Offline caldude53@att.net
#1 Posted : 09 July 2024 07:04:44(UTC)
caldude53@att.net
Does anyone have experience converting to LEDs on older locos? I've managed to remove the incandescent bulbs on my 1970s BR 103 (#8854) and solder on rice-grain LEDs with tiny resistors. Upon testing, the new lights are unreliable. Sometimes the wrong end lights up (the rear lights up while moving forward and vice versa), sometimes the LEDs are very dim or don't light up at all... I seem to have missed something.
Is that a capacitor on the circuit board? Does it have anything to do with the lights?
Thanks!
Offline Carim
#2 Posted : 09 July 2024 11:15:16(UTC)
Carim
I haven't tried this conversion myself, but there are diodes on the board that may cause you problems. This video explains this:
?si=R1WWMzvo75ebhKrd
see from about 4:20
Here is another (not great) video showing the conversion just using led.s; I don't think he touches the board at all:
?si=sAAKQ83MZHXZhrmx
Hope this is of some help.
Carim
Offline Wheelflat
#3 Posted : 09 July 2024 18:24:42(UTC)
Wheelflat
Märklin's diodes from the 70's are starting to fail. I have two early 8875's where diodes have failed closed circuit, causing the bulb to be illuminated in both directions.
Perhaps they can't be relied upon for controlling you leds.
In any case you need to confirm the polarity of the diodes on the circuit board correspond to the leds
thanks 1 user liked this useful post by Wheelflat
Offline Zme
#4 Posted : 10 July 2024 06:20:56(UTC)
Zme
Hello, hope all is well.
I just don’t have the skills needed to add an LED on a circuit board so I have never tried this. To me, this would be risky business and with my luck, I would damage something else on the board. I believe the videos posted, includes a seller who had custom made LED modules which could just be placed into the same location as the original bulb. For some reason, this seller no longer offers them. I did manage to purchase a few and they worked very well. A big improvement for certain.
Now that circuit board issues were brought up, a while back I purchased a replacement circuit board for one of my older locomotives. To my delight, the board also had LEDs attached to both ends. These work very wells also. Here is a link to the vendor, he might still have some of these in stock which will replace the circuit board on your locomotives. This might solve two problems at once. If you have very early 8875s the circuit boards changed a some point moving the brushes directly to the motor and the board might not be available. Let the seller know what you have.
https://zscalehobo.com/m...klin_numbers.html#spares
If this doesn’t pan out for you, LEDs are available for overseas vendors, but might be more expensive. Shipping is also a concern. I would contact them beforehand to make certain they will sell to you and to confirm all costs.
https://www.z-hightech.d...g=6&sprache=englisch
I have purchased from this site before and had no problems. Expect a long time for delivery, might be two or three weeks in the mail, make sure you get the tracking number.
Hope this helps. Take good care. If you locate a seller of zscale LEDs let us know, we all would like to have them!
Zme
Offline Poor Skeleton
#5 Posted : 10 July 2024 22:06:50(UTC)
Poor Skeleton
Thanks!
To answer the easy bit first, the capacitor helps stop the LED from flickering, which can be particularly bad if your track/wheels are dirty
To get to the more complicated stuff (and apologies if what I say here is patronising - seeing as you've got this far you may know most of this already).
LEDs are directional devices, which is to say they'll glow when the voltage is applied in one direction, but not the other. This may answer your observation that some LEDs light up in the wrong direction of travel. In this case, flip the LED round and you should be in business.
Locomotives with directional lighting will have a diode on the board to control the flow of current to the incandescent bulbs. These are quite susceptible to damage so the best thing is to remove them altogether and link them out. On diesel locomotoves these are the small disc things at eaither end of the circuit board. It's easy enough to unclasp the metal clip that holds them in place, memove the disc diode and then replace the clip, making sure it makes contact with the central contact point on the PCB. Once that's done your LEDs will take care of themselves regading directional lighting up.
If the disc diodes are still fitted but in opposition to your LED, the LED won't light up. Flipping the LED round will sort this out, but I would also recommend getting rid if the diode which does nothing useful now and only delays the point at which the LED lights up.
