Offline Marklin Nut
#1 Posted : 07 August 2024 21:06:21(UTC)
Marklin Nut
Hi everyone,
Hope there is someone out there who has some experience with iTrain PC software that might be able to help.
The Problem:
The CS2 S88 Link is reading all feedback signals in correctly. But the iTrain software is reading only the first three modules correctly and fails to read the last two modules. Is there anyone who would have experience with iTrain to be able to provide me with troubleshooting this problem? At this point I do not know if the problem is caused either by the software or by the CS2. I have communicated this problem with the iTrain forum, posted earlier today.
CS2:
The CS2 is using the Marklin CANBUS with the S88 Link. There are three S88's daisy chained together on BUS 2 and one S88 on BUS 1. There are a total of 80 feedback inputs. On the CS2 Layout tab, I created 80 feedback contacts so to visually monitor if the contacts are working. They work, regardless of the CS2 being connected to the PC or not.
Cycle time Bus 1 = 167 ms
Cycle time Bus 2 = 167 ms
Activation Time = 100 ms
S88 interval = 220 ms
S88 Query Interval = 100 ms
iTrain:
The Feedback information was created as described in the iTrain manual: following procedures in Appendix D, page 197 for Marklin (Link + GFP3). I tried to reset the Link S88 several times adding one S88 at a time and checking the feedback monitor. Same results. Also I tried to move the S88 from Bus 1 to Bus 2, makes no difference in iTrain, always get same result. I have worked on this problem for a month, searching forums for anyone who has the same problem, but I have not found the answer. It's time to find some help.
S88 Bus = (Link + GFP3)
S88 Link #2.0 (16) works in Feedback Monitor
S88 Link #2.1 works in Feedback Monitor
S88 Link #2.2 works in Feedback Monitor
S88 Link #2.3 fails in Feedback Monitor
S88 Link #2.M fails in Feedback Monitor
Activation Time = 200 ms
Channel Interval = 1000 ms
Feedback Switch On delay = 100 ms
Feedback Switch Off delay = 500 ms
Hope there is someone who can help.
Thank you,
Marklin Nut Confused
Offline Thewolf
#2 Posted : 14 August 2024 01:01:15(UTC)
Thewolf
Hi Peter Cool
My experience with Itrain is not rich enough to help you .
I suggest you register on the Itrain forum, where very good specialists will assist you, and if your problem turns out to be very complex, Xander will help you
https://berros.eu/itrain/forum
Thewolf
Offline PerR
#3 Posted : 14 August 2024 07:52:17(UTC)
PerR
Hi Peter,
I am using iTrain with a CS3 and a Link88 and a number of S88 at home and in my modeltrainclub, without any problems.
Did you remember to increase the number of S88 modules in the Connection setup where the connection to the CS2 is defined.
I think that a too low number there could explain what you see.
Have a nice day.
Per
thanks 1 user liked this useful post by PerR
Offline Marklin Nut
#4 Posted : 15 August 2024 03:09:37(UTC)
Marklin Nut
Originally Posted by: PerR Go to Quoted Post
Hi Peter,
Have a nice day.
Per
Hi PerR,
Thank you for the advice and your quick response. My setting for S88 has two modules above my actual S88 module count. I also wrote to the iTrain
forum and the advice I received was to read the manual in the Appendix. Which I had priorly done before contacting them.
I have been looking at how iTrain is reading my S88 modules and I believe that the problem occurred at some point during my initial setup. I moved
modules from bus 1 over to bus 2 on the Link88 after iTrain was set up. Now the S88 order count is incorrect. The addresses were changed on the S88
module in CS2 to reflect Bus 2. But now iTrain is reading S88 Link #2.3 in-place of S88 Link #2.2 and the module is a phontom in the iTrain feedback
monitor.
Tomorrow I will spend more time at trouble shooting. Somehow, I did something wrong and messed up the order of module 2 and 3. It appears that
iTrain only reads in 3 modules successfully and reads in 2 modules as phantoms. The phantoms are turning blue (outline only) so it sees receiving data
but iTrain fails to recognize it as a feedback signal.
Thanks again for the advice, I can give you an update on my findings.
I appreciate your help on this matter.
Offline Marklin Nut
#5 Posted : 16 August 2024 01:59:11(UTC)
Marklin Nut
Hi everyone,
Today I looked into the problem deeper trying to figure out how iTrain is reading the CS2 S88 Link feedback modules.
After some trial and error, I came to the conclusion that the last two S88 modules on each bus fails to be recognized by iTrain feedback monitor. I increased
the number of S88 from 6 to 8 in the CS2 (there are four S88 total not including the S88 Link). It made no difference to the results. I changed around the
S88 modules on each bus, making sure the addresses changed with the module, and the results were always the same. Two phantom lines appeared in the
iTrain feedback monitor, one that is sensing the last S88 on Bus 1 and the other for the last S88 on Bus 2. As for the CS2, all feedback sensors worked as
expected.
Is there a way to reset the S88 Link? I tried setting Bus 1 & Bus 2 in the CS2 to zero and then add one S88 at a time, but it made no difference. Any
suggestions would be greatly appreciated.
Offline Marklin Nut
#6 Posted : 31 August 2024 19:06:09(UTC)
Marklin Nut
Hello everyone,
Not sure if anyone is knowledgeable about iTrain. I found the answer to my own question after talking to Marklin mfg. My feedback modules are now working correctly, thanks from a little help from Marklin.
It was a misunderstanding on my part reading the iTrain manual on how to set-up an S88 Link, I found the wording a bit confusing, but it makes sense now.
I used the Node as the S88 module selection instead of the S88 bus selection. Since I had 0ne S88 Link plus four S88 modules in my system. Mistakenly, I had seen the "S88 Link #2.0 (16)"; "S88 Link #2.1 (496)"; "S88 Link #2.2 (496)"; "S88 Link #2.3 (496)"; and "S88 Link #2.M (64)" as feedback modules and not the S88 Link Bus 0, Bus 1, Bus 2, Bus 3 and Bus M. I'm not sure what the Bus M is except it could mean additional S88 Links connected to the Marklin's CAN-bus.
Anyway, hope if anyone stumbles onto this post with the same question, I hope it clarifies the confusion that I experienced.
Happy railroading,
Peter BigGrin
thanks 1 user liked this useful post by Marklin Nut
Offline PerR
#7 Posted : 01 September 2024 09:26:05(UTC)
PerR
The 16 input on the Link88 can be configured as normal input (#2.0 (16) ) with 16 possibilities or as a matrix (#2.M (64) with 64 possibilities.
I guess that this is the explanation.
Per
Offline Marklin Nut
#8 Posted : 04 September 2024 14:55:22(UTC)
Marklin Nut
Per
Thanks, it makes sense now. M stands for matrix.
This page was generated in 0.577 seconds.
