Offline Roger W. Hooper
#1 Posted : 08 August 2024 22:31:28(UTC)
Roger W. Hooper
As my subject indicates, I need a preprogrammed decoder for 55082 (BR 241-A) and 55413 (BR 42-DB]. I am not into programming my own decoders. I am 81 years old and really don't have the background to do this particular job. Thus, I need to know where it is possible to purchase what I need for these two locos. Hopefully, someone out there has some advice.
Thanks in Advance -
Hoop
#2 Posted : 09 August 2024 00:21:57(UTC)
You dont't say what locomotives the new decoders are going in to because that will determine what decoder type you need to purchase.
I'm assuming that they are going into the original locos which presumably have the same interface as the LGB 55029 decoder - Marklin's 1 Gauge decoder.
You could ask Marklin to supply you with a new original decoder as specified in the loco's parts list, or you could buy the LGB 55029 decoder and have it programed with an appropriate sound file. Your dealer should be able to do this.
Attached is the sound file for 55082 (you need to use 7zip to unpack the zip file) but there isn't one for 55413, so someone would need to create one for you perhaps using a BR 42 H0 sound file as a base. You do need to be certain that the LGB 55029 decoder will fit into your locos.
Part number for the 55413 decoder is 262123 but it is out of stock. It looks like the LGB decoder will fit. Likewise for 55082.
M55082_Serie241A-SNCF_Spur1.zip (18,960kb) downloaded 32 time(s).
Edited by user 09 August 2024 12:28:10(UTC)  | Reason: Not specified
This page was generated in 0.515 seconds.