As for varying brightness, different colour LEDs need different levels of current - a white or blue LED can be blindingly bright with just a few hundred microamps, whilst a red or green might need ten times as much. What value resitors have you fitted? I'd suggest something like 1k would be a good starting point for red, green or yellow, whilst 10k or 22k might be better for white of blue.
A final point is that LEDs can be quite sensitive to prolonged heat, particularly the white and blue ones, so if you've been a bit slow with your soldering that might have damaged them. If you have a multimeter you can check them out with the continuity/diode check. Obviously they'll only light up with the connections the right way round, but you can check they do light up this way.
Hope that's of help
Chris
thanks 3 users liked this useful post by Poor Skeleton
Offline Numo
#6 Posted : 12 July 2024 11:06:08(UTC)
Numo
Macau
Hello new on the forum is there any where we may purchase z scale marklin passenger car with interior lights, thanks
thanks 1 user liked this useful post by Numo
#7 Posted : 14 July 2024 23:23:48(UTC)
Poor Skeleton
I've seen them on ebay from time-to-time but that's about it.
The difficulty is getting power to from the wheels to the interior of the coach itself. There's no easy way to accomplish this and they all add significant friction to the movement, so your locos will end up being able to pull even fewer coaches.
Chris
#8 Posted : 15 July 2024 04:25:54(UTC)
caldude53@att.net
The LED problem is fixed! I wish to thank: Carim of London, Zme of West Texas and Chris of Cambridge England for some very helpful advice. Love
The problem was with the diodes under the cover plates on either end of the circuit board. (I wouldn't have known they existed because Marklin's exploded parts diagram doesn't show them.) Carim brought them to my attention and he supplied links to a couple of helpful YouTube videos. I removed the diodes, installed tiny washers to stand in for the diodes, installed my LEDs and resistors and viola. I had to experiment to find the correct position of the LEDs, but this was pretty easy.
Anyone who contemplates doing this conversion might benefit from my experience. The "rice-grain" diodes (with the appropriate resistors) came from Amazon:
https://www.amazon.com/dp/B091BS...product_details&th=1 (see NOTE below)
These are actually a bit bigger than rice grains with dimensions of LENGTH 6.15 to 6.66mm and DIAMETER 1.95 to 2.26mm. (The sizes vary because it appears they're hand-made (or partly hand-made.) It's challenge to shoe-horn in the LEDs/resistors (resistor LENGTH 5.7 to 5.9mm, DIAMETER 2.17 to 2.25mm). I soldered everything together, then bent the LEDs back over the resistors. Oh, and I reused the lamp bases that the incandescent bulbs were attached to. Skill with a soldering iron was a must; everything is just so tiny.
NOTE: If I had it to do over again, I would have searched for LEDs that are even smaller than the ones I got. In order to fit it all in I ended up slightly modifying the clear plastic inserts that direct light through the headlight holes in the body shell. This was straight-forward, but it was yet another step in a fairly lengthy process.
Thanks again!
Sam
thanks 1 user liked this useful post by caldude53@att.net
Offline DasBert33
#9 Posted : 15 July 2024 08:24:18(UTC)
DasBert33
Do these 'rice grains' exist based on 0402 or 0201 sized diodes? That would be smaller. And is it possible to get them with resistors inside? I wonder what type of resistors you used. You should probably try to avoid the big axial resistors like the ones that came with the leds, and use smd 0402 or 0201 resistors instead. Would it be possible to use the footprints where the mentioned diodes were mounted originally for the series resistors?
Anyway, most of my HO conversions I do with smd 0402 leds and 0603 resitors, I admit I dont do tiny Z.
Br,
Bert
thanks 1 user liked this useful post by DasBert33
#10 Posted : 15 July 2024 15:58:12(UTC)
You have been a member since:: 23/07/2014(UTC)
Br,
Bert
Be very careful using 0201 and smaller components, these are classed as dangerous to human health as it is possible to breath them in and start asbestosis type problems in the lungs. Always use a mask when handling them.
