Offline Mr. Ron
#1 Posted : 27 October 2024 04:50:51(UTC)
Mr. Ron
I am building a new layout using all Marklin M track. The profile of M track allows for a large space under the rails. I wondered if anyone has used the open space under the M track sections to run the wiring needed for power feeds, accessory wiring, signals, etc. This would eliminate the under layout wiring which is hard for a 90 year old modeler to handle. Another method would be to place all track on top of 1/2" styrofoam board and run all wiring ABOVE the layout in a trench alongside the track. The purpose is to eliminate all under-the-layout wiring that is difficult for anyone 90 years old to deal with. Every layout I have ever seen from the hundreds have placed wiring below the layout. This is fine if you are younger than say 50 and in good shape.
Offline Michael4
#2 Posted : 27 October 2024 10:47:48(UTC)
Michael4
I have tried running layout beneath M track but although the theory is good it didn't work for me. It just gets too complicated. Being analogue there is a lot of wiring.
I now use trunking and conduit that can be opened and closed. This runs round the side/edge of the layout and in theory all the wiring runs neatly across the layout and into the conduit. This doesn't look too bad if done carefully and since I keep on changing things it is remains to easy to work on.
Offline BenP
#3 Posted : 27 October 2024 12:12:19(UTC)
BenP
This solution will not work for layout deeper than 3-4 ft and lot of relief, but attaching to wall allows folding that exposes bottom. My original 4x8 layout was like that, but now I must sit below table of my 8x12 layout. Using 36" height table allows me to sit underneath on a trolley/dolly. (Only 69, but increasingly feeling the undertrack challenges.)
Ben van der Pluijm--
Offline dave55uk
#4 Posted : 27 October 2024 15:09:59(UTC)
dave55uk
Could you use C track instead? My digital layout has only 2 wires going from the track connector box to the underside of a piece of track. All point motors are fed from the track - no extra wiring required.
#5 Posted : 27 October 2024 17:44:11(UTC)
Hi Ron
I think, using the space under the M rails is not a good idea as the first thing to do in case of issues is to have to remove the rails to access wires. The other issue is the dramatic increase of length of every cable while a straight line is way shorter.
How to minimize wiring / accessibility of wiring?
- use digital and digital turn-outs. In this case you need TWO wires to connect your layout to the Central Station. Correction: you still need stop sections with signals UNLESS to control trains MANUALLY (in digital) that is no block system, etc.
- use digital and digital turn-outs AND a train control software (I use Rocrail). In this case NO NOTHING for signals / Stop sections AS YOU DON'T NEED THEM. To be honest, you still need to use contact tracks to report the location of trains (One or Two contact tracks per Block (the place where train stop waiting for free access. This wiring can really be kept to a minimum AND you don't need to change the wiring to change the operation of trains.
- if you prefer remaining in analogue, then one solution is to have wires comming from each turnout (3 wires) and bring them to a front cable path (accessible from your chair) where you connect it to the switch control box.
I really know how you feel (I am 78 and crawling under the table is not my favourite thing).
So how to minimize the crawling under the table?
- avoid using multi-levels layouts (I have 3 levels) so sometime I have to be under the table, with my frontal LED light, my iPhone to control the train (power ON / OFF, etc)
- be generous with block lengths (long blocks forshort trains)
Offline ccranium
#6 Posted : 27 October 2024 18:38:17(UTC)
ccranium
@MrRon your idea for a channel would work as long as you can reach all the areas where you have "trenches" and also label the wires. If you're running analog, creating a bus in a trench is no different than running them underneath in a loom.
Running all those wires under M track is more hassle than it's worth. There's no room for more than a small layout, and shorts are inevitable and hard to locate/isolate.
Brian
Offline Mr. Ron
#7 Posted : 27 October 2024 19:18:51(UTC)
Mr. Ron
Thanks for your input. I think I will go with the styrofoam trench approach since most of the layout will be on a 2 foot shelf (already there).
thanks 1 user liked this useful post by Mr. Ron
This page was generated in 0.287 seconds.
