Offline Sgroombr
#1 Posted : 22 October 2024 07:30:44(UTC)
Sgroombr
I have a Trix 25903 (https://www.trix.de/en/products/details/article/25903)
I use iTrain running Dcc (126) protocol
I can operate functions:
F0- headlights
F2- operating sounds
F3- horn
F5- cab lighting
F7- lights
F11- couple manoeuvre
F12- couple together.
All others (F1, F4, F6, etc) I cannot get to work anymore.
Is there a specific Cv that I need to adjust to get these operating again?
What are the CVs that control these functions?
#2 Posted : 22 October 2024 09:21:07(UTC)
F6 is "ABD off" - you only notice a difference when you run the loco manually.
F1 and F4 are for Telex. Maybe they are controlled via SUSI.
When Telex no longer worked on my Köf III, I made a decoder reset and Telex was back.
IIRC I only tried to reduce the brightness of the headlights and as a result Telex no longer worked. A reset helped.
Offline Sgroombr
#3 Posted : 22 October 2024 09:31:54(UTC)
Sgroombr
Thanks. I applied a reset with no luck (CV8 = 8) . In general the functions missing are sound functions
Offline rhfil
#4 Posted : 22 October 2024 14:19:27(UTC)
rhfil
You might have a bad speaker. If you have a multi-meter the simplest check is to see if there is continuity through it. That is the first check you should now do.
#5 Posted : 22 October 2024 20:50:13(UTC)
F0- headlights
F3- horn
F5- cab lighting
F7- lights
What digital system do you use?
It seems you have some lack of contact between system and the iTrain running.
Try to test only with the digital system running the locomotive.
Offline Sgroombr
#6 Posted : 23 October 2024 02:56:43(UTC)
Sgroombr
Hi, I have tested. Bothe speakers have continuity.
Offline Sgroombr
#7 Posted : 23 October 2024 02:59:13(UTC)
Sgroombr
F0- headlights
F3- horn
F5- cab lighting
F7- lights
Hi, I have a Digitrax DCS210+ . I have the same issue when using the handset (DT6020) and using its function buttons
Offline Sgroombr
#8 Posted : 23 October 2024 03:44:58(UTC)
Sgroombr
F0- headlights
F3- horn
F5- cab lighting
F7- lights
Offline Sgroombr
#9 Posted : 23 October 2024 06:30:49(UTC)
Sgroombr
F0- headlights
F3- horn
F5- cab lighting
F7- lights
Hi, I thought more about what you were trying to diagnose. I did it again and only used the Digitrax control without iTrain and all the functions worked using the had control (PROGRESS!). So therefore it is likely to be something to do with the iTrain interface?
#10 Posted : 23 October 2024 17:39:39(UTC)
Exactly!
However i am not expert about iTrain but can you check at iTrains homepage and look after if there is information can help and support you when you use Digitrax system?
For some years ago i start look at Digitrax system to control trains with pure DCC protocol.
I did found out some problem about Digitrax when i did start read pro and con.
Did decides by not buy the Digitrax system.
Hope you can fix the problem about iTrain.
This page was generated in 0.474 seconds.