Offline DasBert33
#11 Posted : 15 July 2024 21:13:59(UTC)
DasBert33
Yes 0201 is small, but to inhale these you really need to make an effort I think. I use these in my work as electronics engineer quite often and I never noticed issues and never felt the need to use masks. You will need a good magnifier, soldering iron and tweezers to use them though, so for this topic, maybe start with 0402 components first.
btw, i recently purchased some warmwhite 0402 leds from a german online shop called 'ledandmore' and i am very pleased with the price and led color.
#12 Posted : 16 July 2024 01:02:49(UTC)
caldude53@att.net
I'm happy to know that smaller LEDs exist. I'll keep this in mind for future conversions. I'm new to LEDs/diodes & resistors. The resistors that came with the diodes are quite small & barrel-shaped. (dimensions supplied above) They seem like garden-variety resistors to me, only quite small.
Thanks for the advice!
Sam
Offline parakiet
#13 Posted : 16 July 2024 08:29:52(UTC)
parakiet
Views messages in topic : 298
Parakiet of Belgium loves this topic! LOL
thanks 3 users liked this useful post by parakiet
Offline Zme
#14 Posted : 18 August 2024 04:25:29(UTC)
Zme
Hello everyone. Hope all is well.
I purchased some of the Marklin LED inserts.
So far I have two of my locomotives converted. (88941,3). It is nice to see the locomotives lighted even at a slow speed. In reverse these inserts shut off however.
They are correct when they say these do not work with all locomotives. The wafers these are made on are very thin. I guess to make them more compatible. The original wafer for the 8953 inserts are at least twice as thick. The original inserts are a tight fit by design. I tried the new insert in a 8899 and a 8895 but could not get them working. The LED insert is loose in the slot.
Without modifications the new inserts will not make contact. Somehow bending the chassis insert contacts may be necessary but I have not tried this yet. I don’t know if it is possible to make the insert contacts thicker by dropping a bit of solder on each. Anyone have experience with this and have a solution?
Thanks, take good care.
Zme
Offline Carim
#15 Posted : 18 August 2024 13:21:11(UTC)
Carim
Hi Dwight,
Are you talking about the CK LEDs or a Märklin spare part? If it is Märklin, could you please give us the spare part number?
Carim
Offline Zme
#16 Posted : 18 August 2024 16:20:36(UTC)
Zme
Here is a link to the sellers website:
https://zscalehobo.com/marklin/250391.html
This is a Marklin item, made in Hungary. I just noticed the diagram with this and it seems to show installation on a newer version Locomotive.
On the Br 94, it fit snugly and worked perfectly. The only issue I noticed is that there is a cover sleeve over the light bulb and this does not necessarily transfer over to the LED. The bulb is long, the LED is just a small nub. I transferred one sleeve with no problem but the other must have melted a bit and will not come off of the bulb. I have to work on this. Without this sleeve I think some of the light bleeds thru where you don’t want it.
Take good care.
Zme
#17 Posted : 19 August 2024 06:01:18(UTC)
caldude53@att.net
Thanks for the information!
I recently talked to ZscaleHobo about these replacement LEDs. I asked if they could be used in non-steam locos (the listing says they are for steamers). I was told that they might work in non-steamers, but there was uncertainty in the answer. Now I know why. It's the thickness of the base!
Having made my own LED replacements for my #8858 BR 103 electric, I would not hesitate to add a layer of solder, as Zme suggests, to make the bases thicker. I doubt a lot can go wrong, but I have yet to buy some and to try this "fix."
Good luck!
thanks 2 users liked this useful post by caldude53@att.net
Offline Zme
#18 Posted : 19 August 2024 06:44:13(UTC)
Zme
Thanks for your reply.
I have a newer steam locomotive 88744. I looked up the spare parts list for this. The part number of the light module is listed as 250391.
This light module is actually the replacement for the newer line of steam locomotives, at least in this example.
These still might work on other varieties of locomotives but may require some adjustments. Correct fitting modules may be ordered from https://www.z-hightech.d...g=6&sprache=englisch but this might be more expensive when adding shipping.
I will eventually try to make them thicker with some added solder and see what happens.
I already tried these in the railbus and Br 110 series without luck. Modifications would be necessary.
Take good care.
Zme
PS. Just checked 88995 and this model lists this new module as the correct replacement part. Something changed because this new module would not work in 8899. This once again proves, nothing is easy with Z.
