Offline Mr. Ron
#1 Posted : 02 October 2024 01:53:07(UTC)
Mr. Ron
Single engines often have a problem when running slow to stall on turnouts and dirty track sections. Will running multiple engines all in the front or at the rear prevent power dropout? What I am trying to say is; if the first engine hits a dead spot in the track, will a second or more engines push the lead engine past the dead spot and so keep the train running? An example would be an A and B diesel where both units have power pickups.
#2 Posted : 02 October 2024 08:10:53(UTC)
This may work to some extent. But don't be surprised when you find lost traction tyres on your layout.
If one engine stops, the wheels on the other locos can start slipping.
Having two connected sliders can lead to issues with booster sections and braking modules.
#3 Posted : 03 October 2024 19:30:05(UTC)
If using traditional Maerklin signals, the locomotives that are not yet in the "stop" zone will continue pushing the train. Given that the cars between the engines are lighter than the engines themselves, this can provoke a derailment if they exert too much pressure on the intermediary cars.
Using two locomotives tandem removes this danger and may help with power gaps, but if one of them does stop, it can result in strain on the second locomotive as it tries to keep motoring. The motors are strong enough to take the wear and tear, but traction tires can deform and will leave more residue on the tracks, worsening the problem down the road.
Offline Mr. Ron
#4 Posted : 03 October 2024 21:21:38(UTC)
Mr. Ron
Thank you for your input. I just dismantled my layout that had 12 turnouts. The engine would stop at a turnout, but not at all turnouts, I guess keeping the track clean and oil free is the solution. I am in the process of moving into a bigger house and redesigning my new layout.
Offline Bill L
#5 Posted : 04 October 2024 02:59:25(UTC)
Bill L
I connect the red wire (power) from both loks together (disadvantage is you cannot uncouple them because you have an outside wire from one lok connected to the other) but the advantage here is you have both shoes to pick up current for both loks. This way, either both loks run together or both stop together at a slow down module/stop signal together.
thanks 1 user liked this useful post by Bill L
Offline cintrans
#6 Posted : 05 October 2024 01:15:23(UTC)
cintrans
Aruba
Ron
It is not that easy either to match the exact same speed on both engines when the run independent from each other...
A better way is to connect two engines permanent to each other (double traction), but connect both motors on one decoder.
I have two A-B-A F7 units like that, they run fantastic and have lots of power to pull a lot of freight cars!
Jean-Pierre
This page was generated in 0.298 seconds.
