Offline obb_taurus
#1 Posted : 01 August 2024 16:22:38(UTC)
obb_taurus
I just got 4 of the IC2 Bi-Level cars yesterday (43486 > 43489) and I'm pulling them with a BR 103 (39173), to my dismay, when pulling out of the station it came to a slight curve which basically consist of a C Track 24224 going into a 4 way crossing. Going through the curve, the first car tipped partially to the side and then derailed. I found a video online that explained how the coupler can get caught on the underside of the buffers. I checked all the couplers to ensure that was not the case and noticed the couplers were not seated properly between the locomotive and car. Once I seated the coupler properly things were fine until the set went up an incline, as the set entered a curve on the incline it derailed again. I'm assuming because of the pull from the weight of the cars going uphill the slack on the couplers was pulled tight so it no longer clears the buffers which in turn causes the cars to derail. Hope this all makes sense, any suggestions on how I can fix this issue?
thanks 1 user liked this useful post by obb_taurus
#2 Posted : 01 August 2024 16:49:15(UTC)
It is possible that the coupler is hitting the buffers. It can also happen that the mechanism sticks at a specific point and this can cause the same issue to occur.
Do you have any Roco close couplers that you can test to see if the same problem occurs.
On my push-pull trains, I have been using the Fleischmann Profi Couplers (SBB IC 2000, EWIV, EWIII and Zuerich S-Bahn)
You can also test the coaches with the new Maerklin close coupler head, which is supposed to be exact NEM.
Offline obb_taurus
#3 Posted : 01 August 2024 17:38:40(UTC)
obb_taurus
I will check to see if the mechanism sticks.
I don't have any other couplers aside from a relex coupler which I also tried when the problem initially occurred between the lok and first car cause I thought the buffers were hitting on the turn because they were too close. It actually helped the problem but when I saw the video online I switched back to the close coupler.
All the cars come with current conducting couplers and the cab control car has the pickup shoe, guess even though they are sold separately, they are still considered a set. Unfortunately I don't have the new couplers but even if I did and they would solve the problem, I would have a new problem, I would have no lighting in the cars. Sad
Offline JGM
#4 Posted : 01 August 2024 20:01:35(UTC)
JGM
I had a similar problem with a different locomotive tried everything but the only fix was to reconfigure the track so that there was more straight on the approach current conducting couplers are just a little more tight just enough to be a problem also play around with the pick up shoe they can lock up and cause same problem enjoy the journey when you get it right you will have learned so much that will serve you again and again
#5 Posted : 02 August 2024 00:13:35(UTC)
I would send a quick email to digital(at)Marklin.com and see what Rick suggests. As you mention, this train has lighting controlled by the decoder in the pilot coach and requires current conducting couplers. The Maerklin design works with a metal contact which transfers the power from the coupling to a pin inside the coach that connects to the light channel. You could replace the uncouple-able ones with the fixed bar version and try that.
Technically, it would be also possible to use current conducting couplers by Viessmann, Roco or other, but you would have to bypass the Maerklin contact and run wires from the coupler to the coach interior. There is a current conducting version of the new coupler, which may avoid any impact with the buffers. Older Maerklin coaches (26-27cm) used to allow for the buffers to be pushed in for use with tighter curves. I don't know if the newer 28cm models have the same feature, particularly the double deck coaches you have...
As far as the incline, is it possible to add a shim under the tracks to make the incline begin more gradually?
#6 Posted : 02 August 2024 00:36:05(UTC)
Hi (no first name, this is OK, you are probably with the CIA, I understand)
@obb_taurus;674856
It happened to me on brand new Märklin that sometimes, the short-coupling mechanism is not as smooth as it should be either on some brand new cars (in my case the Edelweiss set) or when it is very cold (below 10°C) and a little spray of DRY Teflon in the mechanism does wonders.
The other thing I found with this set is that there was a mistake in my layout: an R1 curve followed by a triple switch resulted in an R1 followed by an R2 in the other direction (an S figure which is absolutely forbidden for long cars (coaches). Inserting the shortest straight track in-between did the trick.
Online rhfil
#7 Posted : 02 August 2024 01:02:03(UTC)
rhfil
I have experienced some couplings getting stuck when moving from side to side which is worse when a little pressure causes it to press against the bottom of the car. Moving the coupling with a bit of pressure an applying any lubricant that works on plastic, teflon or silicone, solved the problem.
Offline Pasquiles
#8 Posted : 02 August 2024 09:57:07(UTC)
Pasquiles
Luxembourg
I had this issue as well and I can confirm that new Maerklin close coupler head, helped to fix it.
Also adding weight to the wagons (like it is done in real life) helps as well.
thanks 1 user liked this useful post by Pasquiles
Offline obb_taurus
#9 Posted : 02 August 2024 20:30:28(UTC)
obb_taurus
I was actually able to run the set around my layout without it derailing yesterday evening but I could hear a clicking noise so I'm sure the couplers are hitting the buffers on some cars, sometimes it was hard to hear over the squeeky pickup shoe though. The only place it derailed was on an incline when it went over a curved turnout but it was the second last car which derailed instead of the first one. Will fiddle around with it some more to see if I can stop it from derailing complete.
With this set, I can really see how Marklin's quality has gone down, never had a squeeky pickup shoe on any kind of lok or cars before and what's with the paint? It feels like fine sand paper!! I'm beginning to worry what problems I will see with my Northlander whenever it arrives.
Jean, sorry for not signing my message, I don't work for the CIA, but I work for the Govt and I'm required to keep my identity secret so let's just call me Mike. LOL
Online rhfil
#10 Posted : 02 August 2024 21:56:27(UTC)
rhfil
I ran the cars that were derailing around the curve very slowly while I lowered myself to track level at a curve so I could watch what was happening. The coupler would jam before it slid all the way to the side. That caused the car wheels to come off the track and actually derail. Making it possible for the couplers to slide all the way to both sides prevented the raising and derailing. Adding weight to the cars would do the same thing - forcing the weight of the car to overcome whatever was preventing the coupler from fully sliding all the way.
Offline Copenhagen
#11 Posted : 03 August 2024 11:28:07(UTC)
Copenhagen
I have a set of the same cars. I can see that if you turn a wagon upside down and move the coupler and the bogie to their extreme positions it is possible for the wheel flanges to hit and snag on the back end of the coupler. Not sure if this is what causes any problems. It would only do in extreme curves.
I've changed the coupler on the car coupled to the locomotive (the Danish Vectron Litra EB) to the Roco universal which is also on the loco. The rest of the couplers the standard Marklin short couplers. I bought an extra bi car from another make (in order to have four wagons) and on that I put the new Marklin short couplers that are flatter than the old ones.
I have some "difficult" spots on my layout but the set runs fine. On some rolling stock I have to adjust wheel spacing not just because of the tight spots but just to ensure problem free driving and shunting.
(My set of three bi cars plus one is the Danish version. Not the German).
Edited by user 03 August 2024 18:36:40(UTC)  | Reason: Not specified
This page was generated in 0.346 seconds.
