Offline Zbyszek
#1 Posted : 09 October 2024 12:26:02(UTC)
Zbyszek
Poland
tory.pdf (122kb) downloaded 55 time(s).
Hello BigGrin
I have become the happy owner of a Marklin 29244.
I would like to extend the tracks according to the drawing I posted on the forum. I used SCARM software. On the drawing I marked the place where the tracks are slightly shifted but the program does not detect the error.
Therefore I would like to ask if this will work well? Thank you in advance for your answer. BigGrin
thanks 1 user liked this useful post by Zbyszek
Offline rhfil
#2 Posted : 09 October 2024 15:06:39(UTC)
rhfil
There is a bit of give and take with ctrack. Usually if you are pretty close it will work.
#3 Posted : 09 October 2024 15:19:06(UTC)
Re; give and take: Not too much though. Especially on curving gradients. If the horizontal plane is off where the track join, the center studs can catch the couplers. Even on strait- way's. If the inside or outer rail has a gap, the Loco's or cars can derail, and you may have a current continuity gap. You can shim under the uneven track joints and sections to even this up. You can hide shims of wood, or other materials like rubber, or plastic with Lichen or other foiliage materials.
Offline BenP
#4 Posted : 09 October 2024 15:33:08(UTC)
BenP
Hello BigGrin
Scarm has adjustable tolerances for gaps and angles. Make them smaller and mismatches appear. I use M track, which has greater mismatch tolerances than click c track.
Ben
Offline Zbyszek
#5 Posted : 09 October 2024 15:50:31(UTC)
Zbyszek
Poland
Thank you.
I set the tolerance to 1 mm, and at the marked point at the cross there is a gap of 1.2 mm.
Maybe someone has an idea how to do it correctly?
Offline rbw993
#6 Posted : 09 October 2024 16:09:29(UTC)
rbw993
It' will be fine. The layout is flat and big (has enough pieces) to be flexible enough to compensate for the 1.2 mm offset.
Roger
Offline Zbyszek
#7 Posted : 10 October 2024 09:43:09(UTC)
Zbyszek
Poland
So I can buy tracks and assemble my project. Hopefully it will work. Thanks for your help :)
Does anyone have something similar?
#8 Posted : 10 October 2024 13:42:06(UTC)
No, not since we were 5 years old... BigGrin
(To the politeness police; It´s a joke, dont get all worked up!)
Offline Zbyszek
#9 Posted : 10 October 2024 13:51:56(UTC)
Zbyszek
Poland
Laugh Laugh Laugh
Unfortunately, I don't have a permanent layout.
The tracks will be laid out every now and then to play with my 2-year-old daughter. That's why I came up with something that will give more variety than driving in circles.
I already have a digital set 24802 and I'm thinking about how to diversify it.
thanks 3 users liked this useful post by Zbyszek
#10 Posted : 10 October 2024 13:57:17(UTC)
When I first bought any C track in 2000, I had a larger flat oval with R2, and a siding with R1 as well, with the 2902, and 2904 extension sets which included both left and right narrow and wideer turnouts. I still have it all, but some of the first C track that was made with BASF plastic got brittle and cracked. The turnouts didn't, so when I built my new layout, I added solenoid motors to them, and use M 83 external decoders.
This page was generated in 0.455 seconds.