Offline georgi UK
#19 Posted : 19 August 2024 22:59:42(UTC)
georgi UK
Would like to know where my post disappeared that showed the LED replacement??! Was liked by Zme then went?
Offline Zme
#20 Posted : 20 August 2024 02:22:21(UTC)
Zme
Hi. Hope all is well.
That seems impossible. Are you sure it was this topic?
Once posted, I don’t think there is a way to remove it.
Perhaps the administrator for the website could assist.
Hope it works out. Take good care.
Zme
#21 Posted : 21 August 2024 03:44:31(UTC)
caldude53@att.net
I've already endorsed adding a thin layer of solder to LED bases, so they fit snugly in some locos. Now it occurs to me that it might be possible to gently bend the contacts on the engine's circuit board to achieve a snug fit. And in cases where the looseness of LED base is extreme, it might necessary to do both: add layers of solder AND put a slight bend of the contacts.
But I don't really know. Confused I haven't yet seen these new Marklin LED replacements, nor the locos in question.
Good luck everyone.
Zme
Offline Zme
#22 Posted : 21 August 2024 06:01:31(UTC)
Zme
Hello hope all is well.
Here is a photo showing the difference in the light modules:
There is a significant difference in the thickness of each. I am not certain this difference can be made up with bending the holder and adding solder.
Take good care.
Zme
#23 Posted : 21 August 2024 12:51:08(UTC)
Take good care.
Zme
I would be cautious about trying to add solder to build up the thickness. Solder is very soft and will collapse under spring pressure, over time, eventually causing intermittent contact. To build up that sort of thickness I would look at soldering a piece of copper sheet onto the new lamp unit to make it thicker.
Zme
#24 Posted : 22 August 2024 02:44:00(UTC)
caldude53@att.net
Wow, those new bases are indeed very thin! It may be that adding solder and even bending the mount may not work, as you say. What's Marklin thinking? Confused
Here's another idea: I used the old thicker bases when I made the conversion to LEDs. It was pretty easy to heat the solder, then use a "solder sucker" to remove the molten solder. The old incandescent bulbs just fell away. I then soldered the LEDs and resistors to the blank bases. BUT, upon studying the new LED base, it seems that removal of LEDs from the thinner bases might not be so simple. I'd have to physically inspect one to make a judgement call.
Your idea of adding copper sheet to those thin bases is a good one. I think you could use brass sheet in place of copper, if brass is easier to get. (Brass contains enough copper that it ought to make a suitable substitute.) I know brass shim stock is available from industrial suppliers like Grainger, MSC Direct and McMaster-Carr. Being shim stock, it comes in varying thicknesses. Also, solder sticks to brass quite readily.
Again, good luck!
#25 Posted : 22 August 2024 22:59:26(UTC)
Poor Skeleton
Again, good luck!
I've also been trying to think of something you might have to hand that you could use to bulk up the thickness of the base. The best I can come up with is a sliver of (non aluminium) tin can soldered to the base. A couple of small (M2?) washers might also do the trick. Having said that an off-cut of rail filed flat or a crushed rail joiner would probably also do the trick.
I wasn't initially keen on the idea of a blob of solder - my concern being that it would soon oxidise and possibly lose contact - but I don't think that's likely to be a real problem and worth a try. If it doesn't work it would be easy enough to supplement it with something else.
Any help?
Chris
#26 Posted : 23 August 2024 02:45:27(UTC)
caldude53@att.net
Hi Chris,
In the absence of brass shim stock, I would fall back on a piece of heavy-duty aluminum (or "aluminium") foil. Aluminum is an excellent conductor. I just don't know how well solder will stick to it. I would use an acid-based flux so you have a fighting chance at a solid bond. You can of course fold the foil to whatever thickness is needed.
I look forward to hearing how you make out with this. Sooner or later, I expect to be converting my own LEDs.
Good luck!
Sam
#27 Posted : 23 August 2024 21:33:21(UTC)
Poor Skeleton
Hi Chris,
Good luck!
Sam
It's just not possible to solder to aluminium - it oxidises too quickly.
Chris
Zme
Offline Zme
#28 Posted : 24 August 2024 02:31:24(UTC)
Zme
There have been very many good ideas about this topic. Thank you all.
