Offline Siluc94
#1 Posted : 03 November 2024 19:44:53(UTC)
Siluc94
Hello Guys
I can't get the M84 to work with the CS3, I saw the Model Train Fun video where he explains that there is a bug in the CS3.
Can anyone help me solve this problem?
Thanks in advance if anyone can give me some links to solve the problem
thanks 1 user liked this useful post by Siluc94
#2 Posted : 03 November 2024 21:41:32(UTC)
I haven't seen that video, but he has had a solution in every video I've seen before. I only have M-83 decoders. Update your CS 3 to the latest software and check the dip switch setting on the m 84. Read the instructions for it. You can select mfx, or dcc. One setting offers more addresses. In DCC you have to manually install the m 84.
Offline Siluc94
#3 Posted : 05 November 2024 15:31:21(UTC)
Siluc94
Thanks so much for the reply
#4 Posted : 05 November 2024 16:28:38(UTC)
Not truth! You can set DCC protocol in the m84 and use mfx read out by register in the CS3. Set dip switch first with choiced adress before you let CS3 do the work.
Offline Siluc94
#5 Posted : 05 November 2024 17:15:22(UTC)
Siluc94
Ciao Goofy
Thanks for answering my question
Offline Siluc94
#6 Posted : 05 November 2024 17:42:04(UTC)
Siluc94
IMG_9923.mp4 (3,748kb) downloaded 27 time(s).
This is my problem and I don't know how to solve it, I have done all the attempts that "Model Train Fan" recommended. All useless, perhaps not being an IT technician I miss some steps and am not able to upload the CVs. Thank you so much to whoever can resolve this
#7 Posted : 05 November 2024 18:27:16(UTC)
I can see what the problem is.
When you did choice adress via dip-switch and start mfx register m84 did you set "keep it adress" first?
You must do this first before you click "ok".
I recommend you first reset m84 or delete m84 from the CS3 before you start all over again.
#8 Posted : 05 November 2024 18:38:27(UTC)
Can you check in the set up at CS3 and see after if you have DCC protocol enable?
This page was generated in 0.378 seconds.
