks in advance.
- djb
For the older engines, you need both. Usually the carbon actually wears down while the copper one tends to wear unevenly over time and provides less contacts area. Its usually best to replace both at the same time but the carbon will wear quicker. it is also helpful to open the engine rotor assembly and clean the flat plates that the brushes contact so that the electrical connection is optimal.
Ed
Offline genusCastor
#4 Posted : 18 December 2024 17:02:25(UTC)
genusCastor
Allrighty, thanks guys. The engine is running a lot better (quieter) since I cleaned the rotor and brushes. I'll need to order a new set of brushes to have on hand, these two are looking a little short. I see them for sale on eBay, any suggestions for another source?
Thanks again.
- djb
Offline hermanvk
#5 Posted : 19 December 2024 05:03:57(UTC)
hermanvk
Thanks again.
- djb
I don't know if Tejas is a typo for Texas?
You might want to look at:
Texas European Model Trains
thanks 1 user liked this useful post by hermanvk
Offline genusCastor
#6 Posted : 19 December 2024 13:29:17(UTC)
genusCastor
Tejas is a historical spelling for Texas. Cool
Thanks for the link, looks like they have some brushes, I'll order some today.
- djb
thanks 1 user liked this useful post by genusCastor
Offline dickinsonj
#7 Posted : 21 December 2024 01:20:18(UTC)
Plus one on AJCKids - they are my go to dealer for everything Marklin, from small parts to entire trains.
And I don't live anywhere near to Tejas. BigGrin
Offline hermanvk
#8 Posted : 21 December 2024 02:26:19(UTC)
hermanvk
Neither do I (live anywhere near to Tejas), but shipping is actually killing it always for me.... Sad
This page was generated in 0.300 seconds.