I tried a few of the suggested solutions but did not locate brass or copper, and the washers I purchased were too large. I might need to check a specialist hobby type store and could possibly come up with something that works. I will continue to check one of these places next time I am out and about.
In the meantime, I did get the modules to work in a BR 110 and a small steam train BR 74. For the 110, I bent the light contacts on the circuit board downward and the contacts on the lower isolator were bent upward. I have an old tool which makes the bend on the circuit board easier. Picture a small screwdriver with the end removed and a small slot cut in the blunt end. I did not want to make very many repeated adjustments so make my first bend a good one on the circuit board. This material seems a bit inflexible. It worked out and with two modules I have a white light in each direction.
For the 74, I had to remove the brushes and then bend the light contact to engage the module. The contact holds the light and condenser. This material is copper and it bent easily. I will probably add some kind of glue or something to keep the module steady.
I have used up all of my LEDs and would need to purchase additional ones. Perhaps Marklin will produce modules which require less adapting. It could happen.
It would be better if the 110s light was white in the direction of travel with a trailing red. The white light on the steamer is more prototypical but having it shut off in reverse might not be totally accurate. If anyone is aware of how this is done let me know. I heard steamers forward lights stay on in white regardless of the direction of travel but I have some locomotives which have reverse lights in white.
Again thank you for the good ideas. Take good care. Maybe you can find a tool similar to the one I described. It helps to adjust the cooper contacts on the top of boggies of 110s also.
Zme
#29 Posted : 26 August 2024 01:39:35(UTC)
caldude53@att.net
I'm happy to hear that the LED conversion has a solution! Love
Yes, it would be great if Marklin came out with a direct LED replacement for older locos. Meanwhile, it's not too terribly difficult to remove the incandescent bulbs from their bases and solder on resistor/LED combinations, as I have. And since I learned that even smaller LEDs are available, it will be that much easier to fit the replacements under the body shells.
Chris has informed me that you can't solder aluminum foil. In that event I would attach the foil to the base using a TINY dot of superglue, small enough to still allow for good contact between foil and base. (This assumes you still want to shim the base to make it thicker.)
Cheers y'all!
Sam
Offline Zme
#30 Posted : 03 September 2024 02:02:53(UTC)
Zme
I did work with the Br 74 type locomotive. I used a piece of solid core, single strand wire, flattened and inserted into the light slot. Gives a bit more stability to the light and is working.
These locomotives are nearly twenty years old. Seems worth the effort to get the light modernized. What do you think, is it worth $15.00 and shipping.
Take good care.
Zme
#31 Posted : 03 September 2024 02:21:52(UTC)
caldude53@att.net
Take good care.
Zme
I agree that these older locos are worth maintaining and upgrading. I got my #8854 BR 103 Electric in the late 1970s. I cherish it. Now if I could only find the 5-pole motor for it... they're like finding hens teeth! Sad
Sam
Zme
Offline Carim
#32 Posted : 03 September 2024 13:04:14(UTC)
Carim
If you look in the comments to the video below, the poster describes how he gets better performance out of 3-pole motors:
https://youtube.com/shor...ZvRI?si=T4Ygzq-vDgJWa1rs
Hope that this is of some interest.
Carim
Offline Zme
#33 Posted : 07 September 2024 19:40:22(UTC)
Zme
I agree, those are good pointers for tuning the three pole locomotives and likely these tips are good for a five pole too. Clean, smooth parts are always beneficial.
If I understand correctly, it takes a bit more power to get the 3 pole motor turning, but it has more speed once moving. This motor might be a bit more noisy.
The 5 pole starts to move with less current, might have a bit less speed, but in most cases is quieter. I don’t know why, but put the shell on a Br 110 or similar and there is a growl which you might think is the motor. Perhaps all the gears in the bogies just make noise. Does anyone recall a comparison test of the pulling power of each motor.
Do the basic characteristics of each of these motors influence the performance of a snail controller? Perhaps.
These two motors are long lived, reliable, and likely will be around for some time. Fine tuning is always a good thing.
Take good care.
Zme
This page was generated in 1.183 seconds.
