Offline JayMac
#1 Posted : 29 August 2024 02:55:26(UTC)
JayMac
This may have been asked before, but I was wondering if you can combine the two systems. My thought process is to have Ecos as the main system with CS3 being primarily running and programming and Trix models I have.
#2 Posted : 29 August 2024 06:37:31(UTC)
Short answer…no! These are digital system and cannot serve together.
Offline DasBert33
#3 Posted : 29 August 2024 08:04:48(UTC)
DasBert33
The answer is more nuanced than that. You cannot connect them over the CAN bus and use them fully integrated or use the output of both, but if the ecos is the main device you can connect the CS to the sniffer input. You will have to use motorola or dcc protocol (not mfx afaik) on the cs for the things you want to control on the ecos. Just lookup 'sniffer' in the ecos manual.
thanks 2 users liked this useful post by DasBert33
#4 Posted : 29 August 2024 11:24:00(UTC)
Hi Jay
Fervent Märklinist here.
The CS3 is excellent for all uses of Märklin stuff (Locos, decoders, sensors, event management, programming decoders and their sounds).
The ECOS is an aging system excellent for non-Märklin gears (Railcom, etc).
Compatibility?
To my knowledge neither the CS3 nor the ECOS can be the slave or the master of the other one.
Power?
Both units can be supplemented by boosters of the SAME BRAND and the CS3 when fed with a Märklin 100VA power supply delivers 5A. My layout is powered like this with a CS3 + 60101 and has a permanent connection with 26 locos, lighted trains, more than 70 switches / signals and its draws 3.8 A
My advice (if I may) If like I you have a majority of Märklin locos and decoders AVOID using third party electronics as operation and programming can easily turn into a nightmare (programming an ESU LokSound without a LokProgrammer, whereas with a CS3, programming an mSD3 is easy).
ESU ECOS is NOT FULLY MFX (permanently ask you to go back to DCC for programming)
Offline DasBert33
#5 Posted : 29 August 2024 14:51:25(UTC)
DasBert33
Hi Jean, Jay,
Your reply sure is biased towards Marklin, you must have stock options :-). Just wanted to note that I am a Marklin user that has happily been using Ecos(1) for a long while now (since 2008). I choose the system because of the openess compared to Marklins, and you get a lot more value for the money. Also check decoder prices of 3rd party suppliers. The ecos comes with a powersupply, with Marklin you have to purchase that seperately, and the current rating is higher.
Again, with the sniffer functionality the CS3 (or any device) can be a slave to the Ecos, but with limitations (no bidirectional communications). So that counts as some kind of compatibility. But the CS3 ecosystem is better with more connectivity options I admit (albeit very expensive because you need dedicated equipment/wiring each time).
I don't understand your 'not fully MFX and needing DCC' comment. I can still use the MFX GUI interface with the latest locos/decoders. Sure there have been issues at some points where an update from ESU was needed, but these were always released timely. BTW I think Marklin had similar issues too. The main MFX thing that ecos does not support is the cab view controls and the resources simulation (mfx+). But I wonder whether that makes it worth it? Or am I forgetting something? Can the CSxs do all protocols at the same time (Motorola/MFX/DCC/Railcom) or are certain combinations unsupported?
You are also right about needing the ESU programmer for sound decoders, but you do get a better sound library as well. For regular decoders (non sound) programming works without programmer as well for me.
There is definitely one pro on Ecos for the true, classical Marklinist that you did not mention: the speed dial is a potentiometer with an end stop and reversing mechanism like on the old analog controllers. If you are a marklin purist I think that is a big pro. So no endless turning to set the speed like on CSx.
Having said all that I am thinking of purchasing a new controller (my old ecos1 still has a monochrome screen), and I am unsure what system I would pick now. A CS3 (that is also starting to get dated), an Ecos2 (also dated, but with a recent screen refresh and output boost), or something else? I would actually prefer a new CS4 or Ecos3 I think.
Sorry, did not want to hijack the topic.
Jay, if you already own both controllers I would try the sniffing, otherwise if budget is not an issue go for Marklin only like Jean recommends. But don't be afraid of running an Ecos, it is a good system that gives good value for money.
What I would not do is buy an additional main controller (CS3 or Ecos2) if I already had one (again CS3 or Ecos2). In that case I would try to make the one I have work for all setups/systems/layouts.
BR,
Bert
Bert
thanks 3 users liked this useful post by DasBert33
#6 Posted : 29 August 2024 17:52:12(UTC)
Believe it or not I have no stock with Märklin.
I only say if you have mostly Märklin locos and decoders, it is a great mistake to go for an ECOS.
Alternatively, if you love collecting items from as many brands as possible then the ECOS might be good for you.
I was recently forced to install a LokSound 5 micro into one of my locos because of very small size and it turned out being a nightmare programming from the CS3.
It turned out that you MUST have a lokprogrammer or else you must deal with a HUGE number of CVs. Doing the same with a CS3 is a piece of cake (No Märklin Lok Programmer needed.
On the other hand the CS3 does all the control of locos, of decoders, of sensors and the sound programming oif decoders all of this with a very user-friendly way.
The only central station I had from ESU was the CS1 60212. It still "works" but it is pure shit and returned to its box 6 months after purchase.
Only a matter of personal choice but I never would advice a friend Märklinist to buy an ECOS.
MFX editing ESU does not use MFX to program MFX decoders and must go through DCC. The ECOS may mask this but using an ESU decoder with a CS3 is quite unpleasant so the family is quite important (each device is made to work with others in the same family.
Offline DasBert33
#7 Posted : 29 August 2024 19:57:37(UTC)
DasBert33
I cannot confirm your experiences to be honest. No need to bash ESU or hype Marklin like that.
Let's just agree to disagree.
Just curious what direction Jay will go now.
Bert
thanks 1 user liked this useful post by DasBert33
#8 Posted : 29 August 2024 22:48:25(UTC)
Agree with that. ESU. Did the CS1 which was rubbish and went in the bin when the CS2 appeared. Many like the ESU controller and I am sure it does a good job and will work well but don’t expect it to work along side items made by Marklin. ESU do decoders which understand are excellent. Marklin items are made to work with Marklin and it is no surprise if there are problems with other manufacturers items. I expect ESU will have a forum to help with their stuff although many in here can also help as we do with a roco and PIko etc.
Edited by user 30 August 2024 10:34:48(UTC)  | Reason: Not specified
#9 Posted : 30 August 2024 10:39:51(UTC)
I agree David. Just as a CS 3 doesn't auto recognize a Zimo decoder for example. Is it the railcom? However, a CS 3 does auto recognize an ESU M4 sound decoder.
I too considered an ECOS for the throttle toggle feature, but having owned Marklin digital since the late 90s, and a few new mfx locos, the CS 3 won me over. The full touch screen vs. the buttons as the CS 2 and ECOS as well.
#10 Posted : 31 August 2024 11:17:12(UTC)
Are you sure about that?
Zimos MS sound decoder support mfx and CS3 can also auto register Zimo decoder.
#11 Posted : 31 August 2024 12:16:07(UTC)
Not my Roco Goofy. It's a few years old though. To change the address, it must be on the CS 3 programming track.
Offline rhfil
#12 Posted : 31 August 2024 15:42:39(UTC)
rhfil
According to Marklin Dudes the CS3 does a unique handshake with Marklin mfx decoders and, possibly because of that, do not need to be on the programming track to be reprogrammed. I am not sure if that applies to any other decoder. Apparently not. The listed digital address of the decoder applies to operating when not in mfx mode.
This page was generated in 0.416 seconds.
