Offline maxgand
#1 Posted : 07 October 2024 21:47:38(UTC)
maxgand
Buonasera, vorrei digitalizzare Marklin BR 3155 con motore e decoder sonoro di Marklin.
C'è sul forum descritto come fare e quali prodotti acquistare per la digitalizzazione?
Grazie
Saluti
maxgand
In English for the rest of us:
Good evening, I would like to digitise Marklin BR 3155 with Marklin engine and sound decoder.
Is there a description on the forum of how to do it and which products to buy for digitisation?
maxgand
Edited by moderator 08 October 2024 10:17:43(UTC)  | Reason: Provided the English translation.
thanks 1 user liked this useful post by maxgand
Offline mario54i
#2 Posted : 08 October 2024 10:02:13(UTC)
mario54i
Il procedimento è lo stesso, cambia il decoder.
Same operation, just another decoder.
#3 Posted : 08 October 2024 13:31:21(UTC)
Bon giorno' Mario. Installing a digital or sound decoder won't give optimal motor running control because #3155 has a 3 pole armature and a field coil. If that is ok with you, fine.
Otherwise, if you can find a 5 pole armature retrofit kit with a field magnet, that will be better. The Marklin basic decoder for the former I describe, and the SD3 sound decoder for the latter. One has electric locomotive sounds on it, or you can have your dealer install custom sounds.
Offline Ross
#4 Posted : 10 October 2024 03:25:51(UTC)
Ross
Hi Massimo,
You may like to read my article upgrading the BR111 locomotives see below.
BR111 article
Hope you can make use of it.
The link has been corrected.
Grazie
Saluti
maxgand
maxgand
Edited by user 09 November 2024 21:07:53(UTC)  | Reason: Not specified
Ross
thanks 3 users liked this useful post by Ross
Offline maxgand
#5 Posted : 09 November 2024 17:49:17(UTC)
maxgand
Grazie Ross per la cortese e veloce risposta, ma il server non riesce ad aprire la pagina.
Puoi inviarmi la tua conversione in altro modo.
T
Grazie maxgand
Grazie
Saluti
maxgand
maxgand
Offline Ross
#6 Posted : 09 November 2024 21:09:42(UTC)
Ross
Hi Massimo,
The link above has been corrected.
T
Grazie maxgand
Grazie
Saluti
maxgand
maxgand
Ross
Offline ChrisKenna
#7 Posted : 10 November 2024 00:49:58(UTC)
ChrisKenna
Hi Massimo,
BR111 article
Grazie
Saluti
maxgand
maxgand
Truly impressive technical and explanatory skills, Ross, thanks for sharing.
Regards, Chris
With respect and thanks to Ngannawal, Ngambri and all First Nations people
thanks 1 user liked this useful post by ChrisKenna
Offline Ross
#8 Posted : 10 November 2024 03:32:04(UTC)
Ross
Hi Chris,
Thanks for your kind comments. I hope you find things of interest.
Regards, Chris
Ross
Offline maxgand
#9 Posted : 10 November 2024 10:22:00(UTC)
maxgand
Hi Massimo,
Grazie Ross
Grazie Ross
Saluti
maxgand
Grazie
Saluti
maxgand
maxgand
This page was generated in 0.521 seconds.
