Offline nouveau.ukiyo
#1 Posted : 23 July 2024 03:53:59(UTC)
nouveau.ukiyo
I'm new to model trains and I'm thinking of getting started with a simple N-scale Minitrix digital starter set and getting some track / trains to mostly do temporary layouts. I don't want to be tied to one brand and would like to have digital locomotives from several brands. Is the Mobile Station that comes with the Minitrix Starter Sets compatible with non-Minitrix products? And if I got a Central Station or another DCC controller, would there be issues with controlling several different brands on trains?
Thanks!
#2 Posted : 23 July 2024 07:53:35(UTC)
Welcome to the forum!
I have H0 gauge locomotives from many brands and the Trix MS2 handles them quite nicely. Should be the same for N gauge.
#3 Posted : 23 July 2024 12:22:24(UTC)
Welcome to this great forum.
Here is the little I know:
- MS2 (Märklin 60657 and Trix 66955) are identical except the green knob for the Trix unit.
- Minitrix operate with 15 VDC power supply to feed the track box (Märklin 60116 used both by Märklin and Trix) and not with 18 VDC power supply for both Märklin and Trix HO.
- upgrading MS2s is only possible using an on-line CS3 or CS2. Alternately a visit to your dealer may help.
- Digital on Z gauge uses DCC with a lower voltage (15 VDC to feed the "box").
- larger Märklin family gauge use 22 VDC to power the "box" (a different one) like LGB for instance.
I have the following units: CS1, CS2, CS3, MS1 and MS2
They are all very good except the CS1 and MS1 which now look prehistoric.
#4 Posted : 23 July 2024 17:02:58(UTC)
nouveau.ukiyo
Thanks for the details, this is helpful because I am considering HO and Z scale as well. It seems like I can use the same MS2 unit across different scale but I would need different power supplies?
One follow up question: I understand Marklin / Trix uses a different digital standard called mfx. Are there any significant features of mfx absent in DCC? If I have a non-Marklin DCC controller, would I lose features on a Marklin / Trix mfx locomotive?
#5 Posted : 23 July 2024 17:17:10(UTC)
Some Märklin locos have 32 functions, but I think only 29 can be controlled using DCC.
Without mfx, you miss out on the automatic mfx registration.
Without RailCom, you miss out on the automatic RailCom+ registration.
Märklin CS2 and CS3 have nice GUIs for programming Märklin mfx decoders.
If I'll ever have a permanent layout, I won't be using mfx with it. Still it's good to have a CS2/3 for programming.
I'm sure others will tell you that mfx is great.
Sorry, but try yourself and find out if mfx works for you.
#6 Posted : 23 July 2024 17:23:58(UTC)
nouveau.ukiyo
Thanks. I'm thinking of getting a Minitrix and Fleischmann starter set and playing around with both to see how they work. It looks like I won't be missing out on much without mfx.
You mentioned you don't have a permanent layout. I'm looking into just doing some temporary layouts. Is there a kind of track you prefer? I was considering the Kato Unitrack Master and Variation sets, as they seem easy to assemble / disassemble and feature some interesting desgins. The only drawback is that they are made for analog setups and not compatible with Minitrix controller without some modification.
#7 Posted : 24 July 2024 00:56:21(UTC)
@nouveau Ukiyo
MFX is great when using Märklin: Very user-friendly and improving all the time.
When using other brands I suggest you to use DCC (wide spread). I just had a nightmare using an ESU LokSound 5 micro decoder with a Märklin CS3.
Temporary layouts
I have now a permanent layout with C Track and it is excellent for temporary layouts as all is hidden uder the ballast (switch motors, decoders, etc) thus making the wiring very small and discrete. This is HO. I N gauge I don't know but maybe Kato hides their solenoid inside the points and they write " Digitrax recommends their DS52 or DS51K1 stationary decoder for operation of Kato Unitrack turnouts."
Offline bzzi
#8 Posted : 27 June 2025 00:35:24(UTC)
bzzi
Czech Republic
Hello guys.
And what about the voltage for other brands in MS/CS? Minitrix uses 19 volts, same as H0. However if I understand it well Piko uses 16V for digital. Can I safely run Piko with CS3? I'm thinking about Piko 94167 and Minitrix locos together on CS3+, but afraid of the voltage.
Thank for the help.
Ivan
Avatar picture - narrow gauge rack railway in High Tatras, Slovakia
https://en.wikipedia.org...3%C5%A0trba_rack_railway
#9 Posted : 27 June 2025 12:14:06(UTC)
Hello Ivan
It seems that Minitrix uses 66510 power supply with a 15 VDC output, taking into account the reduced voltage needed by N trains
More recent and more powerful PSUs (e.g. 60041) have a switch to set either 19 VDC or 15 VDC for respectively HO or N operation
Offline bzzi
#10 Posted : 27 June 2025 16:09:09(UTC)
bzzi
Czech Republic
Thanks Jean, I forgot about this switch on CS3+ power adapter.
I just tried Minitrix 16883 Re 4/4 II, which is quite new loco and it works with CS3+ with both voltages 15V and 19V set on PSU 60041.
I just have a feeling (no proper measuring) that it runs a bit slower on 15V, which would be understandable.
Sorry, nouveau.ukiyo, to update your thread, but I had a feeling it's been related.
Ivan
Guest (7)
This page was generated in 0.402 seconds.
