Offline revmox
#1 Posted : 16 August 2024 04:14:42(UTC)
revmox
It seems that I may have a chance to build a new layout. It would be in part of an old garage and 3000x5200 is available as shown in the images.
My initial choice is whether to do a complete loop around the area with standard 600 and 900 wide benches for a simple continuous loop that could maybe use grade crossovers to double the effective running length OR to do a dog bone layout with 1200 wide sections at either end to enable return R2/R3 curves.
My question is, if I go with the continuous loop version and "duck under" access isn't acceptable, what is the best way to get walk in access? What are the thoughts on the best way to go - lift out removable section, hinged lifting section, removable bridges across the gap, whatever - or go with the dog bone?
Maybe there is a much better solution, but it must allow for continuous running as I'm not into end-to-end running, dead end termini or shunting.
If it makes any difference, I also favor the 50s - 70s small branch line style of things with trains usually less than 1m long so completely avoiding R1 isn't essential.
Thanks in advance, Mark.
thanks 2 users liked this useful post by revmox
#2 Posted : 16 August 2024 05:57:00(UTC)
In my last layout, I had a gap and then built a bridge over it. However the tracks were about 1.4m off the ground so that I could easily duck under the bridge to sit on a bar stool and watch the trains. This also gave me room for a small bench/desk (initially) to work on locomotives etc. You need some extra board alongside the track so that you can rest your beer/rum glass. BigGrin
Offline revmox
#3 Posted : 16 August 2024 07:53:09(UTC)
revmox
Thanks Adrian,
That's given me a new point of view. My current "island type" layout has a bench height of 1050 and a clearance of 900 underneath around the edges. The 1050 is a compromise viewing height for me and the grandkids. The 900 underneath isn't fun to work under.
I went out and rolled the garage door to different heights to investigate and at 1300 getting under was quite easy. So, if I kept a baseboard height of 1050 but had a dual track bridge 1000/1200 long at a height of 1300 across the access area - that might do the trick. My consists have no trouble with a 5% grade so it shouldn't be too hard to work in a 5 metre or more grade into the plan.
Thanks, definitely worth a thought.
Also, yes, it's very important to keep a special spot for some engineering alcohol.
I use the carriages below to keep up the supply of port or drambuie during winter.
thanks 9 users liked this useful post by revmox
Offline ccranium
#4 Posted : 17 August 2024 01:02:46(UTC)
ccranium
@ Mark, Not to get too off-topic, but those are great wagons! What catalog # are they??
Brian
Offline revmox
#5 Posted : 17 August 2024 01:40:44(UTC)
revmox
Hi Brian,
Carriages are custom 3D prints along with bogies salvaged from several damaged Marklin 4473s, low side cars, found in a bunch of random bits in the corner of a secondhand shop. They are in two parts to get a drop floor for enough clearance through tunnels.
They were my first attempt at printing something serious when I got a 3D printer and I think I could do a much better job now. There's a slight chance that the 3D files may still be on one of my backup drives. If I find them I'll edit in a link.
Cheers.
thanks 1 user liked this useful post by revmox
Offline Harvey
#6 Posted : 17 August 2024 02:23:00(UTC)
Harvey
Curious, what 3D printer do you use. I happen to have, as a gift and Toybox printer and printable dimensions are 9cm (ht), 9 cm (wid), 7 cm (depth). I have printed some cargo loads (pipes and such) and would like to print a car to. Appreciate your response
Harvey
Offline ccranium
#7 Posted : 17 August 2024 03:14:53(UTC)
ccranium
"There's a slight chance that the 3D files may still be on one of my backup drives. If I find them I'll edit in a link."
Thank you; that would be great!
Offline revmox
#8 Posted : 17 August 2024 05:41:13(UTC)
revmox
We're right off topic here but I've made the 3D objects publicly available on TinkerCAD. You should now be able to find them under my username of revmox. There are two items - Low Shot Car and Copy Of Shot Base v4.
If that doesn't work for you then I could regenerate the stl and gcode files.
My wife bought me an original version Ender-3 printer as a present. It came in so handy that she insisted that I upgrade to a later version, the Ender-3 V3 SE. This has a number of very worthwhile improvements - especially the auto bed levelling. I think they are quite cheap for what you can do with them.
The print area is 220x220x250H - that's about 8.5x8.5x10 inches in olde worlde speak.
Offline ccranium
#9 Posted : 17 August 2024 23:25:38(UTC)
ccranium
Thanks again, Mark. I downloaded the files and will play with them. No shortage of shot glasses here, so at least I have something to start with.
Brian
Offline revmox
#10 Posted : 18 August 2024 00:31:05(UTC)
revmox
Good grief, how did this post get here?
The design is for 12ml shot glasses. That's the only size I could find that would fit through my single-track tunnel portals, especially if on a curve. Round top 35mm diameter, 47mm high, square base 25mm. $2 for a set of 6 at the Salvation Army secondhand shop, also fairly common on eBay. There are 60 fills from a standard bottle, so you have to schedule some extensive running to finish a bottle in a session. A great way to get family and friends interested in your model railway.
Offline ccranium
#11 Posted : 18 August 2024 17:13:33(UTC)
ccranium
Now I'm inspired to do automatic filling in my tunnels; a new type of shadow station!
Thanks again for the great info, and for the inspiration!
Cheers (with my coffee cup at this time of day...),
Brian
Guest (5)
Bridging the gap (General MRR)
by dave55uk 02/10/2023 22:45:01(UTC)
This page was generated in 0.482 seconds.
